  1. Oct 26, 2018 at 8:32 AM
    Reh5108
    Reh5108 Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    I'm hoping that's all it is. $30 for those isn't bad. Need to drop the diff to install the turbo oil pan so I'm not too annoyed by it.
  2. Oct 26, 2018 at 8:33 AM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    I feel like there’s more details in your build. I’ll go check that out, thanks.
    Reh5108[QUOTED] likes this.
  3. Oct 26, 2018 at 8:33 AM
    El Taco Diablo
    El Taco Diablo Professional Pinstriper
    Matt - KN6DZP
    Hughson, CA
    Impulse Red DC, 5vz-fe, 4wd swap, LT, dual case, F/R locked
    Just 3 tons of fun!!!
    One diffrence between what you are describing and what my set up will be, is I will be manual hub, not ADD. Not sure if that's good, bad, or indifferent... but that's why I'd love to hear everyone's insight and opinions while I figure out the best balance between what is best, and what I'll actually be able to afford to do.
  4. Oct 26, 2018 at 8:46 AM
    ToyRyd04
    ToyRyd04 Taco Transformer
    Greg
    Perryville, MD
    '04 PreRunner
    SAS'd PreRunner Diamond Axles Crawlbox
    Not awful then, especially already needing to be in there. Might as well swap in a new pinion seal as well.
  5. Oct 26, 2018 at 8:46 AM
    Reh5108
    Idaho
    Careful with those axles. I actually swapped my driverside to a manual hub so I wasn't turning the rest of the drivetrain. I ended breaking it much easier than I thought it should have. They are 6mm smaller on the stub shaft. When they break they also take the hub with it. After that incident I swapped the ADD spindle and axle back in. I haven't had any ill effect from turning the front driveshaft all the time.
  6. Oct 26, 2018 at 8:47 AM
    Reh5108
    Idaho
    Did that in the spring.
  7. Oct 26, 2018 at 8:54 AM
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    Correct.
    Also means my tires clear better in the front, and I don't cover the side of my truck in mud. :luvya:
    I really don't like tires sticking out way past the fender.
  8. Oct 26, 2018 at 8:55 AM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Youre kind of fucked there no matter what as you have a 3rd gen 4runner and that inherently has weirdly different parts than your taco. And the 3rd gen is also well..totally different.
    Running Board Man likes this.
  9. Oct 26, 2018 at 8:56 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Right. All good points and fair.
    With a more aggressive offset wheel and wheel spacers. You can add another inch or so to your measurement. Would clear a shock fine. You just have to be okay with the wheel poke, which you're not. But it will work just fine if you are okay with the poke.
  10. Oct 26, 2018 at 8:57 AM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    Yeah, I remember reading his post on it. Replaced the spare tire carrier. Cool stuff.
    Reh5108 likes this.
  11. Oct 26, 2018 at 9:02 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Not on a tacoma far as i know. Lots of people did that with supras when i was into those to fit certain offset wheels.
    Stock fenders aren't big enough to really gain much from doing that, least the fronts. I think you could do some body work trickery to the rear bed sides with some strategic cuts and rolling it then patching the body. Be a lot of work though
    BYJOSHCOOK and JKO1998 like this.
  12. Oct 26, 2018 at 9:06 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    its a triangulated 3 link btw haha Not 4 link cool
    yeah the motor is the exact same. But Im sure there are lots of quirky differences hidden all over. Thank you Toyota.
  13. Oct 26, 2018 at 9:08 AM
    Reh5108
    Idaho
    Do you feel like the 4 link "sways" compared to the Tacoma? My roommate had a 3rd gen for a bit and it was sketchy how much the rear felt like it would float. Also drove a 5th gen 4runner that felt similar but not nearly as bad, just noticeable.
  14. Oct 26, 2018 at 9:10 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Thats cause its a 3 link which swing the axle as it moves through the range of motion.
    My brothers did it pretty bad. Would kind of do a weird rear end shimmy that could be terrifying on the highway in bad road conditions. This was mostly due to being lifted too much I think. Lowered it down a bit and it helped a lot plus new sway bars.
  15. Oct 26, 2018 at 9:17 AM
    Reh5108
    Idaho
    Yep. It wasn't fun around 65mph. I'm sure no sway bar made it worse.
  16. Oct 26, 2018 at 9:47 AM
    GreeGunc
    GreeGunc Full of regret
    Jacob
    North GA
    1st gen 3rz+18' inferno OR 6spd
    2lo mod. PIAA 510s. Green Floor Lights. Green dash swap. Axle dump exhaust. Husky floor mats. Moto metal mo970's. Shrockworks. Sundown sa-8. 9.5xrc. Kings
  17. Oct 26, 2018 at 9:48 AM
    JKO1998
    Utah
    Holy shit, I hope you honk 100x a day
  18. Oct 26, 2018 at 9:53 AM
    GreeGunc
    Jacob
    North GA
    My compressor kicks on about twice a week, in Greenville S.C the drivers are complete assholes/idiots.
    Only get a taste of the nice Ga people on the weekends, I thought Atlanta was bad...
  19. Oct 26, 2018 at 10:13 AM
    Reh5108
    Idaho
    Looks like you'll have plenty of room.
  20. Oct 26, 2018 at 10:19 AM
    GreeGunc
    Jacob
    North GA
    Stalking your build begins now
    You have a post number for the shock relocate and leaf pack your running
