  1. Sep 25, 2018 at 9:05 AM
    JKO1998
    JKO1998 Well-Known Member
    Utah
  2. Sep 25, 2018 at 9:21 AM
    mechanicjon
    mechanicjon They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
    You need the 6 rib to line the belt up. 1/4 spacer goes behind. Theres two differant pulleys. You need the thicker one on the right.20180418_233039.jpg 20180419_201508.jpg
    SwampYota and FLBAdrian like this.
  3. Sep 25, 2018 at 9:31 AM
    chowwwww
    chowwwww Well-Known Member
    Orange County
    03 Doublecab 4x4
    Billys 5100/Eibach and Wheelers Progressive 1.5 AAL with overload in
    I have SPC UCAs. My tires are rubbing the rear a bit when stuffed even after the pinch weld cut and hammering. Ive read and been told that getting more positive caster will provide me a little more clearance from the firewall. If this is correct, would it be better to adjust caster from the UCA or see if I can do it form the LCA? UCA would be easier to adjust.
  4. Sep 25, 2018 at 9:35 AM
    SnowroxKT
    SnowroxKT Well-Known Member
    Kyle
    Anchorage Alaska
    2008 TRD OR
    more positive caster = more cab rubbing
  5. Sep 25, 2018 at 9:37 AM
    chowwwww
    Orange County
    03 Doublecab 4x4
    Hmm, I really confused on how this works now. I though adding positive caster would move my wheel forward more? Guess maybe ill just add more hammering.
  6. Sep 25, 2018 at 9:42 AM
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
    Donahoe CO, Donahoe Rear Resi, Deaver J59, 16" Pro Comp, 33" BFG AT, Hayden Trans Oil Cooler, Oil Filter Relocator, FM 40, ES Bushings, Beefed CB Drop, Deckplate, K&N Drop-In, DO Bed Bar, Cobra 75 WXST, Firestik Firefly, Philips D1R, Clarion Remote Start, Husky Liners
    Yup it's true assuming you guys are talking about UCAs. Aftermarket UCAs give more caster by moving the top of the spindle back. But it does nothing for helping rubbing on the cab, if anything makes it a bit worse.
    When people talk about adding caster to give more clearance for rubbing it's moving the LCA forward. With stock UCAs I never had a rubbing issue. When I mean no rubbing I mean on the street. 285s, no hammering, nothing cut, not even my fender liners. When I got aftermarket UCAs I started rubbing, had to increase caster at the LCA to get back to no rubbing like when I had stock UCAs.
    chowwwww likes this.
  7. Sep 25, 2018 at 9:44 AM
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
    I just posted above but it depends on how you are adding caster. Adding caster at the LCA provides more clearance for the cab. Adding caster at the UCA does not.
  8. Sep 25, 2018 at 9:57 AM
    chowwwww
    Orange County
    03 Doublecab 4x4
    Thanks! I will add more to the LCA.
    zero4[QUOTED] likes this.
  9. Sep 25, 2018 at 9:59 AM
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
    If you have SPCs & rubbing issues, I think what some guys do is max out caster at the LCA without throwing camber out of spec, then make final adjustments on the SPCs. I'm not for sure though, check with SPC guys to make sure.
    chowwwww[QUOTED] likes this.
  10. Sep 25, 2018 at 10:24 AM
    cynicalrider
    cynicalrider #NFG
    Jersey
    I hope you are looking with a screw driver and not your eyes. I tapped my frame with a screw driver and it went right through. But yes it is a one time coating, and you have till 2019 to find a hole to get yourself a new frame.
  11. Sep 25, 2018 at 11:09 AM
    Blue92
    Blue92 Well-Known Member
    Daniel
    North Carolina
    2018 Sport
    Sprayed all the dirty white lithium grease out of my leaf packs with brake clean and a garden hose. Bought some generic dry lube to try instead. Heres hoping it will last longer than 2 weeks.
    eon_blue likes this.
  12. Sep 25, 2018 at 11:12 AM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Good luck, I've never had squeaky leafs, but it seems how they're painted is the most important thing. Lubes don't last, PTFE would be the best bet for a couple of months
  13. Sep 25, 2018 at 11:19 AM
    Blue92
    Daniel
    North Carolina
    2018 Sport
    The liquid wrench I got says it has PTFE in it. Don't ever buy cheap sub $400 leafs. The day I start working full time in a few years, provided I still have the truck, I'm buying some Alcans. What I really want are a pair of Wheelers 3 packs, which they don't sell anymore. But I understand Alcan can still make them.
    Dan8906 likes this.
  14. Sep 25, 2018 at 4:53 PM
    HCFab
    HCFab Hudson Custom Fabrication
    Zach
    Central Idaho
    Overland 04' v6 4x4 5spd Xtracab, Lunar Mist.
    When raining/muddy I have almost slipped and busted my ass while climbing in the bed so thought some skateboard grip tape on my rear bumper will help with better footing.
    Randomly popped in my head at work today, never seen it done before on a rear bumper, only sliders. I am sure this is not an original idea.
    Cuts are done freehand with a razor so they look like turd. :anonymous:
    koditten and SwampYota like this.
  15. Sep 25, 2018 at 5:29 PM
    Speedytech7
    Why you gotta keep breaking shit?
  16. Sep 25, 2018 at 5:40 PM
    Speedytech7
    I think Toyota made the right call dropping elocker actuators in favor of the electro magnet Harrop style lockers. They're just too damn fragile. Those cable actuators look better each time
    SnowroxKT likes this.
  17. Sep 25, 2018 at 5:53 PM
    License2Ill
    License2Ill Woke like a Coma Toyota Tacoma
    Ian
    It's a dry heat thou, AZ
    2004 SC'd 5VZ DC 5spd 4x4 TRD.GOV
    Bailing wire & Duct tape
    Womp womp.
    Backed into a twig of a tree going .02 mph on flat ground and it appears my CBI swing out is manufactured of pot- metal.
    SnowroxKT and SwampYota like this.
  18. Sep 25, 2018 at 5:58 PM
    eon_blue
    Azusa, CA
    Hey @zero4 which firestone in Northridge do you take your truck to for alignments?
    I need to get one before I go on a road trip Thursday and want to use my lifetime package but the one in Pasadena sucks...I remember you saying the one you go to is good? There's 3 in Northridge that I'm seeing online though
  19. Sep 25, 2018 at 6:03 PM
    JKO1998
    Utah
    They come in 3’s.
  20. Sep 25, 2018 at 6:04 PM
    Speedytech7
    My LC tires each have something in the tread. They don't leak so I've just been leaving it. All of my Michelin tires have been magnets for road hazards haha, but they never leak when something gets in them. Those tires you have look pretty tired tho anyway
