  1. Sep 12, 2018 at 6:31 AM
    cynicalrider
    cynicalrider #NFG
    Jersey
    That's a good idea. Wish I did that when I replaced mine lol
  2. Sep 12, 2018 at 6:40 AM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    That's right. That makes sense. Because I was looking for a wire that lit up for switches. So use the ashtray one for that.
  3. Sep 12, 2018 at 8:58 AM
    presto
    presto Well-Known Member
    Topher
    san francisco
    2000 T4R 4x4
    Fully armored on 33’s
    Is the front diff fill plug and drain plug the same part number?
  4. Sep 12, 2018 at 9:09 AM
    eon_blue
    Azusa, CA
    Are you looking for a fuse to tap into that comes on/off with the truck? When I was installing my AFR gauge, I piggybacked off the gauge cluster fuse...so it comes on whenever I turn the key and off when I take it out.
  5. Sep 12, 2018 at 9:15 AM
    SilverGhost
    SilverGhost Well-Known Member
    RayRay
    Reunion, Co
    02,03 some 04, it's complicated
    #junkyardparts
    Kind of. But I don’t want to tie onto something that is being used that can come on with theACC. I don’t want any interference in the circuit. It’s for my TWK 88 DSP. I don’t use those lines so it’s a free line to tap onto.
    eon_blue[QUOTED] likes this.
  6. Sep 12, 2018 at 9:45 AM
    Prayn4surf
    Prayn4surf 20 minutes late
    Socal
    2004 Tacoma xtra cab
    presto[QUOTED] likes this.
  7. Sep 12, 2018 at 9:52 AM
    presto
    Topher
    san francisco
    2000 T4R 4x4
    Prayn4surf[QUOTED] likes this.
  8. Sep 12, 2018 at 9:54 AM
    Prayn4surf
    Socal
    You can always call the parts dept at a stealership n they will give you the parts numbers. Dont forget to buy the gaskets :thumbsup:
  9. Sep 12, 2018 at 9:54 AM
    Dan8906
    Dan8906 Well-Known Member
    Daniel
    Concord, California
    2004 Tacoma ext cab TRD 4x4
    CBI sliders, ADS extend travel with compression adjuster coil overs, 9” Bilstein 5125 rear shocks, Icon Tubular UCA, Alcan custom leafs, All Pro Apex bumper and skids, NWTI rear diy bumper, 295/70/17 Cooper St Maxxs and nitro 4.88s.
    so i noticed the switch for my reverse light switch is illuminated when the truck is off, should I be concerned that it will kill my battery? Id think that small LED wont do much.
  10. Sep 12, 2018 at 9:55 AM
    El Taco Diablo
    El Taco Diablo Professional Pinstriper
    Matt - KN6DZP
    Hughson, CA
    Impulse Red DC, 5vz-fe, 4wd swap, LT, dual case, F/R locked
    Just 3 tons of fun!!!
    Totally missed that when I checked the ash tray light last night. I always just leave my lights in the ON position. So my quick check showed it off with truck off, and on with truck >AND< lights on.
    SilverGhost[QUOTED] likes this.
  11. Sep 12, 2018 at 10:00 AM
    Matic
    Matic The "OFG" Baby!!!
    Tricky Dick
    Easley, SC
    1 owner 2002 TRD, SR5, DC, 2.7. Full OME suspension, STT pro's.
    OME 881 coils with OME nitrochargers shocks up front. TC UCA's OME Dakars with extra leaf in the rear. Warn 8000 winch with 80ft custom braided synth line. Custom 60ft synth extension. All pro tube bumper, Hi-lift jack, Safari Snorkel, Wilco tiregate. 2019 Jeep JLUR.
    Got a great detail last friday.
    I know....pretty boring.
  12. Sep 12, 2018 at 10:22 AM
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
    Quick opinion. So my LBJ bolts where kinda FUBAR'd (from having to remove them so many times) and one was on the verge of being stripped. I'm obviously going to replace them, but should I go to ACE and get the correct length/pitch etc. (cheaper option/quicker) or go with OEM bolts from Toyota (more expensive)
    presto likes this.
  13. Sep 12, 2018 at 10:25 AM
    Phessor
    Phessor Well-Known Member
    That is a good looking rig!
    Matic[QUOTED] likes this.
  14. Sep 12, 2018 at 10:26 AM
    Phessor
    I would think an appropriate grade replacement bolt would be just fine.
    burntkat, drr and BYJOSHCOOK[QUOTED] like this.
  15. Sep 12, 2018 at 10:28 AM
    presto
    Topher
    san francisco
    2000 T4R 4x4
    If you can find them at Ace I’m sure it would be fine just make sure you get like grade 8 bolts?
    BYJOSHCOOK[QUOTED] likes this.
  16. Sep 12, 2018 at 10:32 AM
    BYJOSHCOOK
    Josh
    Check Out My Builds
    Yeah that's what I was planning on getting anyways is Grade 8 :thumbsup:
  17. Sep 12, 2018 at 10:34 AM
    eon_blue
    Azusa, CA
    the Toyota ones can't be that expensive, they are just bolts after all. Get them from Toyota
    I went into Napa once to get LBJ bolts when I picked up my spare CV axle and they told me that they don't sell the right quality bolts for that kind of hardware, and that I needed to go to Toyota. I wouldn't expect Ace to be any different.
    m3bassman likes this.
  18. Sep 12, 2018 at 11:17 AM
    drr
    drr Primary Prognosticator
    Dan
    Seattle-ish
    02 4WD Tacoma
    Be hard to find Gr. 8 in metric :p
    You’re looking for Gr. 10.9 M10 x 1.25, 35mm long. You can buy them from a hardware store for $0.75 each, or from Toyota for $2 each. They are exactly the same.
  19. Sep 12, 2018 at 11:19 AM
    eon_blue
    Azusa, CA
    Maybe the Napa I went to just didn't stock them but it made me wary of buying them anywhere but Toyota...but this is good to know.
  20. Sep 12, 2018 at 11:33 AM
    drr
    Dan
    Seattle-ish
    02 4WD Tacoma
    Yeah not everywhere has a good metric selection. You can get them on McMaster for $6 for a 10 pack. I believe the ones I use are P/N 95735A635
    burntkat and eon_blue[QUOTED] like this.
