  1. Aug 26, 2018 at 7:44 PM
    04doublecab
    04doublecab Well-Known Member
    Jeff
    2004 Tacoma
    Trucks fucken sick Jamie.
    Spoonman[QUOTED] likes this.
  2. Aug 26, 2018 at 7:51 PM
    burntkat
    burntkat Well-Known Member
    Phillip
    Charleston, SC
    97 Extracab Tacoma
    Why a last alignment? Are you going SAS?
  3. Aug 26, 2018 at 8:04 PM
    malburg114
    malburg114 Well-Known Member
    Las Vegas, NV
    2001 Toyota Tacoma TRD
    You probably wont be able to cycle just one side. Leaf springs are weird and the axle will act different. Plus if your doing the work might as well cycle and setup bump stops and measure for the exact length of shocks needed.
  4. Aug 26, 2018 at 8:14 PM
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
    Donahoe CO, Donahoe Rear Resi, Deaver J59, 16" Pro Comp, 33" BFG AT, Hayden Trans Oil Cooler, Oil Filter Relocator, FM 40, ES Bushings, Beefed CB Drop, Deckplate, K&N Drop-In, DO Bed Bar, Cobra 75 WXST, Firestik Firefly, Philips D1R, Clarion Remote Start, Husky Liners
    Oh, no I wish. One last time until next year. I've had 5 alignments in the past 2 months. 3 of which cause one place didn't know what they were doing. The 4th alignment which was the 1st good one I got after replacing most of the front suspension. 5th alignment I got after tack welding the steering column shaft. I just replaced by leaf bushings with new shackles & super bumps while I was at it, didnxt think it would have but it threw my alignment off a bit.
    I'm tired of getting alignments. Still need to replace my LCA bushings but I'll wait till next year along with TREs, then won't have to worry about alignments until as needed normally.
  5. Aug 26, 2018 at 8:21 PM
    burntkat
    Phillip
    Charleston, SC
    97 Extracab Tacoma
    If you want to do it the easiest way, remove all but the.main leaf. Fit a tire. Flex the suspension out with a jack (or forklift if you have one). Set the bumps up, then measure the opposite side for shock length. Remember you want your shock about a half inch longer than the absolute maximum of your available articulation. It isn't a terrible idea to use limit straps to protect the shocks. Don't get crazy chasing big numbers.
  6. Aug 26, 2018 at 8:23 PM
    burntkat
    Phillip
    Charleston, SC
    97 Extracab Tacoma
    Well, you DID go to a metric 33 after all. . ;)
    Titus94[QUOTED] likes this.
  7. Aug 26, 2018 at 8:25 PM
    burntkat
    Phillip
    Charleston, SC
    97 Extracab Tacoma
    Got to ask, why on earth did you weld your steering shaft?
  8. Aug 26, 2018 at 8:40 PM
    Teke
    Teke Soft-Roader :)
    Colin
    Indiana
    2017 TRD Sport 1996 Tacoma SR5 Sold
    Small tack welds will take away the slop but should still break in case of an accident
    zero4 likes this.
  9. Aug 26, 2018 at 8:42 PM
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
    Had so much steering wheel play I hated driving my truck. With that and replacing the steering rack guide & spring feels like brand new again.
    OneWheelPeel and Dan8906 like this.
  10. Aug 26, 2018 at 10:37 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Its the company truck
    X2 for this mod, it works wonders
    Dan8906 and zero4[QUOTED] like this.
  11. Aug 26, 2018 at 11:42 PM
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    150 with a military discount. .not bad.
  12. Aug 27, 2018 at 12:10 AM
    eon_blue
    Azusa, CA
    Last minute trip this afternoon, Pilot Rock 4x4 trail up to Lake Arrowhead so I could pee in the natural spring water everyone on the west coast drinks. Sorry in advance
  13. Aug 27, 2018 at 5:22 AM
    Keep on Truckin'
    Keep on Truckin' Well-Known Member
    Jarvis
    Indiana
    02 Imp. Red - Ext. Cab SR5 4x4- 2.7- Auto
    Rear Locker, TRD Alloy Wheels & Cooper AT3 Tires, Camper Shell ,, K&N ,Icon AALS
    HELP! Spent all day yesterday chasing electrical gremlins. Everything worked until yesterday morning ! ALL the turn signals work Until you step on brake then they Hyper flash also the Same Hyper flash when you turn the park/headlights ON. Hazards are doing the same Hyper flash when you turn on the park/ headlights . ALL bulbs are working! Flasher Relay is clicking & the turn signals/Hazards are working ? NO led lights/ bulbs ! HELP!! Thanks
  14. Aug 27, 2018 at 6:13 AM
    burntkat
    Phillip
    Charleston, SC
    97 Extracab Tacoma
    Why not replace the part? Do the job properly. This IS a life-safety issue, after all.
    I'd hate for him to find out he'd welded it too well in an otherwise minor accident, when the steering column gets driven through his spine.
    Area51Runner and Dan8906 like this.
  15. Aug 27, 2018 at 7:02 AM
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    Thats the mod. You weld it to prevent slop. They all have play
    zero4, Keep on Truckin' and Dan8906 like this.
  16. Aug 27, 2018 at 7:20 AM
    tony2018
    tony2018 Well-Known Member
    Omicron6 likes this.
  17. Aug 27, 2018 at 8:35 AM
    Keep on Truckin'
    Jarvis
    Indiana
    NO trailer light wiring harness, removed over a year ago due to light problems, Thanks for responding. Any ideas on what else I can check ?? Thanks .
  18. Aug 27, 2018 at 8:46 AM
    04doublecab
    Jeff
    2004 Tacoma
    I need to do this and my damn rack bushings
    Fernando[QUOTED] likes this.
  19. Aug 27, 2018 at 11:22 AM
    desertjunkie760
    desertjunkie760 @DesertJunkie760 (IG)
    Shane
    2011 MGM DCSB TRD Sport 4x4
    Check My Sig.
    :boink::boink:
    I also see that you have not painted your sliders yet and they are starting to surface rust? :boink:
    Prayn4surf likes this.
  20. Aug 27, 2018 at 11:30 AM
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
    You certainly can replace the part, it's $180-$200 depending on where get it. But it will happen again if you wheel your truck and/or have big tires.
    Way more others who have done this mod long before I have. Some people with no welder access usese roll pins but I don't agree with that. I would rather use a brass shear pin but I did not feel like machining one & my lathe is buried right now. Tack welds is much quicker & easier.
    I'm not recommending to do this mod, it's up to owner of the truck. But I'm not worried about it. In a minor accident it's not going to do anything. It's designed to collapse in a major accident in which my opinion will still happen.
    I flew a car off a cliff at 95 mph when I was a teen & was lucky to be ok. I didn't get hurt at all, steering column still in tact, didn't even feel the air bag.
