  1. Nov 14, 2018 at 3:21 PM
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    OEM all the way
    triggered....
  2. Nov 14, 2018 at 3:24 PM
    El Taco Diablo
    El Taco Diablo Professional Pinstriper
    Matt - KN6DZP
    Hughson, CA
    Impulse Red DC, 5vz-fe, 4wd swap, LT, dual case, F/R locked
    Just 3 tons of fun!!!
    2002Tacoma4x4 likes this.
  3. Nov 14, 2018 at 3:40 PM
    Itchyfeet
    Itchyfeet Well-Known Member
    I suggest checking the bearings in that install kit. I bought from them and found one of the pinion bearings to be a Timken instead of a Koyo. I was under the gun and still sent it all out to be installed
  4. Nov 14, 2018 at 4:09 PM
    BlackPearl
    BlackPearl Well-Known Member
    Alex
    Toyota Tacoma TRD
    3” lift. Sway a ways 2.5 on 285 75 16 and much more
    I don't know the difference between the 2 brands, are the Timken lower quality?
    and looks like I have 2 Timken bearings and the rest are Koyos
  5. Nov 14, 2018 at 4:35 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Timken is a good brand just like Koyo. No need to worry there.
  6. Nov 14, 2018 at 4:37 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    And Timken oil seals are made by National Oil Seal and typically install much easier than other brands which is nice.
  7. Nov 14, 2018 at 4:48 PM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    He’s talking about how my 5-lug has $2,000 of CHP penalties and DMV backfees on the original California plates. I registered it in Vermont instead.
    And the bedsides are flappy because I drilled out all the spotwelds so I could swap them to a new bed.
  8. Nov 14, 2018 at 5:01 PM
    JBTacoma
    JBTacoma Well-Known Member
    Jeff
    Cullman Alabama
    2000 SR5, 2003 Double Cab and a Suzuki Samurai
    But the frame looks good :fistbump:
  9. Nov 14, 2018 at 5:05 PM
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    my sides are slightly flappy...cuz 35s.... :pout:
  10. Nov 14, 2018 at 5:15 PM
    Blue92
    Blue92 Well-Known Member
    Daniel
    North Carolina
    2018 Sport
    Hazzard Fraught 8" puller was required for mine. If the previous owner hadnt had my truck coated, it wouldve gotten a new frame by now judging by the condition of other parts when I got it.
    East coast is weird. My truck is from Roanoke and was rusty. My dads 92 pickup was from rural NC maybe 2 hours south of Roanoke, and you can still see the serial numbers on the frame still. Never been coated, just washed off at the end of winter.
  11. Nov 14, 2018 at 5:28 PM
    JBTacoma
    Jeff
    Cullman Alabama
    But 35s :headbang:
    Fernando[QUOTED] likes this.
  12. Nov 14, 2018 at 5:57 PM
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    :wink:
    JBTacoma[QUOTED] likes this.
  13. Nov 14, 2018 at 6:00 PM
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    same... cutting the fold off looses alot of rigidity
  14. Nov 14, 2018 at 6:03 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    Yea but 5 lug
    BYJOSHCOOK likes this.
  15. Nov 14, 2018 at 6:27 PM
    Reh5108
    Reh5108 Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    Anyone pondered putting a tundra steering rack in a 1st gen? Solo makes a kit for 2nd gens. Curious how different it could be from ours.
  16. Nov 14, 2018 at 6:29 PM
    Blue92
    Daniel
    North Carolina
    2018 Sport
    After working in Industrial Mainteneace, Ive realised there is no "best" brand of bearing. They will all fail and no brand in particular wears out any faster than the rest. These days they're almost all China made even if the names Koyo, FAG, Timken, BL,etc. If its carried by your local industrial supply, its a good bearing, and most seem to carry every brand out there.
    Blackdawg[QUOTED] likes this.
  17. Nov 14, 2018 at 6:37 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Why? Mine aren't..
    Wont fit and is basically the same rack just wider. So not worth it unlike the 2nd gen tundra swap to 2nd gen taco.
    Reh5108[QUOTED] likes this.
  18. Nov 14, 2018 at 6:48 PM
    Laxtoy
    Laxtoy Dog is my backseat driver
    Maltby, WA
    99 3.4l 5 speed 4WD 2023 Limited DCLB 4WD
    Fox 2.5 DSC resi CO's w/ 700lb King Coils, Camburg uca's, T-100 rear leafs, 13WL Tundra brakes, 1" 4crawler body lift, 295/75/16 Hankook MT, Ruff Stuff u bolt flip, 10" Fox LSC resi shocks turned back on custom mounts, home built rear high clearance bumper with dual swing outs, Diode Dynamics SSC2 Pro rear floods, Skid Row front and transfer case skid, home built transmission skid, Mercerfab sliders, home built front bumper, Badlands Apex 12k winch with synth line, 4.56's, ARB rear locker, LonePeak wedge camper, eBay snorkel, Sierra LEDs 20" dual amber/white light bar, Diode Dynamics SS3 Max amber fogs, Mini D2S projector retrofit, Blue Sea ML-ACR, dual Odyssey PC1200's, 100 watt solar panel, 20 plate heat exchanger/home built shower kit
    4488A76E-564B-465E-AB5D-5047A3DE202F.jpg I nerded out and put in a dual battery voltmeter on a switch, my fridge cuts out at too high a voltage, trying to figure that out is frustrating 4F9C8608-4061-41C2-A8FB-F1EDFCA1EA70.jpg
    Weejub, Captain Magma and FLBAdrian like this.
  19. Nov 14, 2018 at 7:25 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    as in..the voltage from the truck gets too high and it cuts out or as in the voltage cut off for the fridge is too high?
  20. Nov 14, 2018 at 7:47 PM
    SwampYota
    SwampYota Strange things are afoot at the Circle K
    Jon
    Concord, North Carolina
    '03 Tacoma SR5 TRD 5VZ-FE, 5 Speed
    Floor mats
