  1. Oct 8, 2018 at 11:43 AM
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    This is key to ensuring your best bet at getting that plug out
  2. Oct 8, 2018 at 11:56 AM
    burntkat
    burntkat Well-Known Member
    Phillip
    Charleston, SC
    97 Extracab Tacoma
    Anyone happen to know the thread-pitch?
  3. Oct 8, 2018 at 12:00 PM
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    Always hit the front diff drain plug straight on with a ball peen a few times before trying to remove it. It'll make it come off super easy.
    Reh5108 and Jiveydude like this.
  4. Oct 8, 2018 at 12:01 PM
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
    Donahoe CO, Donahoe Rear Resi, Deaver J59, 16" Pro Comp, 33" BFG AT, Hayden Trans Oil Cooler, Oil Filter Relocator, FM 40, ES Bushings, Beefed CB Drop, Deckplate, K&N Drop-In, DO Bed Bar, Cobra 75 WXST, Firestik Firefly, Philips D1R, Clarion Remote Start, Husky Liners
    Yeah stock they are. The Bilstein 5100s I used have as well as the DR resis I'm currently running are longer on the passenger side.
    Called Icon this morning to confirm as many vendors don't list the passenger side shock anymore. The ones that do don't have them in stock so I assume they aren't aware. Icon said they decided having different lengths wasn't necessary & it's easier for them to keep on hand.
    Only other shocks I have really heard that are the same length are OMEs.
    So I guess if you've been running the same length on both sides I won't worry then. Maybe with lift it doesn't really matter much? It's like 1.5" difference in length IIRC.
  5. Oct 8, 2018 at 1:16 PM
    cynicalrider
    cynicalrider #NFG
    Jersey
    For the drain I just use some ugga dugga's from my impact on it's lowest setting. Fill plug is usually the painful process of needing to crush my hand putting support on it straight on and tapping the ratchet arm.
  6. Oct 8, 2018 at 3:06 PM
    Bulldogs129
    Bulldogs129 Don't find fault, find a remedy
    Malcolm
    Mississippi
    2018 TRD, OR, 4wd, Dblcab, 3.5l, & 2002 Tacoma 4wd, SR5, TRD, 3.4L, auto
    @tntacomaguy
    @m3bassman
    ...and @ anyone else
    This is the EP35 relay Advance Auto ordered. It not even close to the old one.
    What did you do about it? And am I on the wrong part here?
  7. Oct 8, 2018 at 3:07 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    That's the right one and you pulled the wrong relay out of your truck from somewhere else. It should be on the backside of your inside fusebox
  8. Oct 8, 2018 at 3:08 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    Its the company truck
    That for your blinkers?
    If so you pulled the wrong relay. The blinker one(atleast in my truck) looks nothing like that
  9. Oct 8, 2018 at 3:11 PM
    Bulldogs129
    Malcolm
    Mississippi
    How much to taking the fuse panel off?
    I see one 10mm bolt
  10. Oct 8, 2018 at 3:12 PM
    Sperrunner
    Sperrunner UA342
    Miguel
    El Cerrito, Ca
    2023 Ford F250
    This is how the stock one looks. Its on the back of the fuse box
  11. Oct 8, 2018 at 3:12 PM
    nzbrock
    nzbrock Well-Known Member
    Noah
    San Marcos, TX
    99 TRD Prerunner 3RZ
    I never actually removed my fuse box to get to it. I just reached up behind there and felt around until I found it.
  12. Oct 8, 2018 at 3:30 PM
    Bulldogs129
    Malcolm
    Mississippi
    Thanks a million! We reached around the backside and replaced it! I can’t believe I got on the wrong relay!! LOL
    Y’all are awesome
    We’re about to replace the instrument panel lights
    Sperrunner[QUOTED] likes this.
  13. Oct 8, 2018 at 3:51 PM
    SilverGhost
    SilverGhost Well-Known Member
    RayRay
    Reunion, Co
    02,03 some 04, it's complicated
    #junkyardparts
    Reh5108 and SwampYota like this.
  14. Oct 8, 2018 at 7:11 PM
    Bulldogs129
    Malcolm
    Mississippi
    @ anyone
    Which is the fan fuse? In the process of changing the instrument lights we lost power to the a/c fan...any ideas on where I can start troubleshooting?
  15. Oct 8, 2018 at 7:13 PM
    Speedytech7
    Did you take out the HVAC controls? Cances are you knocked the power for the fan out there
    Bulldogs129[QUOTED] likes this.
  16. Oct 8, 2018 at 7:15 PM
    Bulldogs129
    Malcolm
    Mississippi
    Lemme check it. I’ll pull the bezel back off
    Speedytech7[QUOTED] likes this.
  17. Oct 8, 2018 at 7:58 PM
    Bulldogs129
    Malcolm
    Mississippi
    The 10 amp mini fuse for the gauge blew. All is good now.
    Thanks @Speedytech7
  18. Oct 8, 2018 at 8:16 PM
    Reh5108
    Reh5108 Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    Just wire brush and brake clean.
  19. Oct 8, 2018 at 8:18 PM
    04doublecab
    04doublecab Well-Known Member
    Jeff
    2004 Tacoma
    Traded out my smittybilt box for a smaller one I built out of some shit I had laying around. Anyone in az wanna buy the old box? It’s for a jk. But it works well for holding tools, jacks, etc.
    Bulldogs129 likes this.
  20. Oct 8, 2018 at 8:44 PM
    WinSlow939
    WinSlow939 Road Salt Life
    Nate
    The Rock, Mass
    2002 with some '99 thrown in for fun
    All the Money I Have
    Decided to change out well-worn UBJ's today.. 170K on the originals... replaced w/OEM
