  1. Aug 24, 2018 at 2:08 PM
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
    Donahoe CO, Donahoe Rear Resi, Deaver J59, 16" Pro Comp, 33" BFG AT, Hayden Trans Oil Cooler, Oil Filter Relocator, FM 40, ES Bushings, Beefed CB Drop, Deckplate, K&N Drop-In, DO Bed Bar, Cobra 75 WXST, Firestik Firefly, Philips D1R, Clarion Remote Start, Husky Liners
    True that. Didn't even know mine was cracked until I took it off. Wasn't planning on buying a new one cause they're expensive. Just happened to come across one brand new for half the price so figured why not.
    eon_blue[QUOTED] likes this.
  2. Aug 24, 2018 at 6:19 PM
    1997tacomav6
    Denver
    Yes It’s obvious they don’t enjoy driving their truck as much as others
  3. Aug 24, 2018 at 6:21 PM
    Jay-coma
    Jay-coma Well-Known Member
    British Columbia
    Tossed in a new bearing after work
  4. Aug 24, 2018 at 7:28 PM
    Blue92
    Blue92 Well-Known Member
    Daniel
    North Carolina
    2018 Sport
    How easy is this? Ive had a mysterious noise lately and the symptoms point to the carrier.
  5. Aug 24, 2018 at 7:33 PM
    Prayn4surf
    Prayn4surf 20 minutes late
    Socal
    2004 Tacoma xtra cab
    BYJOSHCOOK, zero4, SwampYota and 4 others like this.
  6. Aug 24, 2018 at 7:38 PM
    QMEDJoe
    QMEDJoe Proverbs 3:5-6
    Joe
    Columbus Grove, Ohio
    2003 Tacoma, V6, 5 speed, 4x4.
    Fox 2.0 Coilovers in the front and Fox 2.0’s in the rear, Total Chaos UCA’s, Al-lpro expo leafs, K&N cold air intake, TRD headers,Magnaflow catback exhaust,URD short throw shifter, switched out my 60/40 bench seat for some Tacoma Limited seats, Replaced the vinyl shift boot for a leather one, completely soundproofed the cab w/ Frost King. Replaced stock radio with a Pioneer AVH series head unit. Focal component system w/a 10" sub powered by 2 Alpine amps. Weathertech floor mats. Line-X'd the bed. SCS Ray 10’s, Installed an A.R.E. MX series camper shell. All-Pro Apex front bumper w/ All-Pro skid plates all the way back to the Trans. Low Range fuel skid plate.
    Just came home to these.
    :yes::yay::taco:
  7. Aug 24, 2018 at 7:40 PM
    Phessor
    Phessor Well-Known Member
    Installed my new front differential with 4:88 gears, pretty easy going back in with the help of my daughter. Also installed new front bushings and bump stops. Along with a tire rotation.
    Still need to install the front drive line and put my skid plates back on. But it will be nice to drive it to work tomorrow.
    QMEDJoe and 1997tacomav6 like this.
  8. Aug 24, 2018 at 7:41 PM
    1997tacomav6
    Denver
    Make sure that “center zerk” Cardan joint is getting greased! There are three zerk fitting on the Cardan joint,
    And slip yoke zerk
  9. Aug 24, 2018 at 7:45 PM
    Blue92
    Daniel
    North Carolina
    2018 Sport
    Ive greased those to the point of them slinging grease all over the bottom of my truck. Its either the pinion angle or the bearing is just going out. But I find that hard to believe at 63k. I may try axle shims first.
  10. Aug 24, 2018 at 7:57 PM
    Prayn4surf
    Socal
    Hush you haha
  11. Aug 24, 2018 at 8:04 PM
    pairodice
    pairodice Well-Known Member
    Jay
    SF NM
    02 DCSB prerunner 4x4 manual
    Drove it around now that it's a manual 4x4 pre runner :thumbsup:
    BYJOSHCOOK, SwampYota and m3bassman like this.
  12. Aug 24, 2018 at 8:19 PM
    eon_blue
    Azusa, CA
    Careful, if you over grease them it can ruin them as well. I did that too to where it slung grease all over and my mechanic told me it was way too much, can hurt it that way
  13. Aug 24, 2018 at 8:22 PM
    RyanL
    RyanL Well-Known Member
    Indiana
    15 TRD Pro, supercharged, BP-51s, etc
    Found some 3rd gen TRD OR wheels, they look GOOD on the red 1st gen
  14. Aug 24, 2018 at 8:22 PM
    Blue92
    Daniel
    North Carolina
    2018 Sport
    Great... I wont grease them again for a while. Thanks for the heads up. Ill get the driveline looked at sometime in the near future.
  15. Aug 24, 2018 at 8:32 PM
    OneWheelPeel
    OneWheelPeel Well-Known Member
    Phoenix, AZ
    Gorman?
  16. Aug 24, 2018 at 8:38 PM
    eon_blue
    Azusa, CA
    He told me a just a few pumps but I've read before that you go until it starts to ooze out. I think that over time I over-greased it by doing it too frequently. Didn't hurt anything in my case but when he saw the mess under my truck from the grease getting flung all over he told me it was too much.
  17. Aug 24, 2018 at 8:39 PM
    eon_blue
    Azusa, CA
    I'm sure you're fine it's common to see that happen, just don't want to overdo it too often.
    2002Tacoma4x4 likes this.
  18. Aug 24, 2018 at 8:41 PM
    1997tacomav6
    Denver
    When you over fill slip yoke, the grease takes up the space inside the driveshaft where the yoke is supposed to slide into. Air compresses, grease doesn't, so it is now acting more like a solid driveshaft.
    Reh5108 likes this.
  19. Aug 24, 2018 at 8:51 PM
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
    Yep.
    Edit: Rally race there tomorrow. I never been to watch one of them there & was curious. Was thinking about going back tomorrow to check it out but found out I have to go to a bday party.
  20. Aug 24, 2018 at 9:00 PM
    Seagull233
    Seagull233 Well-Known Member
    Tom
    Upstate New York
    2004 DC 4x4 V6
    BMW seats, OME Suspension, CBI and NWTI plates front and rear, 13,000 winch, LED light bars, Ham Radio, topper with roof rack added, stainless exhaust, 2nd battery, inverter, sound deadener
    Probably got it on his uniform!
