  1. Sep 12, 2018 at 8:03 PM
    bodhi armor
    bodhi armor 02’ Dbl Cab- "The Luck Dragon"
    Joshua
    East TX
    2002 4x4 Dbl Cab Jade Green
    Nice! Thanks for the tip
  2. Sep 12, 2018 at 8:49 PM
    Prayn4surf
    Prayn4surf 20 minutes late
    Socal
    2004 Tacoma xtra cab
    Awesome! Glad you decided to do it yourself.
    burntkat likes this.
  3. Sep 12, 2018 at 9:10 PM
    Prayn4surf
    Socal
    Awesome! You’ll have that service on lock down afterwards.
    m3bassman[QUOTED] likes this.
  4. Sep 12, 2018 at 9:12 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Sounds like a pulley bearing or something external is loose.
  5. Sep 12, 2018 at 9:35 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    The B.S. Auto Repair Group
    You need a sign.
  6. Sep 12, 2018 at 9:48 PM
    JKO1998
    Utah
    I tried to be more creative but I took some sleepy meds and my brain isn’t 100% I don’t think.
  7. Sep 12, 2018 at 9:53 PM
    JKO1998
    Utah
    You make/ design signs?
    Something along that maybe.
  8. Sep 12, 2018 at 10:01 PM
    Shortman5
    Shortman5 Well-Known Member
    Supercharged TRD
    TRD S/C, ADS coilovers.
    It deffinelty comes from the bottom end. I’m gonna check the flex plate torque converter bolts tomorrow. I read on another forum some guy had intermittent ticking in drive like me and it was the loose bolts. Just gotta be sure not to over tighten.
    Still planning on changing the main bearings at some point and checking for play on the rod bearings. But I was told I could possibly warp the main seals since the main cap on the 5VZ is one piece with all the internal weight being on them. Hopefully that’ll make my crank run true.
  9. Sep 13, 2018 at 12:53 AM
    Sebz13
    Sebz13 appy polly loggies
    Shane
    Maui Hawaii
    03 Reg Cab, 99 3 Link SC ext cab.
    a dropped one and a high one
    Anyone have a link to the guide for the shift seat swap? I remember seeing it and can't find it again.
  10. Sep 13, 2018 at 3:38 AM
    burntkat
    burntkat Well-Known Member
    Phillip
    Charleston, SC
    97 Extracab Tacoma
    This will work. The problem with flushing (this isn't really a flush, BTW) is that it's done with a machine, and quite often it's done backwards- blowing crap INTO the transmission where it had been settled into a harmless corner.
    I have had much better luck using an external, inline filter. Magnafine are excellent filters, and they have both a magnetic filter and a fine filter medium- as well as a bypass valve- so if you forget about it, or it plugs up, they freeflow and save the transmission (so long as they are installed in the proper direction).
    The place you want to install them is on the return line from the steering gear, or the transmission cooler (both are hydraulic systems, so the filter is equally applicable to them). I have actually had transmissions that wouldn't shift , shift better than ever after application of one of these.
    As for getting all the fluid out- short of a drain plug on the torque converter, or removing it from the system and emptying it- the method above is one way to do it. Another is to drop the fluid in the pan, refill. Then do this 3 times more within 500 miles or so, and you have got approx 95% of the fluid changed out. Better yet- put the filter I spoke of, in while you are doing this. You will be amazed the difference it makes.
  11. Sep 13, 2018 at 4:00 AM
    Sebz13
    Shane
    Maui Hawaii
  12. Sep 13, 2018 at 6:50 AM
    pairodice
    pairodice Well-Known Member
    Jay
    SF NM
    02 DCSB prerunner 4x4 manual
    Ive had 2 on different trucks, no complaints other than they are a bitch to install when you have to burn or cut the old bushings out
    License2Ill[QUOTED] likes this.
  13. Sep 13, 2018 at 7:05 AM
    Blue92
    Blue92 Well-Known Member
    Daniel
    North Carolina
    2018 Sport
    I hope yours goes easier than mine did. The rubber on mine bunched up under the spring and didnt let me push down far enough on the shifter cap. Cussed and threw tools at it for 2 hours until I succumbed to taking it to the dealer. Its always the easy jobs that end up screwing me over.
    Running Board Man likes this.
  14. Sep 13, 2018 at 8:22 AM
    License2Ill
    License2Ill Woke like a Coma Toyota Tacoma
    Ian
    It's a dry heat thou, AZ
    2004 SC'd 5VZ DC 5spd 4x4 TRD.GOV
    Bailing wire & Duct tape
    Okay cool. Yeah, I burned out those bushings long ago, wasn't any fun.
  15. Sep 13, 2018 at 9:37 AM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    I’m having trouble finding gear, the positions are a little vague. The shifter bushing can be causing this right?
  16. Sep 13, 2018 at 9:39 AM
    BartMaster1234
    Tyler
    Flux Capacitor
    Yes... what else would it be? I have a feeling that shifter bushing with 450k is original.
  17. Sep 13, 2018 at 9:42 AM
    eon_blue
    Azusa, CA
  18. Sep 13, 2018 at 9:44 AM
    Blue92
    Daniel
    North Carolina
    2018 Sport
    For a manual trans, yeah. Get a new seat and bushing from marlin crawler.
  19. Sep 13, 2018 at 9:45 AM
    BartMaster1234
    Tyler
    Flux Capacitor
    No idea. I just know it has trouble finding gear.
  20. Sep 13, 2018 at 9:47 AM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Its the company truck
    Its super easy to swap out
