  1. Nov 8, 2018 at 11:07 AM
    synergy10
    synergy10 @synergy10.sd
    San Diego
    How about the front locker? You have one on yours right? I've considered one in the past but am not sure if I need one. Have you been in situations where you had to use yours?
  2. Nov 8, 2018 at 11:08 AM
    Prayn4surf
    Prayn4surf 20 minutes late
    Socal
    2004 Tacoma xtra cab
    True. It is not needed. Just helpful. I think the best thing he could spend is time. More time on the trail to decide what his truck needs.
  3. Nov 8, 2018 at 11:09 AM
    turbodb
    turbodb AdventureTaco
    Dan
    PNW
    2000 Tacoma Xcab 4x4 SR5 V6 TRD
    AdventureTaco
    Honestly, I think you want 5.29 with the auto. 4.88 would probably work fine, and you think they were good until you drove a truck with 5.29s.
    this is regardless of whether you stick with 33s or move to 35s.
    If you're regearing, it's the right time to do lockers. IF YOU ARE EVER GOING TO NEED THEM. However I do not believe that you need lockers in anything you do and so in that case it is a waste of money.
  4. Nov 8, 2018 at 11:09 AM
    Dan8906
    Dan8906 Well-Known Member
    Daniel
    Concord, California
    2004 Tacoma ext cab TRD 4x4
    CBI sliders, ADS extend travel with compression adjuster coil overs, 9” Bilstein 5125 rear shocks, Icon Tubular UCA, Alcan custom leafs, All Pro Apex bumper and skids, NWTI rear diy bumper, 295/70/17 Cooper St Maxxs and nitro 4.88s.
    Thats where Im at. 2 years for a set of tires.
  5. Nov 8, 2018 at 11:10 AM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Bingo.
    We have a winner.
    If he isn't getting out to just test the waters as it is..no point in getting a locker.
    Seriously. All the stuff I've done..95% of it is without a locker. Actually probably more. I've only had a locker in Frank for 2 years and he's only been road worth for like 2 trips with it. And even then I've used it like 3 times.
    Just pick you line and keep moving. Work most the time. Granted Im not doing Cliffhanger or something(yet) but you can do A LOT of stuff without a locker.
  6. Nov 8, 2018 at 11:10 AM
    Prayn4surf
    Socal
    Yeah, its nice for sure, but I rarely use it unless I absolutely have to. You can break shit if you dont use them correctly. And the right line and a rear locker is all you really need. But yeah Ive been high centered on rocks and the front got me out easy as the flip of a switch
    synergy10[QUOTED] likes this.
  7. Nov 8, 2018 at 11:10 AM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    I’ve onyl had one set of tires last more than a year... have been getting about 20kish out of them, I must have bad habits
  8. Nov 8, 2018 at 11:11 AM
    Prayn4surf
    Socal
    Momentum is a hell of a drug
    jubei, Captain Magma and Dan8906 like this.
  9. Nov 8, 2018 at 11:13 AM
    Dan8906
    Daniel
    Concord, California
    I rotate mine every oil change.
  10. Nov 8, 2018 at 11:13 AM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    I suppose you're right. I've never had very long commutes, nor did my father when he owned the truck. When I got the truck in 2015, it only had 75,000 miles and the tires were almost ten years old. I put about 30k on it since, I'm sitting at 101,000 miles. My commute used to be 15 minutes each direction, and then I moved to San Francisco and I don't commute at all anymore. Just sits in the parking garage till I need to go get groceries or do stuff on the weekend.
    I heard the KO2's are terrible tires, but the tread will last forever. I like 'em, but I'll definitely be getting better tires the next go-around. If 4.88 sounds the best, then 4.88 it shall be.
  11. Nov 8, 2018 at 11:14 AM
    JKO1998
    Utah
    I guess I should add I’ve ever really actually gone all the way through 1 set.
    The other 2 have had problems
  12. Nov 8, 2018 at 11:14 AM
    BartMaster1234
    Tyler
    Flux Capacitor
    I don't, but since I'm paying money to re-gear the thing already it's now or never.
    And I do plan on using this truck off-road more, contrary to popular belief.
  13. Nov 8, 2018 at 11:16 AM
    BartMaster1234
    Tyler
    Flux Capacitor
    The newer trucks flash the check engine light?
    That must get annoying really fast.
  14. Nov 8, 2018 at 11:16 AM
    Dan8906
    Daniel
    Concord, California
    I didnt wheel much in college. After, it increased a lot.
  15. Nov 8, 2018 at 11:16 AM
    JKO1998
    Utah
    Fair enough I guess.
    I rarely ever use mine.
    The only time I’ve actually really thought it’s set me ahead is when I’m chained up, and it’s not needed there either.
  16. Nov 8, 2018 at 11:16 AM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Yours does too if you have a misfire, anything that does major cat damage flashes it
    cruiserguy likes this.
  17. Nov 8, 2018 at 11:17 AM
    Dan8906
    Daniel
    Concord, California
    I thought that if its flashing its an indication that something more severe is happening
  18. Nov 8, 2018 at 11:18 AM
    turbodb
    Dan
    PNW
    AdventureTaco
    Using it more doesn't mean you need a locker.
    Let me say this once and for all, since Monte has said it a hundred times.
    The rig he uses to off-road, Igor, has no lockers. Trust me when I say that he does more extreme off-roading then you will with this truck.
    You can spend the money on the lockers and try and justify it, but know that you are doing it not for capability but instead just to say you have them.
    Edit: and Monte, just so you don't get too big of head, this is like your 4th and 5th and 6th Tacoma's - you want them but don't need them :rofl:
  19. Nov 8, 2018 at 11:20 AM
    BartMaster1234
    Tyler
    Flux Capacitor
    I do live in the middle of a big city, so it doesn't help my case. Haha.
    I seriously do plan on using it more. I'll be honest, it took me this long to finally go off-roading because none of my friends drive 4WD vehicles. I mean, I found @Sperrunner and we went last week, but he's a 2WD lifted S-Runner and I was limited to where his truck could go.
  20. Nov 8, 2018 at 11:20 AM
    BartMaster1234
    Tyler
    Flux Capacitor
    I did not know that, that is interesting.
