  1. Nov 19, 2018 at 3:08 PM
    eon_blue
    Azusa, CA
    Checked those, they're tight at 90ft/lbs...shackle and main bolts are torqued too
  2. Nov 19, 2018 at 3:09 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Exhaust hangers next then and then any bolt youvey touched in the last year
    eon_blue[QUOTED] likes this.
  3. Nov 19, 2018 at 3:10 PM
    eon_blue
    Azusa, CA
    ya I've had back luck with those rubber hangars breaking on me in the past. I'll give them a check
  4. Nov 19, 2018 at 3:12 PM
    Dan8906
    Dan8906 Well-Known Member
    Daniel
    Concord, California
    2004 Tacoma ext cab TRD 4x4
    CBI sliders, ADS extend travel with compression adjuster coil overs, 9” Bilstein 5125 rear shocks, Icon Tubular UCA, Alcan custom leafs, All Pro Apex bumper and skids, NWTI rear diy bumper, 295/70/17 Cooper St Maxxs and nitro 4.88s.
    do or dont go with bamf?
  5. Nov 19, 2018 at 3:14 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Bamf slider have a 8" kick out. It's huge. Even with my 2.5" B's with 12.5 wide tires they are still wider.
    If you aren't gonna be that wide if stance the 4xi one's will work great. Can't beat the price and lots of rigs beat on those just fine
    Dan8906[QUOTED] likes this.
  6. Nov 19, 2018 at 3:19 PM
    drr
    drr Primary Prognosticator
    Dan
    Seattle-ish
    02 4WD Tacoma
    Broken leaf spring? Hard to see sometimes as they break right at the center pin, under the u-bolt plate.
    When’s the last time you greased your driveshaft? :rimshot:
  7. Nov 19, 2018 at 3:27 PM
    eon_blue
    Azusa, CA
    man I hope it's not a broken leaf spring lol, I had my leafs apart 3 times last summer.
    Driveshaft was fully greased *giggity* maybe 3k miles ago, I usually hit it every couple oil changes or thereabouts.
  8. Nov 19, 2018 at 3:49 PM
    jubei
    jubei would rather be doing something else
    NoCo
    White 2002 XC TRD and Yellow 1971 JEEP CJ5
    Stuff. Also things.
    Took an amazing winter drive to Estes Park with my lady last weekend in the middle of a mild winter storm. The truck did great on some relatively sketchy roads, but by the time we got back home there was a crap ton of mag chloride on her, so I gave her a good wash. My dude had a blast rinsing her off!
  9. Nov 19, 2018 at 3:52 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    Were the elk still rutting?
  10. Nov 19, 2018 at 3:58 PM
    jubei
    NoCo
    Stuff. Also things.
    Not at all that I could tell, but I’m no hunter. There weren’t any in town like there typically are during the warmer months.
  11. Nov 19, 2018 at 4:00 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    So an elk didn't try and push its way up on to you then :p
  12. Nov 19, 2018 at 4:02 PM
    jubei
    NoCo
    Stuff. Also things.
    :rofl:
    Thankfully no.
    Speedytech7[QUOTED] likes this.
  13. Nov 19, 2018 at 4:13 PM
    JKO1998
    Utah
    My family goes and spends about a week there early October, guess that place is full of elk around then
  14. Nov 19, 2018 at 4:13 PM
    Jonyd182
    Jonyd182 What do you mean I can't go up there...Watch this!
    Jonathan
    Columbia, SC
    '99 SR5 TRD 3.4
    Armored to the teeth, 35's, Crawlbox, Boxed Frame
    I had to go with trail gear since they're basically the only player in town now. Marlin is no longer accepting orders and does not have an eta on when they will receive materials to start production again. I tried to buy a Marlin 3 years ago and after putting down a 100% deposit I waited almost a year before I gave up and pulled my deposit back. An Iconic brand and product but it always seems like they have some major issue they're working thru that equal insanely long lead times.
    I haven't tested the Trail Gear yet but so far I have no complaints. Their customer service and specifically their technician Lincoln has been amazing throughout the install for me. Plus they have them in stock. It was in my lap a week after I placed the order.
    The triple stick is a PITA and was probably more work than the crawler..lol Be prepared for a lot of beer and hammering :cheers::frusty:. I'm a big fan of RADesign and so far the triple stick is looking pretty good. The levers have more play in them then my twin stick did; but I might be able to tighten it up a bit more.
    jubei[QUOTED] likes this.
  15. Nov 19, 2018 at 4:14 PM
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    Nailed it
    4x will be good for your needs
  16. Nov 19, 2018 at 4:23 PM
    Itchyfeet
    Itchyfeet Well-Known Member
    I pulled the Limited seats out and put the stock ones back in. I'd like to sell the Limited seats, but shipping is going to suck and I live where this type of stuff just doesn't sell.
    Might as well throw the fuckers in the burn pile considering all the money I have tied up in them
    cruiserguy likes this.
  17. Nov 19, 2018 at 4:32 PM
    drr
    Dan
    Seattle-ish
    02 4WD Tacoma
    I thought you figured out all you need is the raised trim piece for the outside seat bolt?
  18. Nov 19, 2018 at 4:39 PM
    Itchyfeet
    I would still have to grind the shank off the bushing insert, plus there's still the issue of the lumbar knob being useless as it butts up against the console.
  19. Nov 19, 2018 at 4:44 PM
    jubei
    NoCo
    Stuff. Also things.
    Thanks, man!
    Your experience with Marlin isn’t surprising. They took over six months to deliver my TacoBox after the last big redesign.
    I’ve heard the same thing about the triples install! Hopefully the 1” body lift will help alleviate that a bit, which was the biggest reason I went with one. That’s interesting about the play in the shifters, though. I’ll be looking forward to hearing if you can tighten them up.
    Do you have a build thread on TW?
  20. Nov 19, 2018 at 4:44 PM
    JKO1998
    Utah
    Do the earlier years have a different cab floor layout or something?
