  1. Sep 5, 2018 at 12:04 PM
    burntkat
    burntkat Well-Known Member
    Phillip
    Charleston, SC
    97 Extracab Tacoma
    I'm surprised that someone "making the loudest stereos in the country" doesn't know what a relay is.
    A relay allows you to control a high current circuit (lights, winches, etc) with a low current circuit.
    Can you tell me why this is important?
  2. Sep 5, 2018 at 12:11 PM
    License2Ill
    License2Ill Woke like a Coma Toyota Tacoma
    Ian
    It's a dry heat thou, AZ
    2004 SC'd 5VZ DC 5spd 4x4 TRD.GOV
    Bailing wire & Duct tape
    That bluesea fuse box is rated at 100ADC Max. And usually fuse rating @12" suitable wire at max current x1.25 decides the fuse hence 125A fuse.
    If you're running a continuous 85A at 9" of #6awg is fine. I'd up the wire size to at the very minimum 4ga if you plan to max out the fuse box at 100A. I would not go over the 100A rating.
    Oldred92[QUOTED] likes this.
  3. Sep 5, 2018 at 12:18 PM
    foxrcing07
    foxrcing07 KO7FOX
    Morgan
    Modesto, CA
    2019 Raptard 2001 TJ
    Dirt
  4. Sep 5, 2018 at 12:41 PM
    El Taco Diablo
    El Taco Diablo Professional Pinstriper
    Matt - KN6DZP
    Hughson, CA
    Impulse Red DC, 5vz-fe, 4wd swap, LT, dual case, F/R locked
    Just 3 tons of fun!!!
    County not Country... and you don't run relays for stereos. You run power, ground and remote. All the relays you need are already in the equipment your using.
  5. Sep 5, 2018 at 12:44 PM
    tony2018
    tony2018 Well-Known Member
    You can use relay's when you need to remote power on an amp if the cheap head unit doesn't have a way to do that. But now a days amps detect signal.
    burntkat likes this.
  6. Sep 5, 2018 at 12:47 PM
    Reh5108
    Reh5108 Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    With the amount of money I throw at it, I'd like to think it's a space craft.
    I don't go out of my way to put lock washers on anything. Torque to spec if it's important and paint mark it.
    Fun fact: ski lifts use nordlocks in certain applications.
    burntkat[QUOTED] likes this.
  7. Sep 5, 2018 at 12:56 PM
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    You really want to be that guy right now?
    I asked a question, and I made a sarcastic statement.... don't be the guy with the man bun in the conversation.
    koditten, Nate0303 and Adude like this.
  8. Sep 5, 2018 at 1:08 PM
    burntkat
    Phillip
    Charleston, SC
    97 Extracab Tacoma
    Having been an autosound installer at a high level, I couldn't disagree more. We used tons of relays.
    There is far more to a competitive autosound system than just power, ground, and remote. Especially if you want it not to become someone else's. ;)
  9. Sep 5, 2018 at 1:10 PM
    burntkat
    Phillip
    Charleston, SC
    97 Extracab Tacoma
    We agree, then. I don't trust things simply to lockwashers. Having a "witness mark" so I can tell at a glance if things are backing off is just good practice... to say nothing of threadlocker.
    Didn't know that nordlocks were used in skilifts. But then, I have not seen a skilift since they were invented! :)
    Reh5108[QUOTED] likes this.
  10. Sep 5, 2018 at 1:11 PM
    burntkat
    Phillip
    Charleston, SC
    97 Extracab Tacoma
    I'm bald, you insensitive shit!
    Speedytech7 likes this.
  11. Sep 5, 2018 at 1:11 PM
    burntkat
    Phillip
    Charleston, SC
    97 Extracab Tacoma
    -smirks and wonders if I'm gonna have to prove it-
  12. Sep 5, 2018 at 1:12 PM
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    My 01 and my dads 02 do not have abs... standard was in 03-04
  13. Sep 5, 2018 at 1:13 PM
    burntkat
    Phillip
    Charleston, SC
    97 Extracab Tacoma
    -turns computer monitor around trying to figure out what in hell I am looking at-
    Were you intoxicated when you took this pic? :)
    (close the hood, crank it and gun it~ let the fur fly.... it's only a cat!)
    Oldred92 likes this.
  14. Sep 5, 2018 at 1:18 PM
    chrispchicken9
    chrispchicken9 Well-Known Member
    '04 3.4 tacoma, '16 4.0 4runner
    It's a 1999 Leer 122 built for 99-04 tacoma trucks
    HCFab[QUOTED] likes this.
  15. Sep 5, 2018 at 1:20 PM
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    Well... good for you buckaroo. I think you should pat your self on the back.
    And you didn't use relays on a sound system. Maybe multiple head units, or DVD, or lights, or actuators for doors. But if you were running a head unit, capacitors, amps, speakers... there is no reason to run a relay.
    So... how does any of this help me figure out the answer to the question that I'm asking? Or do you just like being the guy with the man bun?
  16. Sep 5, 2018 at 1:21 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Its the company truck
    No i was taking a video and trying to record while i open the hood. Then just sag a screen shot of the video. Didn’t bother to flip the picture
  17. Sep 5, 2018 at 1:31 PM
    foxrcing07
    foxrcing07 KO7FOX
    Morgan
    Modesto, CA
    Dirt
    :worthless:
  18. Sep 5, 2018 at 1:52 PM
    burntkat
    Phillip
    Charleston, SC
    97 Extracab Tacoma
    Yes, we did- all the time... why? Well, when the turn-on lead (which is of course, sourced from the head unit, Junior) only supports a 500ma load, each device (amp, crossover, etc) poses about a 200ma load, and you are running 3 or 4 devices, you will literally fry the hell out of the turn-on lead coming out of the head unit... if you don't use a relay.
    As I said before (answering your question, BTW)- a relay allows control (switching) of a high-current load by way of a small current.
    Put another way- the coil is the low-current side. The NO/NC poles are the high current side.
    Application- switch from the dash controls the coil, using lightweight wire and no concerns of excessive wire run length and up-sizing the high-current wire to accommodate the added length of running from the battery, into the cabin, and out again. The high-current leads can be kept in the engine compartment (in the case of one of the most common uses for a relay, upgrading the factory headlights to ensure they get full battery voltage).
    But hey, apparently you think I'm sexy or something, keep going after the man bun. Have fun with that, but keep it to yourself.. and you're cleaning up the mess.
    Speedytech7 and Fernando like this.
  19. Sep 5, 2018 at 1:53 PM
    burntkat
    Phillip
    Charleston, SC
    97 Extracab Tacoma
    Believe me, noone wants to see my ugly mug. :/
  20. Sep 5, 2018 at 1:56 PM
    SwampYota
    SwampYota Strange things are afoot at the Circle K
    Jon
    Concord, North Carolina
    '03 Tacoma SR5 TRD 5VZ-FE, 5 Speed
    Floor mats
    So many skills, not a one of them “people.”
    Did you actually do anything to your Tacoma today or are you just here to get in a perpetual d**k measuring contest?
    nagorb, Digiratus, jubei and 3 others like this.
