  1. Oct 31, 2018 at 10:26 PM
    JBTacoma
    JBTacoma Well-Known Member
    Jeff
    Cullman Alabama
    2000 SR5, 2003 Double Cab and a Suzuki Samurai
    Why
  2. Oct 31, 2018 at 10:29 PM
    xtremewlr
    xtremewlr Well-Known Member
    Todd
    Tucson, AZ
    2003 4Runner V8 - 2012 b00sted XRunner
    I have mods
    Easy enough to do, just draw a line on the top plate to continue the center X out to the outer bolts and then cut off the excess outer parts. I ordered the same battery tray after seeing your post on it and am picking up a PC1400 tomorrow to replace the tiny, incorrect battery that is in the truck now, installed by the previous owner. After reading the concerns about the terminals, I'm going to cut mine as described, paint it with POR15 and then plastidip the top or see what other options I can come up with. Maybe do a spray can bedliner coating on the top instead of the plastidip, it would be a lot thicker and better protection from tools or accidental contact. Just the top of the top plate tho as it doesn't appear there is much space for anything thicker than a coat of paint between the top plate and battery.
    austinmtb[QUOTED] likes this.
  3. Oct 31, 2018 at 10:29 PM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    Rust
  4. Oct 31, 2018 at 10:41 PM
    JBTacoma
    Jeff
    Cullman Alabama
    Oh, I am so glad we do not have that problem in Alabama.
  5. Oct 31, 2018 at 10:52 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    Oh we don’t here in California either. This 4Runner spent time in the salt belt.
    Only reason I took it is because that ratio is so rare. Only rusty car I’ve ever worked on.
  6. Oct 31, 2018 at 10:53 PM
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    Whimp
    Speedytech7 likes this.
  7. Oct 31, 2018 at 10:56 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    Sorry, I don’t speak rust.
    :luvya:
  8. Oct 31, 2018 at 11:08 PM
    Empty_Lord
    Dan
    mskes You stronger
  9. Oct 31, 2018 at 11:19 PM
    JBTacoma
    Jeff
    Cullman Alabama
    4:30 ratio is easy to find here.
  10. Oct 31, 2018 at 11:36 PM
    xtremewlr
    Todd
    Tucson, AZ
    I have mods
    Bought and installed an updated stereo system for the truck. The old Sony head unit worked fine but did'nt have bluetooth and I pretty much only stream Pandora. Also had no hands-free phone capability and was running with the OEM speakers. Which when I removed the old unit, I found that they wired it so it was only using the front speakers on a 4 speaker setup... :confused:
    Out with the old stuff.
    Replaced it all with Kenwood Excelon stuff. Sounds much better with 4 of these 6.5" speakers actually working now. And it has bluetooth and hands-free capability for calls.
    The head unit installed. It's a KDC-X502. I forgot to wipe everything down so it's covered in fingerprints and dirt from the install. I also got a Mod Armor Modnetic Stick 90 to hold my phone that you can see in the pic. Works good so far.
    While I was doing the stereo install, I replaced the cigarette lighter and one of the power ports with USB ports I found on ebay. I have these in my 2004 Dodge Ram as well and they are awesome.
    And finally, I received my 4xInnovations heavy duty trans mount to replace the broken one in the truck right now. Waiting on the paint to dry, I used POR15 spray can top coat stuff. Probably won't get it installed until Friday.
  11. Oct 31, 2018 at 11:40 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    They are on 4Runners. Unheard of on Tacomas, at least at junkyards here in California and Nevada.
  12. Nov 1, 2018 at 7:09 AM
    JBTacoma
    Jeff
    Cullman Alabama
    Search for 2000 models and you will find them.
  13. Nov 1, 2018 at 7:22 AM
    drr
    drr Primary Prognosticator
    Dan
    Seattle-ish
    02 4WD Tacoma
    I am running those wheels in the 16x8 flavor (4.0 BS) with 1.5" spacers. Tires are 315/75R16 MTRs. They still rub a bit on the frame at full lock and stuffed, but nothing terrible.
    burntkat, jubei, cruiserguy and 3 others like this.
  14. Nov 1, 2018 at 8:02 AM
    Blue92
    Blue92 Well-Known Member
    Daniel
    North Carolina
    2018 Sport
    I have a B07A code on the vin sticker. 4:30 on a 4x4.
  15. Nov 1, 2018 at 9:01 AM
    chowwwww
    chowwwww Well-Known Member
    Orange County
    03 Doublecab 4x4
    Billys 5100/Eibach and Wheelers Progressive 1.5 AAL with overload in
    Installed a tru-cool transmission cooler yesterday. It took longer than expected. but guess that's what happens when you refuse to drop the skid plat and cant find your 90* needle noses. Hopefully its all working right. Also did a drain and fill. I will be on a 5hr drive tomorrow.
  16. Nov 1, 2018 at 9:04 AM
    BartMaster1234
    Tyler
    Flux Capacitor
    Huh. Must’ve changed since the time I was searching for parts because I remember not being able to plug in 4.30.
  17. Nov 1, 2018 at 9:05 AM
    BartMaster1234
    Tyler
    Flux Capacitor
    It’s definitely a rare gear ratio in 4x4. I’ve seen more 4.56 than I’ve seen 4.30.
  18. Nov 1, 2018 at 9:12 AM
    austinmtb
    austinmtb Well-Known Member
    Austin
    Southern Oregon
    2004 Toyota Tacoma DC TRD 4x4
    ADS Coilovers & Shocks, All Pro Standard Leafs, TRD Supercharger, Haltech Standalone, URD 2.2'' pulley, Method NV wheels, Copper Discoverer STT Pro tires, ECGS 4:56 gears, custom steel tube bumper, custom steel skid plate,
    Could you post some pictures when you're all done? I'd like to see how it turns out. Maybe I'll go ahead and do the same thing.
  19. Nov 1, 2018 at 11:59 AM
    cynicalrider
    cynicalrider #NFG
    Jersey
    You still have flares on 35's?
  20. Nov 1, 2018 at 12:25 PM
    Reh5108
    Reh5108 Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    I always thought most 4cyl 4x4 5 speeds came with 4.30s
