  1. Oct 30, 2018 at 5:56 AM
    acs118
    acs118 Well-Known Member
    Pittsburgh, PA
    2002 4WD V6 TRD Tacoma
    Full front brake change (calipers, pads, rotors) and bleed over the weekend. Driver caliper had clear signs of a piston or two being seized up, inside of the rotor had a ring of rust about a half inch wide. I thought for sure this was the friction/ drag I was feeling and while it has definitely improved, I still feel some very slight drag at low speeds/ have some minor vibration. Feel it in the gas pedal more than anywhere else, sounds similar to @lukester78.
  2. Oct 30, 2018 at 6:09 AM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    I hate when I back into trees
    Blue92[QUOTED] and ToxicTwin like this.
  3. Oct 30, 2018 at 6:26 AM
    rseesparky
    rseesparky New Member
    Riley
    435, Utah
    02 Tacoma. V6. SR5
    Wired my Light Bar, and Pods into a relay to control maunally or with the high beams. 96EDF2ED-12A1-4ECB-B03F-4F9503877189.jpg93FD362E-67E4-43CD-8EDA-8AFEF4E6E69E.jpgF6EA0DCE-EC6E-4C12-991A-EC7766E7715E.jpg
  4. Oct 30, 2018 at 6:42 AM
    Thaitoy
    Thaitoy 2003 3.0 turbo diesel. 6in lift w 33's
    2003 taco 3.0 turbo diesel
    6 inch lift. 33in tires 10000lb winch and shocks
    Sanded and.painted push bar. Now it is drying.
    TacoSauce04, ToyRyd04 and SwampYota like this.
  5. Oct 30, 2018 at 7:18 AM
    Blue92
    Blue92 Well-Known Member
    Daniel
    North Carolina
    2018 Sport
    I hate groundskeepers who do half ass jobs.
  6. Oct 30, 2018 at 8:54 AM
    Pyrifera
    Pyrifera Adventureswithdog.com
    Oregon
    '04 TRD 4x4, V6, 5-speed
    All nooks & crannies now upgraded with Dog Hair!
    A slight bit of added character ;-)
  7. Oct 30, 2018 at 9:27 AM
    Dan8906
    Dan8906 Well-Known Member
    Daniel
    Concord, California
    2004 Tacoma ext cab TRD 4x4
    CBI sliders, ADS extend travel with compression adjuster coil overs, 9” Bilstein 5125 rear shocks, Icon Tubular UCA, Alcan custom leafs, All Pro Apex bumper and skids, NWTI rear diy bumper, 295/70/17 Cooper St Maxxs and nitro 4.88s.
    what is the purpose of that additional tube?
  8. Oct 30, 2018 at 9:30 AM
    Blue92
    Daniel
    North Carolina
    2018 Sport
    A step. I borrowed the design from addicted offroad. It also absorbs tree impacts before it hits my tailgate too, I guess. 00-06TundraRear_002.jpg
    vonellis, MacGyvR and Dan8906[QUOTED] like this.
  9. Oct 30, 2018 at 10:16 AM
    SUGABEAR
    SUGABEAR Well-Known Member
    MR.M
    SoCal
    Well I spent a whole hour looking for that stupid leak with no luck. I checked the freeze plugs and they seem clean with no sign of leaking. I checked behind the air intake manifold next to the heater core lines and nothing. The leak is so slow that it’s crusting over before it even drips. It’s not a continuous leak, but I’m SOL at the moment. Probably just keep an eye on it and hopefully it doesn’t get worse.
  10. Oct 30, 2018 at 10:24 AM
    cynicalrider
    cynicalrider #NFG
    Jersey
    I got a steel bumper so I CAN back into trees. :rofl:
  11. Oct 30, 2018 at 11:00 AM
    RysiuM
    RysiuM Well-Known Member
    Rysiu
    Was Golden State, now Poland EU
    1995 4x4 LX Ext Cab, I4 2.7, MT, 335K miles
    DD Deck+backup camera, LED DRL, All LED except H4 Hella
    I used to back up into trees and wooden poles when parking in a camp sites. And I have just chrome bumper. I worked well till one day when two things happened at the same time:
    1. I misses that darn pole and hit it with my rear fender just in front of the bumper,
    2. It was not wooden pole, but concrete painted in brown.
    The scar is for this day so my wife can point at it and laugh at me every time I complain at her driving.:rofl:
    cruiserguy likes this.
  12. Oct 30, 2018 at 12:54 PM
    vonellis
    vonellis Well-Known Member
    04 DLBC x4 S/C 97 2X 04 DBLC 4X S/C
    Some and some more
    Parking lot kisses! She lost in the kiss I lost some paint . B6867C6C-232F-4F11-8F31-A9D7287604FC.jpg
    SnowroxKT likes this.
  13. Oct 30, 2018 at 1:09 PM
    Seagull233
    Seagull233 Well-Known Member
    Tom
    Upstate New York
    2004 DC 4x4 V6
    BMW seats, OME Suspension, CBI and NWTI plates front and rear, 13,000 winch, LED light bars, Ham Radio, topper with roof rack added, stainless exhaust, 2nd battery, inverter, sound deadener
    Today was flush the power steering pump day. Followed Timmy the Toolman's video (the one where you pump out the system while adding fluid, and then pull the reservoir to clean the screen filter. It seemed that I could not keep up with the flow rate of the pump return line as I was adding fluid, and it gave the low fluid whine. This necessitated stopping and starting a couple of different times, but eventually, I got to clean fluid coming out of the return. Then pulled and cleaned the reservoir. Lots of brake-clean, and some pretty nasty black gunk was flushed out. Then started to use the air hose, on low pressure, to dry the brake-clean. After shooting air up through from the bottom, this piece of what I think is the corner of a paper towel was blown up to the cap opening. It wasn't anything that I was using, but it may have well been why I had trouble with getting fluid in fast enough. Is there any logical reason that the PO might have inserted this in the reservoir? I've never had it apart, and I'm not even sure that I have ever needed to add fluid. I'm fairly confident it isn't part of the filter, as I could not see any more material in the there, and it is obviously very oddly shaped to fit in a round reservoir. Any thoughts guys???IMG_0251.jpg
  14. Oct 30, 2018 at 1:14 PM
    chowwwww
    chowwwww Well-Known Member
    Orange County
    03 Doublecab 4x4
    Billys 5100/Eibach and Wheelers Progressive 1.5 AAL with overload in
    Going to be installing a transmission cooler this week. A340F transmission. thinking of just bypassing the radiator all together and using the transmission cooler only. Any thoughts on this? not in cold weather much. Also, can anyone let me know which line is the feed and which is the return on the transmission?
  15. Oct 30, 2018 at 1:16 PM
    Seagull233
    Tom
    Upstate New York
    2004 DC 4x4 V6
    Return line is the one coming from the driver side of the radiator. Hope that helps.
    chowwwww[QUOTED] likes this.
  16. Oct 30, 2018 at 1:39 PM
    chowwwww
    Orange County
    03 Doublecab 4x4
    Thanks!
  17. Oct 30, 2018 at 1:39 PM
    nzbrock
    nzbrock Well-Known Member
    Noah
    San Marcos, TX
    99 TRD Prerunner 3RZ
    Output line from the transmission should be the one that has the temp sensor on top of the exit port.
  18. Oct 30, 2018 at 1:42 PM
    Dcpsychobilly
    Dcpsychobilly Well-Known Member
    Aurora Colorado
    04 dbl cab Taco
    Bumpers, skids, lights and more lights, trail gear bumper, sliders, front kings, dakar lift leaf springs rear, corbeau seats
    So I'm in need of skid plate bolts.
    Is the correct size m8 1.25 15mm?
  19. Oct 30, 2018 at 2:03 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    you could bypass it all together. It does help get the oil up to temperature faster. But certainly not needed if you aren't in a cold climate.
  20. Oct 30, 2018 at 2:06 PM
    chowwwww
    Orange County
    03 Doublecab 4x4
    Thanks. I live in southern California so not in any cold temps. Coldest ill be in would be when winter camping and that's prob into the low 30s maybe teens if I end up in parts of Utah. so far coldest has been Bryce in December and I think that was 3F at night. but that was only once. I am just looking to avoid the strawberry milkshake if possible.
