  1. Oct 25, 2018 at 10:15 AM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Yeah if Front Range Offroad would come out with their +2 kit I think it would be ideal in a lot of ways. Granted their design was a bit odd. Shame there is no market for that really. If I had more time Id try just making one myself and getting custom axle shafts. Seems like a lot of work for not a lot of gain though.
    I don't know how, because yeah the rear shocks are blown out, but its still works remarkably well...somehow. Holding me back? Yeah sure a bit. But certainly not keeping me from outpacing anything else. Im stoked to redo the rear this winter with some real outboard shocks. Working on putting stuff together to do it.
    I've come to appreciate the mid travel front with the Kings on Igor. But I also do not like it come from the front LT. Its insane the difference it makes. And of course I don't mind the width but that is a big negative.
  2. Oct 25, 2018 at 10:16 AM
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
    10% off everything today on eBay. "PICKUPTEN" No minimum, but max is $100 off
    BartMaster1234 likes this.
  3. Oct 25, 2018 at 10:58 AM
    mechanicjon
    mechanicjon They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
  4. Oct 25, 2018 at 10:58 AM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    You ordered a set?
  5. Oct 25, 2018 at 11:05 AM
    mechanicjon
    Jon
    Scottsdale Arizona
    Actually have them in my garage.
  6. Oct 25, 2018 at 11:42 AM
    1997tacomav6
    Denver
    I h
    I have almost 100,000 since the last rebuild and 40,000 with the methanol kit,
    Rotor and case coating show little wear with
    100,000 miles
    One needle bearing is going out a little
  7. Oct 25, 2018 at 11:42 AM
    mechanicjon
    Jon
    Scottsdale Arizona
    Are the heated mirror parts still available from the dealer?
  8. Oct 25, 2018 at 11:43 AM
    mechanicjon
    Jon
    Scottsdale Arizona
    not bad for 100k
    1997tacomav6[QUOTED] likes this.
  9. Oct 25, 2018 at 11:45 AM
    BartMaster1234
    Tyler
    Flux Capacitor
    Lemme see.
  10. Oct 25, 2018 at 11:46 AM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Not bad at all, very little scoring for as high miles as that whole thing is. Certainly cleaner than mine was when I installed it, not sure how clean it is now with the meth
  11. Oct 25, 2018 at 11:48 AM
    Speedytech7
    Gentlemen...
    zero4 and 1997tacomav6 like this.
  12. Oct 25, 2018 at 11:49 AM
    mechanicjon
    Jon
    Scottsdale Arizona
  13. Oct 25, 2018 at 11:58 AM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    ^ Ma’am
  14. Oct 25, 2018 at 11:58 AM
    eon_blue
    Azusa, CA
    did you just assume my gender?
    edit...nm it's under my avatar
  15. Oct 25, 2018 at 12:03 PM
    1997tacomav6
    Denver
    No carbon build up on the rotors as u can see, no coating pealing off,
    But was recommended to rebuild it at 100,000 each time because of the added boost, methanol and
    smaller pulley.
    A lot more stress on the needle bearings in particular
    cruiserguy likes this.
  16. Oct 25, 2018 at 12:09 PM
    lotsoftoys
    lotsoftoys pavement is boring....
    Jace
    Denver
    98 lifted panda taco
    bunch of crap
    I love the kit, my rear end feels awesome after all that work I did to it. And I dont rub at all with 285s. Works great, just alot of work and alot to think about.
    BYJOSHCOOK, jubei, FLBAdrian and 3 others like this.
  17. Oct 25, 2018 at 12:10 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    WUT :confused:
  18. Oct 25, 2018 at 12:33 PM
    GreeGunc
    GreeGunc Full of regret
    Jacob
    North GA
    1st gen 3rz+18' inferno OR 6spd
    2lo mod. PIAA 510s. Green Floor Lights. Green dash swap. Axle dump exhaust. Husky floor mats. Moto metal mo970's. Shrockworks. Sundown sa-8. 9.5xrc. Kings
    What kind of work we talking about....
  19. Oct 25, 2018 at 12:59 PM
    cynicalrider
    cynicalrider #NFG
    Jersey
    Cutting/welding/breaking down your leaf pack/measuring travel numbers, essentially all the work that goes into building a proper rear shock setup for these trucks.
    lotsoftoys, jubei and JKO1998 like this.
  20. Oct 25, 2018 at 1:10 PM
    GreeGunc
    Jacob
    North GA
    Oh, figured itd be alot more from the way he worded it
