  1. Nov 15, 2018 at 2:38 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    damn almost like your tcase is leaking in water from this last trip or something haha
  2. Nov 15, 2018 at 2:39 PM
    Blue92
    Blue92 Well-Known Member
    Daniel
    North Carolina
    2018 Sport
    What oil did you put in the t-case if not mt-90? I thought you could put it in both the tranny and t-case.
  3. Nov 15, 2018 at 2:41 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Nothing to really worry about there then. Sounds like other than being spent, the oil was doing its job well. For reference this is what came out of my Z trans (brass syncro material, the rest is just plant matter blowing around cause I was in my driveway) and even that was acceptable because this was the first drain after a rebuild, but on an old trans and case like yours you'd at most want to see 1/2 of what's in my pan
  4. Nov 15, 2018 at 2:42 PM
    Shortman5
    Shortman5 Well-Known Member
    Supercharged TRD
    TRD S/C, ADS coilovers.
    I changed my diff fluid for the first time in 120k Sunday. Stuf was pretty thick, had a metallic look to it and here’s the magnet.
    I get some very slight vibration at 50-55mph. Just enough to hear with no music and just enough to see the rear view vibrate a tiny bit. It’s slow pulsating, I’m guessing driveline even though I’ve greased it once not too long ago. Maybe I need to try again with different grease with more tack.
  5. Nov 15, 2018 at 2:48 PM
    Shortman5
    Supercharged TRD
    I did a auto trans drain a frefill 3 times now starting at 110k probably a first for that as well. No metal bits but some non magnetic material that seemed to be tiny bits of clutch material. I called a local shop and they said it’s the clutch packs coming apart and I’ll need a new trans. I guessing they’re just trying to sell me a trans job.
    While my shifting isn’t always super smooth just a bit more noticeable with no slipping I’m hoping its fine. When I drop the pan to do the valve body mod I hope cleaning the rest of the funk out will fix it. I read that changing worn “boost valves” would fix it if that doesn’t work
  6. Nov 15, 2018 at 3:10 PM
    turbodb
    turbodb AdventureTaco
    Dan
    PNW
    2000 Tacoma Xcab 4x4 SR5 V6 TRD
    AdventureTaco
    I know.
    Could have happened in that sketchy crossing I guess - isn't the breather on the top of the tcase? Not sure I've been in water that deep at any other time.
    I figure I'll just change it out again in a lot fewer miles next time and make sure it looks better than it did this time. Could have been original in there for all I know...
    I put Lucas 80W-90 in my diffs, and so put it in the tcase as well. The MT-90 probably would have been fine but I wanted the consistency. Plus, that MT-90 is not cheap (at least comparatively)! hahahaha
    Cool, thanks. Definitely didn't see anything like that in mine. Did notice some (very little) oil leaking from the front diff - both sides where the CVs enter the diff. Gonna have to dig into that next, I suppose the front diff could also be the source of my noise...
    Blue92[QUOTED] likes this.
  7. Nov 15, 2018 at 3:13 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    we definietly fully submerged the tcase at least once if not twice on the last trip.
    Breather is on top I believe its part of the tranny one by the shifter.
    Speedytech7 likes this.
  8. Nov 15, 2018 at 3:47 PM
    GreeGunc
    GreeGunc Full of regret
    Jacob
    North GA
    1st gen 3rz+18' inferno OR 6spd
    2lo mod. PIAA 510s. Green Floor Lights. Green dash swap. Axle dump exhaust. Husky floor mats. Moto metal mo970's. Shrockworks. Sundown sa-8. 9.5xrc. Kings
    Was just in that spot on my truck, right in front of the t case shifter is a breather. Believe its for the t case atleast
  9. Nov 15, 2018 at 4:44 PM
    Phessor
    Phessor Well-Known Member
    Bob
    1998 TRD XTra Cab
    Stuff
    Trimmed my bumper to clear my tires.
    jubei and Captain Magma like this.
  10. Nov 15, 2018 at 6:33 PM
    FLBAdrian
    FLBAdrian A Pretty Sizeable Onion
    Adrian
    Hanford Ca,
    1996 X-Cab 3.4l 2014 Tacoma crew cab
    Too many…
    Where you get the tailgate protector?
  11. Nov 15, 2018 at 6:46 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    xtremewlr and FLBAdrian[QUOTED] like this.
  12. Nov 15, 2018 at 6:53 PM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    I cut all this wiring out of the truck, shortened, and loomed all the harnesses.
    Took forever.
    It’s not ideal, but it was a hell of a lot better than what it used to be.
    This is next.
    SwampYota and zero4 like this.
  13. Nov 15, 2018 at 6:55 PM
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
    Donahoe CO, Donahoe Rear Resi, Deaver J59, 16" Pro Comp, 33" BFG AT, Hayden Trans Oil Cooler, Oil Filter Relocator, FM 40, ES Bushings, Beefed CB Drop, Deckplate, K&N Drop-In, DO Bed Bar, Cobra 75 WXST, Firestik Firefly, Philips D1R, Clarion Remote Start, Husky Liners
    Holy shit that's a lot of wiring. What's all that for? Looks like you need another fuse box or some better battery terminals at the least.
  14. Nov 15, 2018 at 6:57 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    This isn’t even my final form.
    Brice likes this.
  15. Nov 15, 2018 at 7:10 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    That there is my power door retrofit system. My truck came from the factory with crank windows, manual locks, and mirrors.
    I bought the door panels, door components, mirrors, and wiring from a rolled 2004 Double Cab Limited and created my own interface to adapt to the OEM door harnesses. After the kick panel connectors IH1/IH2 and IL1/IL2, it’s all custom.
    Now I have keyless entry, remote mirrors, and power windows. The control box is bolted to where the clutch pedal would go.
    I did this about three years ago when I didn’t know any better about electrical. I have to re-do it since the parking lights keep going off. There’s a short somewhere.
    5FFA44F1-D013-420E-BDE3-3BF78574CE29.jpg 670D20EA-A54C-4701-A429-0A5E334B9601.jpg 69E20ADB-322F-4E0B-9A5E-C2053201E876.jpg
    zero4[QUOTED] likes this.
  16. Nov 15, 2018 at 7:52 PM
    FLBAdrian
    Adrian
    Hanford Ca,
    Too many…
  17. Nov 15, 2018 at 8:53 PM
    El Taco Diablo
    El Taco Diablo Professional Pinstriper
    Matt - KN6DZP
    Hughson, CA
    Impulse Red DC, 5vz-fe, 4wd swap, LT, dual case, F/R locked
    Just 3 tons of fun!!!
    Me neither
    :cheers:
    foxrcing07 and xtremewlr like this.
  18. Nov 15, 2018 at 9:02 PM
    xtremewlr
    xtremewlr Well-Known Member
    Todd
    Tucson, AZ
    2003 4Runner V8 - 2012 b00sted XRunner
    I have mods
    Took about 2 weeks to receive it. I also got a u-bolt flip kit and the plates were powder coated. It said on the site that the powder coating would cause delays so I imagine that is why it took a couple weeks to arrive.
    They are standard. I gained about 4" of lift in the rear so if they sag some, that should be fine. AAL is easy enough to do when the time comes too.
    synergy10[QUOTED] likes this.
  19. Nov 15, 2018 at 9:04 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    Are we posting license plate pics now?
  20. Nov 15, 2018 at 9:10 PM
    xtremewlr
    Todd
    Tucson, AZ
    I have mods
    I tore my dash apart today to figure out why I could change the temp on the heater controls. Turns out to be the cable running to the valve thing under the hood that opens and closes flow to the heater core. The cable is stiff and tight as shit, even after my best attempts to lubricate it and get it freed up. Time to see if I can order another one and tear the dash apart again once I have one. No so fun. I also replaced the missing vent direction thingy on the passenger side while I was in there. Got one off ebay from a 4Runner but it seems that the ends that allow it to tilt are slightly too small and it just flops around in there. Oh well, at least it isn't an empty hole any more and now I know how to take the dash apart. Fun times. :annoyed:
    SwampYota likes this.
