  1. Sep 9, 2018 at 3:49 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Only 1000 than one very undergeared rig
  2. Sep 9, 2018 at 3:52 PM
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    Wiring diagram should give you the pin to look for, trace the wire then. Splice into it and boom.. kill switch
    Shouldn’t hurt anything, we disable the pump for testing things all the time at work.
  3. Sep 9, 2018 at 4:01 PM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    There was a write up on TTORA that used the blue power wire to the circuit opening relay that powers the fuel pump
    burntkat likes this.
  4. Sep 9, 2018 at 4:12 PM
    eon_blue
    Azusa, CA
    Photo dump...few more shots of the Eastern Sierras where we camped last weekend, then a couple from Gold Mountain (local 4x4 trail) yesterday
    Coyote Flats
    coyoteflats-1.jpg coyoteflats-2.jpg coyoteflats-5.jpg coyoteflats-4.jpg coyoteflats-7.jpg coyoteflats-15.jpg coyoteflats-16.jpg
    Gold Mountain 4x4 (Big Bear)
  5. Sep 9, 2018 at 5:26 PM
    License2Ill
    License2Ill Woke like a Coma Toyota Tacoma
    Ian
    It's a dry heat thou, AZ
    2004 SC'd 5VZ DC 5spd 4x4 TRD.GOV
    Bailing wire & Duct tape
    What were the temps like? I'm headed out that way early week after next..
    Dalandser and eon_blue[QUOTED] like this.
  6. Sep 9, 2018 at 5:29 PM
    License2Ill
    Ian
    Anybody run the Daystar greaseable front eyelet leaf bolt/bushings for a few years? Happy? Not happy?
  7. Sep 9, 2018 at 5:31 PM
    Sebz13
    Sebz13 appy polly loggies
    Shane
    Maui Hawaii
    03 Reg Cab, 99 3 Link SC ext cab.
    a dropped one and a high one
    solidified my choice in purple.
    BThorson[QUOTED] and HCFab like this.
  8. Sep 9, 2018 at 5:50 PM
    KeptOnChooglin
    KeptOnChooglin Well-Known Member
    Phil
    Houston, TX
    2003 Crew Cab PreRunner L4 Auto
    OK, I went with the Amazon replacement part, which looks identical in about all respects to the OEM. OEM was in the 85+ range.
    https://smile.amazon.com/gp/product/B00C7Y3MW0/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1
    The old OEM latch. To remove I used a pliers to snap the black plastic clips that retain the latching rod/linkcable ends.
    The new latch, not installed. Gently use a pliers to compress the end of the plastic clips that slip into the metal rotating part of the mechanism. Pull them up and out. You can not easily connect them to the rods otherwise. Snap them onto the end of the rod/link/cable and rotate so the end goes through. Then gently use the pliers to snap/push them down into the mechanism and seat them.
    The new latch, installed. About 10-20 minutes work.
  9. Sep 9, 2018 at 6:24 PM
    eon_blue
    Azusa, CA
    It was on the warm side during the day (low 80s) but being at that elevation (11k ft +) it would get cool pretty quickly, not to mention the wind...which we didn't have too much of when we were up there.
    Nighttime got pretty cold as you can imagine, not cold enough to freeze or snow but was probably in the low 40s or so.
    I put those in with my All Pro Expo leafs (main eyes), they're great so far but it's only been a little over a month. I use lithium grease via a grease gun and it helps keep the main eye bushings from squeaking
  10. Sep 9, 2018 at 8:26 PM
    Empty_Lord
    Dan
    That would work as well. Same concept. Kills the circuit.
  11. Sep 9, 2018 at 9:23 PM
    El Taco Diablo
    El Taco Diablo Professional Pinstriper
    Matt - KN6DZP
    Hughson, CA
    Impulse Red DC, 5vz-fe, 4wd swap, LT, dual case, F/R locked
    Just 3 tons of fun!!!
    Another Mod Day in the 209.
    We fitted @roguegs Tonneau cover around his RTT rack. @510to209Taco did his ECGS bushing. @CalTacoma09 installed bed stiffeners, replaced his battery terminals, and @foxrcing07 was able to diagnose his rear locker problem. We checked out @Sharkfrog projector headlights and think we nailed down the problem. @sd1uh8as stopped by to bring some TW express parts. And @Pella stopped by to say hi.
    The only thing that was done to a 1st gen is I installed some 1.25 Spidertrax... that @sd1uh8as brought over for me.
  12. Sep 9, 2018 at 9:50 PM
    roguegs
    roguegs Well-Known Member
    Angelo
    V8 T4R
    Went from 3rd Gen Taco to 3GT4R to 2nd Gen Taco and finally a V8 4GT4R.
    When the fck did you go across the street lol
  13. Sep 9, 2018 at 9:55 PM
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    Lmao! I was movin and shakin :thumbsup:
  14. Sep 9, 2018 at 10:04 PM
    Prayn4surf
    Prayn4surf 20 minutes late
    Socal
    2004 Tacoma xtra cab
    So much fun, gotta do that again soon man!
    Good call on Jack Ryan, probably watch the whole season tonight lol
    jubei, eon_blue[QUOTED] and Dan8906 like this.
  15. Sep 9, 2018 at 10:05 PM
    Dan8906
    Dan8906 Well-Known Member
    Daniel
    Concord, California
    2004 Tacoma ext cab TRD 4x4
    CBI sliders, ADS extend travel with compression adjuster coil overs, 9” Bilstein 5125 rear shocks, Icon Tubular UCA, Alcan custom leafs, All Pro Apex bumper and skids, NWTI rear diy bumper, 295/70/17 Cooper St Maxxs and nitro 4.88s.
    It’s a pretty good show!
    Prayn4surf[QUOTED] likes this.
  16. Sep 9, 2018 at 10:12 PM
    eon_blue
    Azusa, CA
    Haha yeah I finished it in 2 nights
  17. Sep 10, 2018 at 6:39 AM
    Keep on Truckin'
    Keep on Truckin' Well-Known Member
    Jarvis
    Indiana
    02 Imp. Red - Ext. Cab SR5 4x4- 2.7- Auto
    Rear Locker, TRD Alloy Wheels & Cooper AT3 Tires, Camper Shell ,, K&N ,Icon AALS
    I've been watching "Ozark", 1st season, what a great show!
    TacoYankee likes this.
  18. Sep 10, 2018 at 7:22 AM
    pcm
    pcm Well-Known Member
    New clutch in September 2017, heavy duty, aisin. Had to have it removed due to the defective clutch. I bought it through rock auto. Had pay for the part again, then credit when they received the original. Had to pay twice for repair. The second clutch is going bad again, it'll be less than 9 months since the second replaced. No one from rock auto will pay for the repair cost, AGAIN!
  19. Sep 10, 2018 at 7:45 AM
    chrispchicken9
    chrispchicken9 Well-Known Member
    '04 3.4 tacoma, '16 4.0 4runner
    I use the weathertech as well , running the heater on high to the floor helps too :)
  20. Sep 10, 2018 at 8:24 AM
    eon_blue
    Azusa, CA
    Are you getting it installed by the same place? I had a heavy duty clutch that got installed backward by some shop and was toast in a matter of days.
    Also keep in mind it's especially important with heavy clutches that they get broken in properly (easy driving for the 1st 500 miles or so) or else they do fall prematurely.
