  1. Sep 24, 2018 at 11:00 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    At least it is still positive, many go negative. Somehow my stock arms still get 2 degrees positive with my level of lift
  2. Sep 24, 2018 at 11:01 PM
    turbodb
    turbodb AdventureTaco
    Dan
    PNW
    2000 Tacoma Xcab 4x4 SR5 V6 TRD
    AdventureTaco
    I've never driven any other way, so I don't know the difference. Perhaps once the new UCA's are installed...
    Looks like the spec is 1.42 +/-.75 for my model number (VZN170L). Thanks for the thought to look in the FSM, never thought to look this up. :thumbsup:
  3. Sep 24, 2018 at 11:03 PM
    Speedytech7
    The level of lift really affects the feel because of the angles the TRE have to be at, stock 1.42 might be bueno, but lifted it's def not great.
    Digiratus and turbodb[QUOTED] like this.
  4. Sep 24, 2018 at 11:03 PM
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
    Donahoe CO, Donahoe Rear Resi, Deaver J59, 16" Pro Comp, 33" BFG AT, Hayden Trans Oil Cooler, Oil Filter Relocator, FM 40, ES Bushings, Beefed CB Drop, Deckplate, K&N Drop-In, DO Bed Bar, Cobra 75 WXST, Firestik Firefly, Philips D1R, Clarion Remote Start, Husky Liners
    @turbodb
    Looking at your sheet again, something doesn't seem right. When anything is out of spec it would show red. On your sheet for caster it says the range is 0.7-2.2. Maybe the specs are different for pre-2001?
    Edit: Just saw your post above, ya beat me to it. Didn't expect caster spec to be that much different from 01up. As long as it drives fine shouldn't matter.
    turbodb likes this.
  5. Sep 24, 2018 at 11:08 PM
    turbodb
    Dan
    PNW
    AdventureTaco
    Yeah, but remember, I'm barely lifted, so... But still, I hear from everyone that I want to be higher, so I'll probably at least give it a try when I do the new suspension. Plus, by moving the front forward (which increases camber), I might get the tire out of the rear of the well and flare a bit.
    :fingerscrossed:
    :thumbsup:
    Speedytech7[QUOTED] likes this.
  6. Sep 24, 2018 at 11:11 PM
    Speedytech7
    I don't like being super tall for a number of reasons, but a certain amount is necessary to have good uptravel for comfort on dirt roads and to keep the underbelly off things. I think after 4 years I finally found that sweet spot on mine, and I bet you're close too but with your skid hanging so low maybe 3/4 to 1" is what's required.
  7. Sep 25, 2018 at 6:17 AM
    cynicalrider
    cynicalrider #NFG
    Jersey
    God I wish. Sadly no RT for me this year and probably won't be able to do another trip like that for 5-7 years. Next "bigger" trip will probably be 5 days in NH, and next BIG trip will be the Alpine loop and other glorious trails CO has to offer.
    But no, haven't had AC for 3 years now and now that I am taking my pup on trips with me I don't want her getting too hot in the truck. Of course I am fixing it as summer ends but better late than never. Literally replacing everything in the system but two lines.
  8. Sep 25, 2018 at 6:24 AM
    onakat
    onakat Well-Known Member
    Canada
    2000 indestructaco!
    here you go. Only three weeks old, so I have to bottle feed them every few hours. They are just starting to eat a little bit of canned wet kitten food. They are in good hands with me :thumbsup:
    Someone abandoned them in the bed of my truck on early sunday morning or on saturday night, I don't know for sure
  9. Sep 25, 2018 at 7:05 AM
    drr
    drr Primary Prognosticator
    Dan
    Seattle-ish
    02 4WD Tacoma
    That's a good point, could very well be where your alignment is set at. Now I'm curious where mine land - may have to think about welding a strike plate in there to prevent this.
    The truck that just works despite itself. 2.7, but plenty of power. Icons, but rides soft and cushy. Ideal camber even with stock arms.
    I think you've reached shitheap nirvana.
  10. Sep 25, 2018 at 7:08 AM
    TacoYankee
    TacoYankee Well-Known Member
    Spotsylvania, VA
    2024 Trailhunter
    Anyone who had their 01-04 frame coated by Toyota during the frame campaign have it reapplied by Toyota during a subsequent inspection? Is so, info please. Just dropped off mine for inspection, I couldn’t find and holes when I looked at it, but loads of corrosion and scaling. Dealer says the frame treatment is a one time deal...
  11. Sep 25, 2018 at 7:19 AM
    eon_blue
    Azusa, CA
    I got my bearings from Wheelers You have to ask them for the circlips separately when you order, they're an extra $4 for both
    zero4[QUOTED] likes this.
  12. Sep 25, 2018 at 7:19 AM
    ThunderOne
    ThunderOne Well-Known Member
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    Damn, I should have gone with the 95-00, oh well. Yeah, the letters had a paper backing across the back adhesive, and then a clear layer stuck to the front to hold the letters together. The paper backing comes off easier than the clear wrapping material.
  13. Sep 25, 2018 at 7:35 AM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    except that arms add caster not camber, which is pushing the top part of the spindle BACK which means it goes into the firewall more...
    So..yeah
    Likely rub more if anything.
    Which is why the Solo stock length arms move the bottom forward 1'' so that you offset this issue a bit and still get a lot of positive castor out of them.
    turbodb[QUOTED] likes this.
  14. Sep 25, 2018 at 8:13 AM
    TacoSauce04
    TacoSauce04 Well-Known Member
    David
    2004 Lunar Mist SR5 TRD Double Cab 4x4 Tow Package
    ARE Shell
    My buddy and I are planning my first road trip since i bought my truck a little over a year ago. 10day trip from Houston. We are planning to drive our first gens up through New Mexico into Durango to Moab through the Black Canyon to Rocky Mtn National Park then to Colorado Springs and finally to Great Sandunes. Any good trail recommendation, camp sites, sites to see or tips along the way? PM if you do, thanks!
  15. Sep 25, 2018 at 8:42 AM
    turbodb
    Dan
    PNW
    AdventureTaco
    Well shit. I even tried looking it up to make sure I was right.
    Therefore, I wish I could un-like this post, given it's implications. But I can't, so I'll just click "like."
    Anyway, it's probably just you, always bringing the bad news. Soon you'll say something like: "Might as well go 35's since you're going to need to do a bunch more clearancing anyway." :luvya:
    Thanks for clearing things up for me though, seriously.
  16. Sep 25, 2018 at 8:45 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Don't forget LT and a supercharger :luvya:
    :D
  17. Sep 25, 2018 at 8:46 AM
    turbodb
    Dan
    PNW
    AdventureTaco
    Well, I mean naturally - you need those things to turn the 35's. Speaking of which, you forgot the GFC - another necessity of LT'ed 35's.
  18. Sep 25, 2018 at 8:48 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Lockers, 5.29s, and crawl box.
    No skids though.
    Don't need that weight at the mall.
  19. Sep 25, 2018 at 8:50 AM
    turbodb
    Dan
    PNW
    AdventureTaco
    What did you say? Couldn't hear you up here.
  20. Sep 25, 2018 at 8:51 AM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    And a linked rear and roll cage
