  1. Aug 31, 2018 at 11:49 AM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    I believe it, damn #overlanders
  2. Aug 31, 2018 at 12:00 PM
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    You need to spend way more money than that before you're a proper overlander. :anonymous:
    Are you even on expo portal bro?
  3. Aug 31, 2018 at 12:10 PM
    eon_blue
    Azusa, CA
    wut there's an expo portal? Like you step inside and get transported to someplace awesome?
    BYJOSHCOOK and Yetimetchkangmi like this.
  4. Aug 31, 2018 at 12:18 PM
    JKO1998
    Utah
    Stock life bro for about 6 more hours till I’m home.
    Bulldogs129 and Yetimetchkangmi like this.
  5. Aug 31, 2018 at 12:46 PM
    Bulldogs129
    Bulldogs129 Don't find fault, find a remedy
    Malcolm
    Mississippi
    2018 TRD, OR, 4wd, Dblcab, 3.5l, & 2002 Tacoma 4wd, SR5, TRD, 3.4L, auto
  6. Aug 31, 2018 at 12:53 PM
    Squeaky Penguin
    Brett
    nagorb and Bulldogs129[QUOTED] like this.
  7. Aug 31, 2018 at 12:54 PM
    Willbeck
    Willbeck Well-Known Member
    Will
    Huntington Beach
    00 Reg Cab 4x4
    Bug deflector
  8. Aug 31, 2018 at 12:58 PM
    Squeaky Penguin
    Brett
    I'll stick with the stronger axles and hubs.
    There's only been a few times I've thought 2 low would be helpful anyways. It would be nice for wheeling on the slickrock, but that's about it.
    BYJOSHCOOK likes this.
  9. Aug 31, 2018 at 1:01 PM
    JKO1998
    Utah
    What about da snow?
    I honestly have no idea, I’ve just read people like it, I think.
  10. Aug 31, 2018 at 1:05 PM
    Squeaky Penguin
    Brett
    I don't see 2 low being helpful in the snow in any situation.
    Willbeck likes this.
  11. Aug 31, 2018 at 1:07 PM
    JKO1998
    Utah
    Floating on top of it going really slow so ya don’t sink.
    I dunno bro, just thinking
  12. Aug 31, 2018 at 1:12 PM
    BlackPearl
    BlackPearl Well-Known Member
    Alex
    Toyota Tacoma TRD
    3” lift. Sway a ways 2.5 on 285 75 16 and much more
    If you have 14'' 700 pound springs try removing your front sway bar. I took min off for a few months and it seems to ride much better.
    With heavier spring the body roll is not as bad.
    Dan8906[QUOTED] likes this.
  13. Aug 31, 2018 at 1:16 PM
    Squeaky Penguin
    Brett
    I think you'd still be better off in 4 low.
    Tight turns is about it. On slickrock where it binds the xfer case really bad, but you need the control of low range. That happens several times every time I wheel Moab.
    Also, going down tight switchbacks it could be helpful. When going down black bear, a buddy in a 2nd gen with an auto put it in 2wd, and made the turns tighter than me, as the xfer case binding pushed the truck through the corner and increased the turning radius. I didn't dare put it in high range though as I needed low to maneuver carefully around the corners and multi point turns.
    m3bassman[QUOTED] likes this.
  14. Aug 31, 2018 at 1:28 PM
    Dirty Pool
    Dirty Pool FLIES ON THE FRIES, KETCHUPS WATERED DOWN
    59.4 Miles, 56.67° NE Of Moab
    99 XCAB V6 MT TRD
    Dirty Pool rear bumper/air tank with integrated spare CV shaft storage, DP customized TJM front bumper, 8000 lb Ramsey/Technora rope, E-locked, Extended breathers with front diff catch can, PCV catch can, SAWs with DP heim joint seals, DP custom 6 leaf rear springs/Billies, DP custom skids, 2lo, Gray wire, Cap, Bed Rug, Black steelies, 01 Center console, Map lights, Disraeli gears
    2lo with a j shift case is as simple as putting a switch on one wire.
    Comes in handy when a trail is lumpy enough to require real slow speeds yet not 4wd.
    jubei, Reh5108 and Squeaky Penguin like this.
  15. Aug 31, 2018 at 1:31 PM
    JKO1998
    Utah
    Ya know, I just realized what the conversation was about.
    I thought you were talking about setting up a twin stick double low range set up kinda deal (whatever that’s called).
    I feel waaay dumb.
  16. Aug 31, 2018 at 1:33 PM
    Reh5108
    Reh5108 Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    I think if I didn't have an auto locker I'd have it. I put a switch in line to interrupt the signal to the ADD. The driveshaft would spin and the stub shaft would get all the power.
  17. Aug 31, 2018 at 1:36 PM
    Squeaky Penguin
    Brett
    Makes sense now. I was stuck thinking there wasn't an way to do it at the xfer case like with the push button cases, but that would work assuming you don't have a lunchbox locker. :thumbsup:
    Reh5108[QUOTED] likes this.
  18. Aug 31, 2018 at 1:37 PM
    Reh5108
    Idaho
    When I had manual hubs, 2 low was fun to just see what it was capable of and it definitely helped me turn since my driverside axle is always locked.
  19. Aug 31, 2018 at 1:44 PM
    burntkat
    burntkat Well-Known Member
    Phillip
    Charleston, SC
    97 Extracab Tacoma
    Could you explain how this is possible? I am new to Toyotas, but my truck has a J-shift case and manual hubs. I don't see how wires come into the picture at all.
  20. Aug 31, 2018 at 1:46 PM
    Reh5108
    Idaho
    If you have manual hubs they don't. Nothing electronic about it. Unless someone swapped the hubs in an ADD truck.
    burntkat[QUOTED] likes this.
