  1. Oct 5, 2018 at 3:59 PM
    Wulf
    Wulf no brain just damage
    rock raisin
    Red loctite is recommended for wheel spacers
  2. Oct 5, 2018 at 4:01 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Eh close enough
    Crodell6 and zero4[QUOTED] like this.
  3. Oct 5, 2018 at 4:08 PM
    Reh5108
    Reh5108 Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    Right, but that's at a bench and not performing in the real world. I'm a proponent of OEM and I'm curious how the may differ actually being used and not just dissected.
    Crodell6 likes this.
  4. Oct 5, 2018 at 4:17 PM
    Reh5108
    Idaho
    I've never struggled to break lbj bolts free after using red loc tite, on the trail or the garage. I don't chase the the threads so they're likely dirty causing the loc tite not to adhere properly. To each there own. Being someone who has had the lbj bolt work out and shear two of them in the spindle, which would have left me stranded in BFE if I was solo. I'll choose the extra security or red.
    Wulf likes this.
  5. Oct 5, 2018 at 4:25 PM
    Shortman5
    Shortman5 Well-Known Member
    Supercharged TRD
    TRD S/C, ADS coilovers.
    550 degrees.
  6. Oct 5, 2018 at 4:27 PM
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
    Donahoe CO, Donahoe Rear Resi, Deaver J59, 16" Pro Comp, 33" BFG AT, Hayden Trans Oil Cooler, Oil Filter Relocator, FM 40, ES Bushings, Beefed CB Drop, Deckplate, K&N Drop-In, DO Bed Bar, Cobra 75 WXST, Firestik Firefly, Philips D1R, Clarion Remote Start, Husky Liners
    I'll see your 550 & raise to 600! ;)
  7. Oct 5, 2018 at 4:42 PM
    Whatitisg
    Whatitisg Active Member
    Garrett
    Illinois
    '99 V6, 5sp SR5 4x4
    I was able to put together a binder with the maintenance records it came with. I appreciate the info man. Thank you
    m3bassman[QUOTED] likes this.
  8. Oct 5, 2018 at 7:08 PM
    taco03Trd
    taco03Trd 03 rig trd v6
    Carlos
    Riverside ca
    03 DC prerunner trd v6 2wd
    Ome 881 5100's jba's looking for more
    EDB06C38-77A5-4A86-A5C9-04A084EAB3B6.jpg 33A86C16-5832-48FD-8E15-C6566B2D98CE.jpg
    Pick up this tryfold today from a 17 taco short bed it comes out to the sides a bit the price was rigth. What u guys thinks ?
  9. Oct 5, 2018 at 7:44 PM
    Wsidr1
    Wsidr1 Well-Known Member
    Indiana
    2 x 95.5 Ext 2.7L & 3.4L A/T 4x4
    @taco03Trd
    I think it looks really good. Looks like you scored a good addition. Now, IF it ever rains there in Southern Cali, your covered.
  10. Oct 5, 2018 at 8:53 PM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    Does anyone know what an intense vibration at idle would be caused by? I don’t know if it’s my junkyard transmission or some kind of engine idle issue.
  11. Oct 5, 2018 at 9:04 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    Drive. Doesn’t seem to do it in Neutral or Park. I’m fact it goes away in Park or Neutral, or at least settles down.
    Only happens when I’m stopped at a light for example. And it doesn’t happen all the time.
    ToxicTwin likes this.
  12. Oct 5, 2018 at 9:05 PM
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
    Is this with the AC on & does it stop with the AC off?
  13. Oct 5, 2018 at 9:06 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    I don’t think it’s the AC. Happens with or without the AC compressor engaged.
    My fear is that it’s my junkyard transmission. The original A340F torque converter was warped and shattered my flex plate. So I put the A340E torque converter which has a different stall speed of 300-400 RPM.
    zero4[QUOTED] likes this.
  14. Oct 5, 2018 at 9:07 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    I never suspected engine mounts, it could be. Can they go bad at 99k?
    I just don’t remember if this intense vibration happened with my A340E or not.
  15. Oct 5, 2018 at 9:11 PM
    Speedytech7
    Yes an lots of auto vehicles vibrate at idle under load. It's super common because 4cyl are the most out of balance type of engine too
  16. Oct 5, 2018 at 9:16 PM
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    all i know is both my truck and my fathers truck with the v6 vibrate alot compared to other vehicles when idling
    BartMaster1234 likes this.
  17. Oct 5, 2018 at 9:17 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    That's comforting. I was afraid I had a bad transmission or something along those lines.
  18. Oct 5, 2018 at 9:19 PM
    Speedytech7
    It's all good, funny enough my engine feels so much smoother at idle and up to 3k with the hard poly mounts, but was super shaky in that range with the floppy rubber stock mounts.
  19. Oct 5, 2018 at 9:22 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    Your LC is auto, correct? Does it vibrate idle?
  20. Oct 5, 2018 at 9:23 PM
    Empty_Lord
    Dan
    A straight six is naturally balanced. theyre some of the smoothest types of engine aside from v12s... doubt he gets vibes
