  1. Sep 10, 2018 at 2:16 PM
    Brake Weight
    Brake Weight But it hasn't rained in weeks...I'll make it.
    Deep South near the Third Coast
    Taco pulling 33s and a B6 pushing 33psi
    Weld on sliders, fiberglass shell, 12k winch in an Elite Offroad bumper, front Aussie Lunchbox
    Cursed RockAuto, and my truck again.
    That doesn’t match either. But at least both my passengers and me can get out without digging around in the door card.
    SwampYota and FLBAdrian like this.
  2. Sep 10, 2018 at 2:39 PM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    I have some door handles. You need brown?
  3. Sep 10, 2018 at 2:54 PM
    Brake Weight
    It’s all good. She’s no where near a show truck anymore. I can’t believe both handles broke within days of each other.
  4. Sep 10, 2018 at 2:59 PM
    License2Ill
    License2Ill Woke like a Coma Toyota Tacoma
    Ian
    It's a dry heat thou, AZ
    2004 SC'd 5VZ DC 5spd 4x4 TRD.GOV
    Bailing wire & Duct tape
    Bump
    Nobody has been running them long term?
  5. Sep 10, 2018 at 3:01 PM
    eon_blue
    Azusa, CA
    I think @se7enine is running them...he was giving me some advice on them awhile back before I bought my set. He might just be using the bolts though and not the bushings, he was kind enough to send me the bushings he didn't use. But he might have some input
    License2Ill[QUOTED] likes this.
  6. Sep 10, 2018 at 3:27 PM
    KeptOnChooglin
    KeptOnChooglin Well-Known Member
    Phil
    Houston, TX
    2003 Crew Cab PreRunner L4 Auto
    I went Iridium a month ago.
    I did go for the dialectric and used it on both the plug top boot/coil contact point and also the top of the coil where the wire clips in.
  7. Sep 10, 2018 at 3:53 PM
    jubei
    jubei would rather be doing something else
    NoCo
    White 2002 XC TRD and Yellow 1971 JEEP CJ5
    Stuff. Also things.
    I’ve got them, but like @eon_blue , I’ve only been running them for a couple months.
    License2Ill[QUOTED] and eon_blue like this.
  8. Sep 10, 2018 at 3:58 PM
    Brake Weight
    Oh. I ordered a LuK clutch kit and Timken front and rear main seals. Looking at just pulling the motor/tranny next month and knock that out along with some bay cleaning. Creeping on a mild turbo, too.
    Adude likes this.
  9. Sep 10, 2018 at 4:08 PM
    License2Ill
    Ian
    Thank you.
    I've been running the Wheeler's ES stock leaf poly bushings in my Dakar's front eyelet: Used only the initial ES grease on install and got 3 yr/20K+ out of them without a squawk. That's a pretty decent run. I'll probably get 10K more miles out of them before they'll be looked at for replacing. Probably of gotten 40K if I bi-annually lubed them. Maybe more...
    Using a bottle jack to force down the eyelet to get access to manually lube the bushings isn't really any fun...
    So definitely interested how these things hold up. Didn't someone snap off their zerk?
  10. Sep 10, 2018 at 4:38 PM
    TacoYankee
    TacoYankee Well-Known Member
    Spotsylvania, VA
    2024 Trailhunter
    I replaced my boots after doing the wires and plugs, didn’t know the were replaceable. Noticed it ran much better after replacing the boots. Got a set of Densos from Amazon for $30.
    Lux[QUOTED] likes this.
  11. Sep 10, 2018 at 5:25 PM
    Prayn4surf
    Prayn4surf 20 minutes late
    Socal
    2004 Tacoma xtra cab
    E7E1C426-7ABF-413F-970E-52F8C0DF6FF3.jpg 88B350DD-44A3-4B95-9F5B-3E42EABAB4F6.jpg
    Took these puppies off. Time to open em up and change the stack n make em ext travel. Will see if this helps the excessive rebound.
  12. Sep 10, 2018 at 5:51 PM
    lukester78
    lukester78 Well-Known Member
    Luke
    97 Tacoma Single Cab 4x4
    I remember that, I think it was just pressed in and popped out on greasing? Wish I remember who that happened to. I have a set of these bolts that haven't made it on the truck yet, I'll check if the zerk is pressed or threaded.
    FWIW, I snapped a threaded zerk in the greasable shackle bolts, got a replacement from Ace Hardware and didn't overtighten any of the others.
  13. Sep 10, 2018 at 5:53 PM
    SilverGhost
    SilverGhost Well-Known Member
    RayRay
    Reunion, Co
    02,03 some 04, it's complicated
    #junkyardparts
    Yesterday and today. Added some JL C5-650 speakers. Had to fab up mounts for them.
    SwampYota, zero4, HCFab and 1 other person like this.
  14. Sep 10, 2018 at 6:06 PM
    License2Ill
    Ian
    To much rebound dampering? Or too much rebound?
  15. Sep 10, 2018 at 6:11 PM
    Lux
    Lux @jamesgrouss
    James
    NJ
    2001 tacoma sr5 4x4
    OME 3" lift 881 coils, Dakar's 33" General Grabber AT2's TG low profile front bumper
    do you have a link? Cant seem to find them. Whats the official name? coil on plug boot?
  16. Sep 10, 2018 at 6:25 PM
    HCFab
    HCFab Hudson Custom Fabrication
    Zach
    Central Idaho
    Overland 04' v6 4x4 5spd Xtracab, Lunar Mist.
    I put a E13-010103 Compass RV mirror in today and wired it up through a Add-A-Circut tap. I had to fab up an aluminum bracket to get it mounted towards the windshield due to it being a windshield mount mirror. I'm very happy with the result.
    My only issue is I cant seem to get the temperature to work only the compass?
    There is no user manual found online anywhere...
    The original mirror bracket fits over the compass PCB l think it was made for it...
    These little taps are so useful! I'll be hard wiring my dash cam next.
    SwampYota, License2Ill and zero4 like this.
  17. Sep 10, 2018 at 6:36 PM
    Prayn4surf
    Socal
    Too much rebound not enough dampering
  18. Sep 10, 2018 at 7:06 PM
    License2Ill
    Ian
    Yeah I had to do the same. I did 15% more rebound. I should of done 20% (ARB/Winch/steel IFS skid).
    Prayn4surf likes this.
  19. Sep 10, 2018 at 7:17 PM
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
    Donahoe CO, Donahoe Rear Resi, Deaver J59, 16" Pro Comp, 33" BFG AT, Hayden Trans Oil Cooler, Oil Filter Relocator, FM 40, ES Bushings, Beefed CB Drop, Deckplate, K&N Drop-In, DO Bed Bar, Cobra 75 WXST, Firestik Firefly, Philips D1R, Clarion Remote Start, Husky Liners
    On mine they are pressed in also, the zerk body is round, no hex for a wrench or socket. Mine are only a month old though, have only greased them once. If they do pop out I'll tap threads & install threaded zerks like the shackles have.
    Wish I saw that post before I put mine on, I would have tapped them before putting them on.
    License2Ill likes this.
  20. Sep 10, 2018 at 9:01 PM
    Dan8906
    Dan8906 Well-Known Member
    Daniel
    Concord, California
    2004 Tacoma ext cab TRD 4x4
    CBI sliders, ADS extend travel with compression adjuster coil overs, 9” Bilstein 5125 rear shocks, Icon Tubular UCA, Alcan custom leafs, All Pro Apex bumper and skids, NWTI rear diy bumper, 295/70/17 Cooper St Maxxs and nitro 4.88s.
    Let me know if it helps! Since we have the same setup
