  1. Nov 8, 2018 at 5:35 PM
    Reh5108
    Reh5108 Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    33's. I'm not saying 5.29's in your instance. 4.88's is what I'd go with for your needs. Idk how the auto is on the 3rz but if it's like it is on the 5vz it blows! I either have something wrong with my 3.4 or all the hype of the 3.4 over the 2.7 is bs. I honestly think my Tacoma has a shot at beating my T100 head to head.
    Do you air down at all?
  2. Nov 8, 2018 at 5:38 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Nope, the auto is just that bad power transfer wise, probably why it rarely breaks too. Head to Head all things being the same I'm pretty sure a 2.7 manual could beat a 3.4 auto to 60mph. I wish I actually tested that before I slapped the SC on the four banger cause now I'm sure I can beat a 3.4 auto haha
    Reh5108[QUOTED] likes this.
  3. Nov 8, 2018 at 5:40 PM
    Reh5108
    Idaho
    It doesn't down shift into 2nd gear when it needs to and up shifts to soon so I start losing speed because it doesn't have the power. I drive it like a manual and choose the gears myself half the time. It's pathetic
    If I had the money I'd put 5.29s in it
  4. Nov 8, 2018 at 5:43 PM
    Speedytech7
    Shouldn't be that bad, have you checked the compression on the 3.4, you might need a good old fashioned tune up
  5. Nov 8, 2018 at 5:45 PM
    Reh5108
    Idaho
    No not yet, want to get the Tacoma back to driving before digging into it. I do get pending misfires for cylinders 1,2 and 3 when it's cold but it never throws a cel.
    Speedytech7[QUOTED] likes this.
  6. Nov 8, 2018 at 5:45 PM
    Speedytech7
    I suppose you are at elevation, I know how bad my cruiser gets around 7k' so maybe that's normal for CO
  7. Nov 8, 2018 at 5:46 PM
    Speedytech7
    Oh yeah there's something going on there for sure then
  8. Nov 8, 2018 at 5:48 PM
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
    Donahoe CO, Donahoe Rear Resi, Deaver J59, 16" Pro Comp, 33" BFG AT, Hayden Trans Oil Cooler, Oil Filter Relocator, FM 40, ES Bushings, Beefed CB Drop, Deckplate, K&N Drop-In, DO Bed Bar, Cobra 75 WXST, Firestik Firefly, Philips D1R, Clarion Remote Start, Husky Liners
    Is your speedo calibrated? If not could be that the computer will tend to shift too early if the speedo is reading way too fast.
  9. Nov 8, 2018 at 5:49 PM
    Reh5108
    Idaho
    Just put 255/85/16 on and it's spot on.
  10. Nov 8, 2018 at 5:51 PM
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    Axle looks pretty clean. Going to wire wheel and repaint it black. New used axle will be here tomorrow and o under the truck. Then truck goes to storage and frame starts getting built
  11. Nov 8, 2018 at 5:58 PM
    SilverGhost
    SilverGhost Well-Known Member
    RayRay
    Reunion, Co
    02,03 some 04, it's complicated
    #junkyardparts
    Not really. They usually are solid. They only flash when it’s really bad.
  12. Nov 8, 2018 at 5:59 PM
    Empty_Lord
    Dan
    Flashing means bad misfire. Even our trucks will do it
    SilverGhost[QUOTED] likes this.
  13. Nov 8, 2018 at 6:01 PM
    SilverGhost
    RayRay
    Reunion, Co
    #junkyardparts
    Yeah that’s what my buddy told me. But it’s the wife’s birthday so no time to run and get a scan tool. Tomorrow....
  14. Nov 8, 2018 at 6:02 PM
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
    If I'm not mistaken I believe all OBDII does that. I don't remember if OBDI did, I don't think so though, at least I've never seen it.
  15. Nov 8, 2018 at 6:05 PM
    Empty_Lord
    Dan
    OBDI wasn’t regulated. Some manufacturers did some didn’t
  16. Nov 8, 2018 at 6:06 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    I wonder how tight it would be. We should have tried it haha even boosted. Yours moves but its nothing like Frank. Only other taco I've been in that pulls as hard is my Dads. The stock boosted one I just test drove didn't even pull as hard as Frank. The gearing helps a lot.
    We should do that with Igor next time haha I bet it'll be close..
  17. Nov 8, 2018 at 6:18 PM
    Speedytech7
    I'm always down for race, definitely be fun. You didn't weigh in with us in WY, how much does Igor weigh?
  18. Nov 8, 2018 at 6:19 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    No, don’t have time for that
  19. Nov 8, 2018 at 6:34 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Im not sure..more than your rig though I think. Though maybe not my much..Haven't weighed him. I will try next time Igor is packed up.
  20. Nov 8, 2018 at 7:21 PM
    Reh5108
    Idaho
    It makes a huge difference! If you're not airing down, I'd say chains are worth it then. At my work the vehicle mechanics seem to believe that every vehicle should be at the max tire pressure on the sidewall. Any little bit of snow and everyone is sliding around. I set my own pressure and have no problem going further than they are and they are chained up at +65psi.
    jubei likes this.
