  1. Oct 5, 2018 at 2:20 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    I think mine were oem, and someone didn’t use loctite or something.
    Checking every once in awhile would for sure help.
  2. Oct 5, 2018 at 2:28 PM
    eon_blue
    Azusa, CA
    yeah I check mine with a torque wrench every oil change or so...60ft lbs and done. Although if one of the bolts is starting to break inside you wouldn't really know about it unless you took it off completely and inspected it closely.
    JKO1998[QUOTED] likes this.
  3. Oct 5, 2018 at 2:29 PM
    eon_blue
    Azusa, CA
    I wouldn't use red locktite on the LBJ bolts though...if you're ever on a trail and need to change out a broken CV axle you're going to have a hell of a time getting the bolts out if you put red on them. I use blue (med. strength) and it works fine.
    zero4 likes this.
  4. Oct 5, 2018 at 2:45 PM
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
    Donahoe CO, Donahoe Rear Resi, Deaver J59, 16" Pro Comp, 33" BFG AT, Hayden Trans Oil Cooler, Oil Filter Relocator, FM 40, ES Bushings, Beefed CB Drop, Deckplate, K&N Drop-In, DO Bed Bar, Cobra 75 WXST, Firestik Firefly, Philips D1R, Clarion Remote Start, Husky Liners
    I agree with @eon_blue, I wouldn't use red loctite on the LBJ bolts, it's not needed. Blue loctite is perfectly fine, I've yet to have a LBJ bolt come loose.
    Never sheared one either. Speaking of which, the photo posted above, that's not a LBJ failure in my book. Looks like the bolts came loose or sheared. I chose to use the OEM bolts rather than what comes with aftermarket LBJs & I'll replace them with new ones anytime I replace the LBJs.
    OneWheelPeel and eon_blue like this.
  5. Oct 5, 2018 at 2:59 PM
    Shortman5
    Shortman5 Well-Known Member
    Supercharged TRD
    TRD S/C, ADS coilovers.
    Red Loctite is formulated to require 300 degrees of heat to break it loose. Otherwise you’d likely break a bolt. You should only use if if you never plan on having to break it loose.
    zero4 and eon_blue like this.
  6. Oct 5, 2018 at 3:19 PM
    burntkat
    burntkat Well-Known Member
    Phillip
    Charleston, SC
    97 Extracab Tacoma
    I prefer my trucks to be durable.
    Weak ball joints is just not acceptable. I realize there are probably aftermarket its that solve the problem with new parts designed for the abuse. However, I'm not putting thousands of dollars into an IFS fix when I can fix the problem, permanently, for much less money- not to mention get a lot of the interference in access to components (oil pan, etc) out of the way.
  7. Oct 5, 2018 at 3:20 PM
    burntkat
    Phillip
    Charleston, SC
    97 Extracab Tacoma
    Red would come out fine- if you have a torch.
    Personally I only use red loctite on assemblies which won't need to come apart for the service life of the assembly- think head studs and the like.
    zero4 and eon_blue[QUOTED] like this.
  8. Oct 5, 2018 at 3:21 PM
    burntkat
    Phillip
    Charleston, SC
    97 Extracab Tacoma
    Try 500 degrees.
  9. Oct 5, 2018 at 3:22 PM
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
    They may be the weak link but if you keep an eye on them usually they'll be fine.
    Unfortuantely there are no aftermarket replacements that are designed better for strength & abuse, not for stock replacement anyway.
  10. Oct 5, 2018 at 3:26 PM
    JKO1998
    Utah
    Durable?
    People have hundreds of thousands of miles on these things and don’t have a problem, the odds of you driving down the road and a ball joint failing is low, even more so when you keep an eye on them.
  11. Oct 5, 2018 at 3:26 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    I'd just never buy a fun vehicle thats an auto. Doesn't matter for comfortable dailys tho.
  12. Oct 5, 2018 at 3:27 PM
    burntkat
    Phillip
    Charleston, SC
    97 Extracab Tacoma
    Thanks for the info. That makes the decision a bit easier.
    I agree, for most folks a SAS is extreme. I am not a rockcrawler, this truck won't be competing in TTC. I've done SAS before, I like the way they drive (let's not go there again- you like yours, I like mine- I don't need my truck to drive like a Cadillac), and I like the fact I can quite literally rebuild the engine in place (so long as it doesn't require machine work- and let's face it, not like I'm going to NOT have machine work done if I need a rebuild). I had an issue with the old motor in the Chevy, where an oil pump went out. Had the stock IFS and front drive unit been there, I'd have HAD to have removed the entire engine to get at it. As it was, I took out a couple dozen machine screws, dropped the pan, and replaced the oil pump in situ. Saved me days of work. Starter replacements were much easier, on and on.
    (if we're really being honest, I love to tinker, and can never leave a vehicle stock- this is quite likely to be the biggest reason for my going SAS. Additionally, the money I'd spend installing a good IFS lift, I'd be time and money ahead to just build it SAS. Among other things, I don't have balljoint problems with Dana 44 axles ;))
  13. Oct 5, 2018 at 3:27 PM
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
    Yup red breaks loose with heat fine but I can't think of anything on a vehicle that's not for race that would require red loctite. But for headstuds? Not something I would even think of. I've built engines using ARP studs to replace conventional head bolts & still never used any threadlocker on them. Just oil or ARP grease.
  14. Oct 5, 2018 at 3:28 PM
    burntkat
    Phillip
    Charleston, SC
    97 Extracab Tacoma
    And yet, that very thing happened to the PO of my vehicle, and he's VERY good about maintenance- former USAF Jet Engine mechanic and knows the importance of maintenance... to say nothing of the aforementioned google search.
  15. Oct 5, 2018 at 3:29 PM
    JKO1998
    Utah
    I think you’re in the wrong thread
    Newb
  16. Oct 5, 2018 at 3:30 PM
    burntkat
    Phillip
    Charleston, SC
    97 Extracab Tacoma
    It depends on the engine. It's been a while since I built a 350, but I recall headstuds (not bolts, studs) requiring red loctite.
    Off the top of my head, a few things that require them- main journals, Redisleeve repair kits for such things as cranks (when they have a bit of scoring but doesn't rate a full R&R), threadserts, etc.
    Concur, ARP is great stuff. You can't go wrong with them.
    zero4[QUOTED] likes this.
  17. Oct 5, 2018 at 3:30 PM
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
    I think you meant to post in the other thread. :boink: :rofl:
    Crodell6 and burntkat like this.
  18. Oct 5, 2018 at 3:32 PM
    JKO1998
    Utah
    He’s a fckn newb
    zero4[QUOTED], eon_blue and Crodell6 like this.
  19. Oct 5, 2018 at 3:35 PM
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
    Interesting, I've never messed with domestic engines so no idea there.
    Ah yes, repair stuff like that is an exception and again race design applications where abuse is subjected. But as far as normal fasteners that are meant to be removed eventually there's no need for red.
    burntkat[QUOTED] likes this.
  20. Oct 5, 2018 at 3:56 PM
    2BeersPlease
    2BeersPlease Well-Known Member
    That's what I found.
    Dan8906[QUOTED] likes this.
