  1. Sep 26, 2018 at 6:59 AM
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    Ughh. I need to do the bushings on my rack.
    BYJOSHCOOK[QUOTED] likes this.
  2. Sep 26, 2018 at 7:34 AM
    burntkat
    burntkat Well-Known Member
    Phillip
    Charleston, SC
    97 Extracab Tacoma
    I didn't know they were remaking The A-Team....
    Pilot0527[QUOTED] likes this.
  3. Sep 26, 2018 at 7:38 AM
    burntkat
    Phillip
    Charleston, SC
    97 Extracab Tacoma
    Each their own. Personally I hate chrome. I wish I could find an antenna spring that wasn't chrome.
  4. Sep 26, 2018 at 7:38 AM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    I find I use mine way, way less than I used to. Does that mean I've become a better driver? :cookiemonster:
  5. Sep 26, 2018 at 8:03 AM
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    It means you guys need to wheel harder trails. :stirthepot:
    My elocker has worked flawlessly from day one. I don't understand how they cause constant problems for others. :notsure:
    JBTacoma likes this.
  6. Sep 26, 2018 at 8:13 AM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    Only problems I’ve had with mine are when I try and unlock it and push the ect button instead of the the locker... doesn’t work.
  7. Sep 26, 2018 at 8:16 AM
    jgill21
    jgill21 Not Technically Stock Anymore
    Jake
    Nashville
    98 2.7 TRD PreRunner
    took you long enough
  8. Sep 26, 2018 at 8:24 AM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    For a CB? Just paint it black. Shouldn’t affect performance or anything.
  9. Sep 26, 2018 at 8:29 AM
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
    Haha in my defense I had a wedding to go to on Friday thru Sunday or else it would've been done Friday. I also got my TC gussets welded up and ran into a few issues :anonymous:
    But it works now! :D
    jgill21[QUOTED] likes this.
  10. Sep 26, 2018 at 8:36 AM
    Reh5108
    Reh5108 Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    What could cause a similar whine to a power steering pump going out. I've removed the belt and still hear the noise. Is it possible that the rack itself can whine?
    BTW don't by a CVJ rack. At a year and a half old it no longer holds fluid and also the tierods couldn't handle full droop.
    Once again OEM is the only way.
  11. Sep 26, 2018 at 8:38 AM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    :rofl:
    Yes please
    Speedytech7 likes this.
  12. Sep 26, 2018 at 9:55 AM
    vonellis
    vonellis Well-Known Member
    04 DLBC x4 S/C 97 2X 04 DBLC 4X S/C
    Some and some more
    Sold some and stripping it down to the frame.
  13. Sep 26, 2018 at 10:02 AM
    eon_blue
    Azusa, CA
    My advice with Quickfists...don't use those plastic rectangular washers that come with them...they break and then the Quickfist slides off the screw and whatever it's holding onto will fly off with it. In my case, it was my axe and it flew off my truck on the freeway when I was going 75 mph. Got lucky I was in the slow lane and it landed off the side of the road.
    Use a small metal washer in its place...works much better
  14. Sep 26, 2018 at 10:25 AM
    Crawler Brennan
    Crawler Brennan Well-Known Member
    1999 Tacoma lifted with dual case gears and lockers larger tires
    2wd to 4wd, 4.7 Taco box, 3 inch lift with upper A arm and coilovers, ARB rear Spartan front 4.88 R&P, MC bumpers front + rear and sliders, 35 12.5 tires with walker evans race bead lock wheels, on board air system, lots of cutting in fenders and fire wall.
    If you are talking about the hard plastic seats for your shifter they are all made by Marlin Crawler and then sold to other shops. Marlin Crawler is working on getting lower cost shipping options also. FedEx doesn't like to ship anything for less than $12 and that's if it doesn't leave the local area its being shipped from.
    OneWheelPeel likes this.
  15. Sep 26, 2018 at 10:51 AM
    OneWheelPeel
    OneWheelPeel Well-Known Member
    Phoenix, AZ
    eon_blue[QUOTED] likes this.
  16. Sep 26, 2018 at 10:58 AM
    eon_blue
    Azusa, CA
    I got really lucky it didn't hit someone...but in hindsight it was kind of funny.
    "What was that noise??"
    * looks in rearview mirror, sees axe twirling in mid air *
    "Nothing hun...just going to...um...pull over for a minute..."
  17. Sep 26, 2018 at 11:08 AM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    I should have taken pics of the one I pulled out of the cruisers rear diff, thing was fucked. One for my transfer case locker and front locker are both pretty clean but someone def opened them and put new grease in cause Toyota doesn't use red grease
    m3bassman[QUOTED] likes this.
  18. Sep 26, 2018 at 11:21 AM
    El Taco Diablo
    El Taco Diablo Professional Pinstriper
    Matt - KN6DZP
    Hughson, CA
    Impulse Red DC, 5vz-fe, 4wd swap, LT, dual case, F/R locked
    Just 3 tons of fun!!!
    Definately! I took one look at those plastic pieces of shit and they went straight in the garbage lol.
    burntkat and eon_blue[QUOTED] like this.
  19. Sep 26, 2018 at 11:26 AM
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    :eek::rofl:
  20. Sep 26, 2018 at 11:40 AM
    Speedytech7
    I did this once when I had my bed basket, the fairing metal plate thing flew off in the cold because the loops that held it on were plastic and got too brittle in the cold. Didn't go back for it though, it was such a wind dam it flew off the side of the road and was never seen again. So no fairing until I rolled the truck haha...
    [​IMG]IMG_20170521_141340777 by Zane, on Flickr
