  1. Nov 6, 2018 at 8:29 AM
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
    One question, do you want to do this all again in a few months? If not replace it all, seal, bearing, o-ring on both sides.
    zero4 and 1997tacomav6[QUOTED] like this.
  2. Nov 6, 2018 at 8:30 AM
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
    Donahoe CO, Donahoe Rear Resi, Deaver J59, 16" Pro Comp, 33" BFG AT, Hayden Trans Oil Cooler, Oil Filter Relocator, FM 40, ES Bushings, Beefed CB Drop, Deckplate, K&N Drop-In, DO Bed Bar, Cobra 75 WXST, Firestik Firefly, Philips D1R, Clarion Remote Start, Husky Liners
    Just saw the pics. That's exactly where mine was leaking.
  3. Nov 6, 2018 at 8:31 AM
    burntkat
    burntkat Well-Known Member
    Phillip
    Charleston, SC
    97 Extracab Tacoma
    You don't have to use AN fittings. JIC work just as well, and in fact are compatible with AN. They just happen to be heavier as they are steel instead of AL. Since this isn't a fighter jet, JIC gets the nod whenever I do hydro work.
  4. Nov 6, 2018 at 8:32 AM
    burntkat
    Phillip
    Charleston, SC
    97 Extracab Tacoma
    Yes you can, but shouldn't.
    Think about it- how's it going to drain the air in the filter? You'll be aerating your oil bigtime, and likely never get the bubble out of the filter. This means you won't be using the filter completely, also.
  5. Nov 6, 2018 at 8:37 AM
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    Simple job.
  6. Nov 6, 2018 at 8:38 AM
    burntkat
    Phillip
    Charleston, SC
    97 Extracab Tacoma
    You get that PSU off Amazon? How's it treating you? I have been looking for a new unit for a while now and have had my eye on a similar unit for a few months.
  7. Nov 6, 2018 at 8:43 AM
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
    Mine is mounted in the engine bay. I don't have a fancy one though, just a PermaCool one.
    My truck came with it so I'm spoiled & have no idea what it feels like to change the filter from the stock location.
    I didn't like the mount configuration the PO used so I replaced it.
    How it used to be
  8. Nov 6, 2018 at 8:45 AM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    eBay, but I'm 100% sure all those units come from the same factory in China. It's nice, it's never dramatically failed on me yet.
    burntkat[QUOTED] likes this.
  9. Nov 6, 2018 at 8:45 AM
    BartMaster1234
    Tyler
    Flux Capacitor
    Sounds like it. Have to order the bushing.
  10. Nov 6, 2018 at 8:52 AM
    Phessor
    Phessor Well-Known Member
    Yes, oil pressure, I feel like the idiot for making that comment...
    Blue92[QUOTED] likes this.
  11. Nov 6, 2018 at 8:57 AM
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
    The units from Circuit Specialists are pretty good & reputable. You can find cheaper ones though.
    I used to have this one:
    https://www.circuitspecialists.com/benchtop-power-supply-csi12001x.html
    Sold it & now I have this one:
    https://www.circuitspecialists.com/bench-power-supply-csi12003x.html
    I use it for mainly anodizing titanium though.
    OneWheelPeel likes this.
  12. Nov 6, 2018 at 9:08 AM
    xtremewlr
    xtremewlr Well-Known Member
    Todd
    Tucson, AZ
    2003 4Runner V8 - 2012 b00sted XRunner
    I have mods
    Received my battery cable but for the life of me, I can't find any place local that can either sell, rent or crimp 2/0 AWG wire. That's the only thing holding me up from getting this finished now.
  13. Nov 6, 2018 at 9:11 AM
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
    Try a stereo shop (automotive audio).
    xtremewlr[QUOTED] likes this.
  14. Nov 6, 2018 at 9:15 AM
    Dan8906
    Dan8906 Well-Known Member
    Daniel
    Concord, California
    2004 Tacoma ext cab TRD 4x4
    CBI sliders, ADS extend travel with compression adjuster coil overs, 9” Bilstein 5125 rear shocks, Icon Tubular UCA, Alcan custom leafs, All Pro Apex bumper and skids, NWTI rear diy bumper, 295/70/17 Cooper St Maxxs and nitro 4.88s.
    Are those going to work for full stuff? Im looking at the 5.25" and will probably have to run 2" or 3" spacer still.
  15. Nov 6, 2018 at 9:30 AM
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
    Don't know what leafs you are running, you'd have to cycle your pack & check. I'm running Deaver J59s with the 4.25" bumps which are good for about up to 3" lifts. Compressed height is 3.5".
    5.25" are for custom applications & wow you want to run 2-3" spacers as well? How much lift do you have?
    I was running superbumps before which were about the same height as the duros uncompressed.
    m3bassman likes this.
  16. Nov 6, 2018 at 9:44 AM
    burntkat
    Phillip
    Charleston, SC
    97 Extracab Tacoma
    Try a propane torch and electrical solder. It will work just fine.
    You DO NOT need to crimp these connections.
  17. Nov 6, 2018 at 9:46 AM
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    what's the purpose of those rear bum stops? I cant see myself coming down that hard on the rear? I don't do no Pismo beach crazy shit. The front end takes most the abuse.
  18. Nov 6, 2018 at 9:48 AM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Same purpose as the fronts
  19. Nov 6, 2018 at 9:49 AM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Same idea. Big hit in the rear it helps soften it and protect your rear shocks.
    If you don't drive super fast a lot not super needed but nice to have. Have a heavy foot? Would recommend.
    zero4 likes this.
  20. Nov 6, 2018 at 9:49 AM
    burntkat
    Phillip
    Charleston, SC
    97 Extracab Tacoma
    Or, just use an Adel clamp. You can get them at Lowe's.
