  1. Nov 17, 2018 at 10:54 AM
    Blue92
    Blue92 Well-Known Member
    Daniel
    North Carolina
    2018 Sport
    First time using fluid film today. Seems similar to the coating Toyota applied years ago. Hopefully the smell will go away in a few days and the drips too. 1117181352.jpg
  2. Nov 17, 2018 at 12:49 PM
    Itchyfeet
    Itchyfeet Well-Known Member
    I sold my snow wheel and tire combo for the Tacoma this morning. I need to figure out how to sell my old leather base leather interior. Seats suck to ship
  3. Nov 17, 2018 at 1:33 PM
    Maine Brain
    Maine Brain Well-Known Member
    Brian
    Florida
    2017 TRD Sport DCLB
    In progress
  4. Nov 17, 2018 at 2:36 PM
    sente3
    sente3 -
    North Jersey
    '04 Xtracab 4x4 V6 5-Speed TRD SR5
    Sliders, rear bumper, front skid, lifted
    In addition to the rear shackles, 33s, rear diff breather relocation, tailpipe chop, 2lo mod, front skid, POR15, and fluid film all done fairly recently, I installed 1.25" Spidertrax I got off FB to get the tires off the frame. Pictures of the new stance. Only rubbed on fender or wheel well once so far. Gotta get a little flexy to see where I need to trim and find out if I need to center the rear axle.
    cali04intx, SwampYota, JPinFL and 2 others like this.
  5. Nov 17, 2018 at 3:17 PM
    Shortman5
    Shortman5 Well-Known Member
    Supercharged TRD
    TRD S/C, ADS coilovers.
    How accurate are these OBD2 scanners to measure HP and torque. Seems high for my setup. This is with the stock supercharger pulley. I’m also getting almost 8psi on my boost gauge (PLX DM-6). Vacc is at 22hg at idle so it doesn’t seem to be off.
    I know the max boost is obviously was off but it’s a estimated not actual.
    EDIT: maybe my cats are clogged causing the boost to be higher?
  6. Nov 17, 2018 at 3:27 PM
    Dustinked
    Dustinked DUSTINKED
    Dustin
    Olympia, WA
    99 tacoma SR5 3.4L V6 Manual
    Spyder Halo projection headlights, Spyder Tail lights, Bilstein 5100s, w/Old Man Emu 881 coils, Bilstein 5125s in the rear, rebuilt front end, balljoints, tie rods, new CV axles, new Rack and Pinion, Old Man Emu Dakar leafsprings, Old Man Emu greaseable shackles, Old Man Emu Exhaust relocation mount, 33"All Country Iron Man Tires, Tinted windows, Replaced rear double slide window with single slide, 8 ball shifter, truck box, And still looking to buy a plate winch bumper.
    Just removed my rear slider window and reinstalled a nicer one that only has one slider. The old one had two that met in the middle. Making it super easy to break in to. The truck looks sleeker now too.IMG_20181117_151352563.jpg
    cali04intx, SwampYota and cruiserguy like this.
  7. Nov 17, 2018 at 3:41 PM
    TacoYankee
    TacoYankee Well-Known Member
    Spotsylvania, VA
    2024 Trailhunter
    It will. Although, the smell becomes somewhat addicting...
  8. Nov 17, 2018 at 3:42 PM
    TacoYankee
    Spotsylvania, VA
    2024 Trailhunter
    550B795A-B550-4986-9308-E37D7CAF8412.jpg Nothing too exciting, just a routine oil change.
    2002Tacoma4x4, SwampYota and Brice like this.
  9. Nov 17, 2018 at 3:50 PM
    Blue92
    Daniel
    North Carolina
    2018 Sport
    It gave me a scare when I came back after driving it when there was smoke coming from the engine area. I forgot I did the frame right next to the headers. Guess it was burning off.
  10. Nov 17, 2018 at 4:06 PM
    TacoYankee
    Spotsylvania, VA
    2024 Trailhunter
    I did the same thing. Also sprayed inside the doors as long the bottom, hinges and strikers, so the smell was inside the cab for a week or two.
  11. Nov 17, 2018 at 4:21 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Not accurate.
    My dads says his hits 375+ a lot. No way its that high.
  12. Nov 17, 2018 at 4:46 PM
    Shortman5
    Supercharged TRD
    Yeah I figured that. Don’t know why it even tries to calculate it if it’s that far off.
    I’m still wondering about my boost pressure. Shouldn’t be getting 7.98psi with a stock pulley. I’ll have to hook up the r4 software to see what that reads.
  13. Nov 17, 2018 at 4:49 PM
    Poncate
    Poncate Well-Known Member
    PNW
    04 DCSB 4x4
    2002Tacoma4x4 and cali04intx like this.
  14. Nov 17, 2018 at 4:50 PM
    Blue92
    Daniel
    North Carolina
    2018 Sport
    I didnt do any of that as I'm only in NC so salt isnt too bad. My truck is from VA so i wanted to stop any rust that is already there, mainly on the rear axle and crossmembers. The frame was sprayed by Toyota in 2010 and that coating is starting to flake off, so I decided it would be a good idea to coat it myself every few years or so. So far I like the product but needless to say I was a bit alarmed to see smoke coming out of my engine lol.
    TacoYankee[QUOTED] likes this.
  15. Nov 17, 2018 at 5:09 PM
    Wulf
    rock raisin
    Hmm, sounds like you have the same issue with the circuit but maybe your lights require more voltage to light. I suppose a workaround would be to add a relay powered when the ignition is on to orient any drain when the truck is off. Bit sure what I want to do yet
  16. Nov 17, 2018 at 5:26 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Wouldn't trust that either. Just rely on your gauge.
  17. Nov 17, 2018 at 6:13 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    They're a complete guess unless you calibrate everything and even then they're not great.
  18. Nov 17, 2018 at 6:25 PM
    Speedytech7
    The R4 will show you in absolute so be prepapred to modify that value
  19. Nov 17, 2018 at 6:34 PM
    Shortman5
    Supercharged TRD
    I’m not sure I understand. Both my gauge and the 7th software tell me HG/PSI. And as far as I can remember they were both pretty close when tuning.
  20. Nov 17, 2018 at 7:23 PM
    kuntry09
    kuntry09 Well-Known Member
    Cam
    Douglas, Georgia
    '99 extended cab Tacoma 4x4 converted Prerunner
    Mine are the CaliRaised side kick ditch lights, so I wouldn’t think they would take that much or certainly no more voltage than a light bar. It seems to be a very slow drain, if it sits for a few days.
