  1. Oct 8, 2018 at 7:58 AM
    Bulldogs129
    Bulldogs129 Don't find fault, find a remedy
    Malcolm
    Mississippi
    2018 TRD, OR, 4wd, Dblcab, 3.5l, & 2002 Tacoma 4wd, SR5, TRD, 3.4L, auto
    I’ll double check it. I think we flipped it 180 degrees. I wonder if the 194 is a direct replacement for 168
  2. Oct 8, 2018 at 8:06 AM
    tntacomaguy
    tntacomaguy Well-Known Member
    Thats the size I used for my truck. I bought all my LEDs from superbrightleds.com. I used the 194s for the the 3rd brake light and the front corners. I think I used an oversized one for the back up lights
    burntkat and Bulldogs129[QUOTED] like this.
  3. Oct 8, 2018 at 8:16 AM
    Bulldogs129
    Malcolm
    Mississippi
    I’ll try rotating the bulbs
    tntacomaguy[QUOTED] likes this.
  4. Oct 8, 2018 at 8:26 AM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    ETCS-i was on all 2003/2004 trucks, v6 or I4, PreRunner/4x4 or 5-lug regardless? Any exceptions to this rule? I know some 2003/2004 S-Runners still have the manual throttle body, and some people report having it earlier than 2003/2004.
  5. Oct 8, 2018 at 8:51 AM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    Are you talking about the extra power button? Specifically on SRunners? My 99 has one if that means anything
  6. Oct 8, 2018 at 8:56 AM
    BartMaster1234
    Tyler
    Flux Capacitor
    You mean the ECT pattern select switch? No, I’m taking about the electronic throttle system that Toyota introduces on later year Tacomas. They got rid of the manual cable driven throttle in favor of an electronically actuated ones.
  7. Oct 8, 2018 at 9:09 AM
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
    Donahoe CO, Donahoe Rear Resi, Deaver J59, 16" Pro Comp, 33" BFG AT, Hayden Trans Oil Cooler, Oil Filter Relocator, FM 40, ES Bushings, Beefed CB Drop, Deckplate, K&N Drop-In, DO Bed Bar, Cobra 75 WXST, Firestik Firefly, Philips D1R, Clarion Remote Start, Husky Liners
    Anyone running rear socks that are the same length left & right? Any issues?
    I was looking to buy Icon shocks but they no longer make different lengths for left & right specific.
  8. Oct 8, 2018 at 9:09 AM
    JKO1998
    Utah
    Elif I know
  9. Oct 8, 2018 at 9:12 AM
    burntkat
    burntkat Well-Known Member
    Phillip
    Charleston, SC
    97 Extracab Tacoma
    Surface mount tech, I assume? Is it possible to replace the IC and diodes?
  10. Oct 8, 2018 at 9:18 AM
    burntkat
    Phillip
    Charleston, SC
    97 Extracab Tacoma
    Yes, terrific stuff!
    vonellis[QUOTED] likes this.
  11. Oct 8, 2018 at 9:24 AM
    Bulldogs129
    Malcolm
    Mississippi
    @tntacomaguy
    :hattip: Many thanks for the tip! It worked perfectly! Also applied the same procedures to the reverse lights and now they work :woot:
    :bowdown: :cheers:
    We’ll p/u the EP35 relay from advanced auto at noon and replace the instrument bulbs at some point today/evening.
    SwampYota likes this.
  12. Oct 8, 2018 at 9:26 AM
    tntacomaguy
    Awesome! Glad it worked for you
    Bulldogs129[QUOTED] likes this.
  13. Oct 8, 2018 at 10:53 AM
    cynicalrider
    cynicalrider #NFG
    Jersey
    Prepped these for their yearly touch up:
    Threw in a red map light for better night vision if I need light at night.
    And started on a camp light project:
    cali04intx, SwampYota and jubei like this.
  14. Oct 8, 2018 at 11:02 AM
    eon_blue
    Azusa, CA
    Are they supposed to be different lengths? Haven't had any issues with mine, I'm guessing their the same length side to side as I only got them about 8 months ago.
    zero4[QUOTED] likes this.
  15. Oct 8, 2018 at 11:25 AM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Yeah for the stock location the pass side is longer if I remember right
    zero4 likes this.
  16. Oct 8, 2018 at 11:29 AM
    eon_blue
    Azusa, CA
    hmmm well crap I don't remember there being a designated right/left shock lol, hopefully I put them on correctly. Unless Icon just makes them the same lengths now then I guess it doesn't matter
  17. Oct 8, 2018 at 11:31 AM
    Speedytech7
    They might, it's only a difference of an inch
    zero4 likes this.
  18. Oct 8, 2018 at 11:35 AM
    eon_blue
    Azusa, CA
    What did I do to my Tacoma yesterday...I stripped the drain plug on the front diff :annoyed: fucking allen-key plug....gonna have to take it in I guess so a shop can weld a hex to it and get it off.
    Luckily the fill plug was able to come off so I could top off the diff, lost almost a half quart of gear oil when I had to do my CV axle last week.
  19. Oct 8, 2018 at 11:36 AM
    Speedytech7
    An air hammer with a chisel bit can usually persuade those off easier
    eon_blue[QUOTED] likes this.
  20. Oct 8, 2018 at 11:39 AM
    eon_blue
    Azusa, CA
    Well I guess that's a good enough reason to add some more tools to my small arsenal lol. Fortunately I did a drain/fill maybe 15k miles ago so I've still got awhile before I need to completely do it again, plus I just added a half quart of fresh fluid. That feeling when you feel the socket round out the plug....it's such a kick to the stomach. I don't know why it was on there so tight, I torqued it to spec last time I put them back on but they were on there real tight for some reason.
