  1. Sep 3, 2018 at 3:43 PM
    Area51Runner
    Area51Runner Well-Known Member
    Northern California, Bay Area
    02 3.4 DC TRD PreRunner 4WD SWAP
    Honestly, I'd stick with the stock filter if I hadn't already bought the AFE :anonymous:
    Sperrunner and Blue92 like this.
  2. Sep 3, 2018 at 3:46 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Its the company truck
    Yeah I bought a afe way before i new it didn’t do anything
    Area51Runner[QUOTED] likes this.
  3. Sep 3, 2018 at 3:50 PM
    Area51Runner
    lol well, to its credit I've only actually washed it like twice in the last 4 years. Aside from that, a shop vac treatment here and there and the thing is super clean.
    Sperrunner likes this.
  4. Sep 3, 2018 at 3:52 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Yeah mine looks new compared to tylers and we have had them about the same time
  5. Sep 3, 2018 at 3:55 PM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    I know it doesn’t increase any power.
    I just like how it sounds.
    And I can’t do the deckplate mod, because I would fail SMOG for modifying the intake system.
  6. Sep 3, 2018 at 3:55 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    Good idea.
  7. Sep 3, 2018 at 4:04 PM
    burntkat
    burntkat Well-Known Member
    Phillip
    Charleston, SC
    97 Extracab Tacoma
    They were pressed in, not threaded. Shoddy worksmanship at the factory. Thread the hole and install better zerks.
    Reh5108 and Lux[QUOTED] like this.
  8. Sep 3, 2018 at 4:15 PM
    Itchyfeet
    Itchyfeet Well-Known Member
  9. Sep 3, 2018 at 5:04 PM
    Reh5108
    Reh5108 Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    It's the same procedure for either. There is a 10mm bolt in the center that needs to come out first. I used a strap wrench to keep the compressor from spinning. Once the bolts out the clutch should slide off. I used a puller to get it off but the 4r didn't have room so we just used a pry bar on top and bottom. Then there is a snap ring holding the pulley on. For me it was easiest to unbolt the compressor mounts and angle it so I could see what was going on. The pulley should then slide off with the bearing. Then there is another snap ring holding the coil on.
    burntkat[QUOTED] likes this.
  10. Sep 3, 2018 at 6:50 PM
    HCFab
    HCFab Hudson Custom Fabrication
    Zach
    Central Idaho
    Overland 04' v6 4x4 5spd Xtracab, Lunar Mist.
    What's the make/model of that Topper? That's exactly what I'm hunting for.
    burntkat likes this.
  11. Sep 3, 2018 at 6:52 PM
    Phessor
    Phessor Well-Known Member
    I installed Daystar airbag cradles on the bottom mounts, that way the airbag can pull away from the axle when fully flexed. Drove it to work today (43 miles) with 10 psig in the airbags, it was just a little bit stiffer then usual but not bad.
  12. Sep 3, 2018 at 7:18 PM
    Jon64l
    Jon64l Well-Known Member
    Jon
    2006 Tacoma, 2000 4runner, 1996 Tacoma
    Let her eat today
    Prayn4surf, jubei, BYJOSHCOOK and 4 others like this.
  13. Sep 3, 2018 at 7:28 PM
    RedManRocket
    RedManRocket Well-Known Member
    Red
    Sonora, Central Cali
    2002 Double Cab LT
    Esb 5.5 with Kings Mcneil 6.5 fenders Other stuffs
    Update on front end, just about done :bananadance:IMG_20180831_165727_869.jpg
    Prayn4surf, jubei, BYJOSHCOOK and 7 others like this.
  14. Sep 3, 2018 at 7:28 PM
    tony2018
    tony2018 Well-Known Member
    I'm thinking the a motor mount issue..
    Also I'm not sure why I wasn't notified @BartMaster1234 of your post..weird..
    Check motor mounts, check tranny fluid level. Also did you replace your torque converter when you replaced the transmission? Can't remember.
  15. Sep 3, 2018 at 7:29 PM
    tony2018
    WHOA...
    RedManRocket[QUOTED] likes this.
  16. Sep 3, 2018 at 7:32 PM
    RedManRocket
    Red
    2002 Double Cab LT
    Going all out #doitonce :D:D:rofl:
    tony2018[QUOTED] likes this.
  17. Sep 3, 2018 at 7:37 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    Yes I used my original torque converter because the one that came with the A340F was warped. There is a different stall speed between the A340E and A340F TC’s.
    I checked transmission fluid level, it’s normal. Motor mounts are original as far as I know.
  18. Sep 3, 2018 at 7:41 PM
    tony2018
    I've heard peeps had issues with vibrations with the angle of the shaft after the carrier bearing. Some used some washers to lower the carrier bearing to fix that, hopefully someone chimes in on that to confirm that.
  19. Sep 3, 2018 at 7:42 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    Part of me thinks it’s some kind of vacuum or throttle body issue from my K&N oiled filter. When I have time, I’ll pull the throttle body off and clean it.
  20. Sep 3, 2018 at 7:46 PM
    tony2018
    Hopefully you didn't really drench the filter too much. since you clean your maf you can try cleaning your throttlebody.
    Keep on Truckin' likes this.
