  1. Aug 19, 2018 at 8:36 PM
    Bootselectric
    Bootselectric Well-Known Member
    Stirling
    2004 PreRunner (RIP) 2013 TRD Sport (DCSB-BRM)
    Thank you, couldn’t be happier with how they turned out. Dig through the forums in Tacomaworld, specifically the “show off your Wet Okele” threads. I scoured the threads until I found Tacos with my exterior/interior with Wet Okeles that matched. Black matches everything, just a thought. Good luck on finding a set that works for you!
  2. Aug 19, 2018 at 9:14 PM
    Spoonman
    Spoonman Granite Guru
    Jamie
    Alberta
    Fan and transmission cooler in.
  3. Aug 20, 2018 at 6:24 AM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    Check Engine light is on.
  4. Aug 20, 2018 at 6:44 AM
    rngr
    rngr Aix sponsa
    01 SR5 4x4 2.7L
    Classic Allpro. haha. I had to open up the bolt holes with a file to get them to align properly. All-in-all, they're still an awesome bang for the buck though. Especially considering you have no other options with their bumper. haha.
  5. Aug 20, 2018 at 8:44 AM
    QMEDJoe
    QMEDJoe Proverbs 3:5-6
    Joe
    Columbus Grove, Ohio
    2003 Tacoma, V6, 5 speed, 4x4.
    Fox 2.0 Coilovers in the front and Fox 2.0’s in the rear, Total Chaos UCA’s, Al-lpro expo leafs, K&N cold air intake, TRD headers,Magnaflow catback exhaust,URD short throw shifter, switched out my 60/40 bench seat for some Tacoma Limited seats, Replaced the vinyl shift boot for a leather one, completely soundproofed the cab w/ Frost King. Replaced stock radio with a Pioneer AVH series head unit. Focal component system w/a 10" sub powered by 2 Alpine amps. Weathertech floor mats. Line-X'd the bed. SCS Ray 10’s, Installed an A.R.E. MX series camper shell. All-Pro Apex front bumper w/ All-Pro skid plates all the way back to the Trans. Low Range fuel skid plate.
    Had my Ray 10’s put on.
  6. Aug 20, 2018 at 10:54 AM
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
    Donahoe CO, Donahoe Rear Resi, Deaver J59, 16" Pro Comp, 33" BFG AT, Hayden Trans Oil Cooler, Oil Filter Relocator, FM 40, ES Bushings, Beefed CB Drop, Deckplate, K&N Drop-In, DO Bed Bar, Cobra 75 WXST, Firestik Firefly, Philips D1R, Clarion Remote Start, Husky Liners
    I'm pretty sure your truck has it if it's CA truck & non-cold spec. If you look on the bottom of the resivoir you'll see the pump mounted on the side of it & the fluid sensor is mounted in a larger round grommet at the very bottom.
    I don't use my washer fluid often. In the 14 yrs I've had my truck I've only seen it come on once and I've only had to fill it twice, second time a few months ago when I replaced the resevoir. The non-cold spec res holds a lot, like a gallon.
  7. Aug 20, 2018 at 11:00 AM
    eon_blue
    Azusa, CA
    yeah you're probably right, I think I do have it I just never run out of fluid lol. I always top it off when I do my oil changes and don't even use it all that much to begin with.
    zero4[QUOTED] likes this.
  8. Aug 20, 2018 at 11:37 AM
    MacGyvR
    MacGyvR Well-Known Member
    Tom
    Dallas, Texas
    03 Prerunner (5VZ-FE)
    OME 2.5", 881, Dakar, Nitrochargers
    Since replacing my radiator in March, two of my freeze plugs have rusted out. The first one was behind an engine mount, so the shop replaced that. This latest one was behind the starter, so I took care of it. I'm sure the rest aren't too far behind.
    SwampYota, FLBAdrian and zero4 like this.
  9. Aug 20, 2018 at 11:40 AM
    chrslefty
    chrslefty Well-Known Member
    chris
    Mesa az
    01 trd
    Stockish
  10. Aug 20, 2018 at 11:44 AM
    Phessor
    Phessor Well-Known Member
    Where did you get your battery terminal covers?
  11. Aug 20, 2018 at 11:48 AM
    chrslefty
    chris
    Mesa az
    01 trd
    Stockish
  12. Aug 20, 2018 at 12:16 PM
    Wulf
    rock raisin
    what cable did you use? I have the same terminal kit waiting to be installed.
  13. Aug 20, 2018 at 12:22 PM
    chrslefty
    chris
    Mesa az
    01 trd
    Stockish
  14. Aug 20, 2018 at 12:34 PM
    ToxicTwin
    ToxicTwin Money Talks...It Says Goodbye
    Robert
    Glendale AZ
    2009 TRD OR
    Nice looking rig!
    QMEDJoe[QUOTED] likes this.
  15. Aug 20, 2018 at 12:57 PM
    Wulf
    rock raisin
    Cool, thanks. I was going to solder the connectors :)
  16. Aug 20, 2018 at 1:06 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    No solder for big lugs, crimp is much stronger
  17. Aug 20, 2018 at 1:34 PM
    eon_blue
    Azusa, CA
    What am I doing to my Tacoma tonight...
    My 255/85 ST Maxx's get put on tomorrow AM, so I need to cut back my pinch weld and try to grind about a half inch off the corner of the end of my sliders. My 32s only clear it by about an inch right now, hoping I can grind away a bit more clearance with my angle grinder.
  18. Aug 20, 2018 at 1:54 PM
    Speedytech7
    Grind bash, rub, repeat
    eon_blue[QUOTED] likes this.
  19. Aug 20, 2018 at 1:55 PM
    Wulf
    rock raisin
    I need to do the same lol, I was thinking I would do at least an inch and cap them so I don't have to do it again if I go to 35s
  20. Aug 20, 2018 at 3:14 PM
    lambo
    lambo actually dumb
    Phil
    Lone Tree, CO
    2002 Double Cab TRD OR
    I got the winch controller mounting sorted this weekend. I ended up deciding to mount it above the winch, and in front of the grille. It ended up pretty good for a first shot and a couple hours of work. Ideally it would be a bit more level but whatever, it works great for now. I'm probably going to pull it off, tweak the bracket a bit so it sits level, and paint it black so it blends in a bit better.
