  1. Oct 22, 2018 at 9:35 PM
    presto
    presto Well-Known Member
    Topher
    san francisco
    2000 T4R 4x4
    Fully armored on 33’s
    Cause the fluid was pretty much black, and it would squeal a tiny bit.. I’d bet the fluid had never been changed before now (179k) It can definitely restrict the flow.
    Edit: also happened to watch Timmy the Toolman and got inspired lol.. Make sure you get a new oring before you do it imo.
    eon_blue[QUOTED] likes this.
  2. Oct 22, 2018 at 10:06 PM
    Yetimetchkangmi
    Yetimetchkangmi Well-Known Member
    Benjamin
    Newcastle, WA
    03 Tacoma 4x4 The Yeti
    ARB front locker, Custom high clearance rear bumper, Custom plate front bumper, mile marker winch PE8, safari snorkel, Deck Plate Mod Fox 2.5 rr DSC, Camburg UCA, squeaky Dakar leafs, 5125 10" and custom 7.5" shackles, thee finest PNW pinstripes, MT-R, Nissan crew cab roof rack??? wtf is that about??? Allpro skids, Rigid duallys President McKinley CB with PA Recaro SRD with Wedge Engineering Morimoto retrofits Champion Rad - Failed Tundra brakes
    link to video?
    presto[QUOTED] likes this.
  3. Oct 22, 2018 at 10:34 PM
    presto
    Topher
    san francisco
    2000 T4R 4x4
  4. Oct 23, 2018 at 4:38 AM
    Blue92
    Blue92 Well-Known Member
    Daniel
    North Carolina
    2018 Sport
    New Akebono ceramic pads and brembo blank rotors along with some paint.1022181747.jpg 1022181740.jpg
  5. Oct 23, 2018 at 6:10 AM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    Blue92[QUOTED] likes this.
  6. Oct 23, 2018 at 6:11 AM
    1997tacomav6
    Denver
    Leaking valve cover gaskets might just need new rubber washers and torqued again instead of replacing all the gaskets.
    My gaskets were replaced 100,000 miles ago, 3 years ago now leaking again.
    The rubber washers are trashed and probably the reason why they are leaking.
  7. Oct 23, 2018 at 9:31 AM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Wow. That's a lot of miles in just 3 years.
  8. Oct 23, 2018 at 9:51 AM
    eon_blue
    Azusa, CA
    lol you should see mine. I take pride in keeping my truck pretty damn clean most of the time despite the dirt it sees pretty regularly, but the vents are always caked in it. Too much effort to clean those out when they get dirty again so easily as soon as you put a tire on dirt.
    Speedytech7 likes this.
  9. Oct 23, 2018 at 9:54 AM
    eon_blue
    Azusa, CA
    Well the vents pull in air from outside, even if you have recirculate on it's still going to pull in some outside air. And if you're spending all day (or multiple days) in the dirt, that stuff is going to work it's way in whether you want it to or not. Esp since we don't have cabin air filters
  10. Oct 23, 2018 at 9:54 AM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    Age
    Should've seen the amount of dust that came out of the 5-Lug when I took my air compressor to it.
  11. Oct 23, 2018 at 10:11 AM
    BartMaster1234
    Tyler
    Flux Capacitor
    You wouldn't have dust because the Texas floodwaters cleaned it all off.
    :luvya:
  12. Oct 23, 2018 at 10:11 AM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Trust me. when you drive a few thousand dirt miles a year. Your vents will be that dirty. Nothing you can really do about it.
    Always fun to turn it on high and have a large cloud of dust blown right in your face haha
  13. Oct 23, 2018 at 10:11 AM
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    or maybe he uses his truck :notsure:
    Mine look the same way after one weekend of playing. They get cleaned well, but it comes right back each trip.
    I usually fire up the AC full blast once I hit the freeway after a weekend in the sticks. Its funny watching the wife's reaction :laugh:
  14. Oct 23, 2018 at 10:12 AM
    BartMaster1234
    Tyler
    Flux Capacitor
    I wish our trucks had cabin air filters.
    turbodb and Yetimetchkangmi like this.
  15. Oct 23, 2018 at 10:24 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    meh. Im over it. The dash could be used for soil samples from at least 5 states haha
  16. Oct 23, 2018 at 10:24 AM
    Yetimetchkangmi
    Benjamin
    Newcastle, WA
    I 'cleaned" out the vents this weekend with the CB install.
    The dust was more like black grease butter...
  17. Oct 23, 2018 at 10:35 AM
    eon_blue
    Azusa, CA
    Every. Single. Time.
    ToxicTwin and Yetimetchkangmi like this.
  18. Oct 23, 2018 at 10:44 AM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    Drive on dirt
  19. Oct 23, 2018 at 10:53 AM
    JKO1998
    Utah
    Someone tried to retrofit one, can’t rmeber who, don’t think they were ever very successful.
  20. Oct 23, 2018 at 10:53 AM
    BartMaster1234
    Tyler
    Flux Capacitor
    Yeah I remember seeing that. They just shoved part of a Furnace filter into the airbox, IIRC.
