  1. Sep 4, 2018 at 1:33 PM
    Dan8906
    Dan8906 Well-Known Member
    Daniel
    Concord, California
    2004 Tacoma ext cab TRD 4x4
    CBI sliders, ADS extend travel with compression adjuster coil overs, 9” Bilstein 5125 rear shocks, Icon Tubular UCA, Alcan custom leafs, All Pro Apex bumper and skids, NWTI rear diy bumper, 295/70/17 Cooper St Maxxs and nitro 4.88s.
    I guess having fuses in series doesnt really affect anything right? Cause if you have a surge it will just pop the first fuse.
    Oldred92[QUOTED] likes this.
  2. Sep 4, 2018 at 1:56 PM
    Dan8906
    Daniel
    Concord, California
    Also what gauge wire did you run to the box from the battery terminal? 4gauge?
  3. Sep 4, 2018 at 2:11 PM
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    My new frame finally came in 4 months later.. wallets much lighter but now the truck can finally start going together. Engines out in Arizona in the next week or so. She should be running by spring. (I’ll post pictures of the frame when I get home)
    burntkat likes this.
  4. Sep 4, 2018 at 2:33 PM
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    damn, I destroyed a wheelers bump stop this weekend. cracked it in half! :burnrubber:
    rngr and zero4 like this.
  5. Sep 4, 2018 at 2:40 PM
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
    Donahoe CO, Donahoe Rear Resi, Deaver J59, 16" Pro Comp, 33" BFG AT, Hayden Trans Oil Cooler, Oil Filter Relocator, FM 40, ES Bushings, Beefed CB Drop, Deckplate, K&N Drop-In, DO Bed Bar, Cobra 75 WXST, Firestik Firefly, Philips D1R, Clarion Remote Start, Husky Liners
    Damn that sucks! Hope mine don't do the same. Time to get pasticguy's rear bumps! I'm planning on getting a set too when they get released.
  6. Sep 4, 2018 at 3:42 PM
    Hashmaster3k
    Hashmaster3k Member
    CO
    '17 TRD OR
    Stock -- for now...
    Replaced timing belt, all accessory belts, water pump, t-stat, crankshaft and camshaft seals, two rollers and timing belt tensioner. Also put this sticker on...
  7. Sep 4, 2018 at 3:43 PM
    FLBAdrian
    FLBAdrian A Pretty Sizeable Onion
    Adrian
    Hanford Ca,
    1996 X-Cab 3.4l 2014 Tacoma crew cab
    Too many…
    I did the pinch weld mod, vacuumed the inside, washed it, going to do clay bar and wax it. F07616DC-0D98-4EDE-A09F-0FD0CFBCEDC0.jpg
  8. Sep 4, 2018 at 4:58 PM
    tony2018
    tony2018 Well-Known Member
    Def will be looking into the cradles and airbags in the near future.
  9. Sep 4, 2018 at 5:16 PM
    SwampYota
    SwampYota Strange things are afoot at the Circle K
    Jon
    Concord, North Carolina
    '03 Tacoma SR5 TRD 5VZ-FE, 5 Speed
    Floor mats
    Ran mine through the automatic car wash. I knew the passenger side leaked got to watch it pouring in today. I really need to do that TSB.
    EF640066-F7A4-41AA-BC32-E5405C1A68AD.jpg 7E116D57-089F-4F47-A5C7-02E1F9EEEB7D.jpg
    FLBAdrian and zero4 like this.
  10. Sep 4, 2018 at 6:18 PM
    Empty_Lord
    Dan
  11. Sep 4, 2018 at 6:28 PM
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
    Finally replaced my carrier bearing & gave my driveshaft a quick dirty coat of paint. I didn't remove the front section of the driveshaft, just replaced the CB & painted with it on the truck.
    Also fixed the crack on my windshield that I got last week from my Pismo trip.
    This pic showing driveshaft angle with the CB drop. Rear wheels are off the ground.
    Before & after pics. It's not completely gone but well worth the $10 for the kit & it doesn't catch my eye anymore which was really annoying. I can still see it if I look for it & with the circle I drew removed my camera can't even focus on it. Now it just looks like a spec of dirt or like one of the many other small pits I have on the windshield.
    20180904_132300.jpg 20180904_132322.jpg 20180904_180238.jpg 20180904_180529.jpg 20180904_180711.jpg 20180904_134315.jpg
    burntkat and SwampYota like this.
  12. Sep 4, 2018 at 6:43 PM
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
    Where does it leak from & what does the TSB fix? Curious, I never heard of this issue.
  13. Sep 4, 2018 at 7:09 PM
    SilverGhost
    SilverGhost Well-Known Member
    RayRay
    Reunion, Co
    02,03 some 04, it's complicated
    #junkyardparts
    Looking at your avatar makes me wonder how your motor mounts are holding up. :p
    burntkat and zero4[QUOTED] like this.
  14. Sep 4, 2018 at 7:14 PM
    Blue92
    Blue92 Well-Known Member
    Daniel
    North Carolina
    2018 Sport
    How frusturating was the CB replacement? Ive gotta do mine soon and I'm a bit intimidated to drop the shaft. Glad to see you had better luck with the stupid chip kit than I did. When I pulled the little cone piece off, it took all the filler with it. My one chip has procreated into two so its come to my attention I need to get them professionally fixed.
    zero4[QUOTED] likes this.
  15. Sep 4, 2018 at 7:14 PM
    SilverGhost
    RayRay
    Reunion, Co
    #junkyardparts
    Interesting how your 02 has an throttle body like that. I thought they didn't go to those until 03.
  16. Sep 4, 2018 at 7:14 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Wheeled mine for a week. Good times.
  17. Sep 4, 2018 at 7:16 PM
    SilverGhost
    RayRay
    Reunion, Co
    #junkyardparts
    Pics or it didn't happen :D
  18. Sep 4, 2018 at 7:18 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Its the company truck
    Weird my 04 has tbe old style
  19. Sep 4, 2018 at 7:21 PM
    SilverGhost
    RayRay
    Reunion, Co
    #junkyardparts
    Really, odd. Yeah from what I've read 03-04 switched to the cable and wire TB.
    zero4 likes this.
  20. Sep 4, 2018 at 7:22 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Thats what I thought too but my 04 is the old style
    zero4 and SilverGhost[QUOTED] like this.
