  1. Nov 22, 2018 at 6:38 AM
    Reh5108
    Reh5108 Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    Mine does not keep up when wheeling. Black truck an the desert sun don't help though.
    I'd be willing to bet the shop pushed the retaining ring that the seal should mate with on too far. I've had a dealer do this. If you have abs you can look in the hole and see it's not right. Or pull the axle, smear some grease on the ring and put it back in and spin it. Pull it back out and it should give you an idea where the seal sits on the ring.
    jubei and 2002Tacoma4x4[QUOTED] like this.
  2. Nov 22, 2018 at 6:40 AM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    As said it's likely an install mess up with the retainer ring. Even the dealership has been known to fuck up that.
    2002Tacoma4x4[QUOTED] likes this.
  3. Nov 22, 2018 at 8:27 AM
    drr
    drr Primary Prognosticator
    Dan
    Seattle-ish
    02 4WD Tacoma
    Wait, $800 in parts??? For each side, you need 1 seal, 1 bearing, 2 bearing retainers, and 1 ABS skid control rotor (tone ring). Plus replace the brake shoes if they got soaked, and refill the gear oil in the diff. You're talking maybe $150 total for all OEM parts.
    If you paid a dealership $800 for parts alone, you got scammed bad.
  4. Nov 22, 2018 at 8:34 AM
    95redrocket
    95redrocket Member
    Vinny
    Northern New Brunswick, Canada
    1995 Extracab 2.7 4WD 5speed Tacoma
    Installed the pioneer DEH-S400BT head unit on my base model tacoma. Quite the upgrade from the stock radio only headunit and the sound is great. Wired the bluetooth mic to come out by the steering wheel in the spot the later models have the airbag on/off. Total cost was 150 canadian.
    cruiserguy likes this.
  5. Nov 22, 2018 at 9:10 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Ah...
    No.
    Cost me about 600 in parts from the dealer with no tone rings.
    The bearings are expensive. And dealership prices are never cheap.
    It's not a 150 setup no matter what
    Reh5108, chrslefty and JKO1998 like this.
  6. Nov 22, 2018 at 9:33 AM
    drr
    Dan
    Seattle-ish
    02 4WD Tacoma
    Bearing Retainer - P/N 42423-20010 - $16.80 each
    Oil Seal - P/N 90310-50006 - $5.71
    Skid Control Rotor - P/N 43517-35010 - $46.62
    Bearing - P/N 90363-40068 - $59.26
    Total = $145.19
    Those are prices from Camelback. And I didn't have that bearing cost in mind, I just bought a Timken that matches the OEM exactly for probably 1/4 of the price. So add in brakes and gear oil, maybe $175?
    Edit: scratch that, I bought the bearing from the dealer too, which is apparently a Timken.
    cruiserguy and 2002Tacoma4x4 like this.
  7. Nov 22, 2018 at 9:45 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Hm ihad no choice when I did mine. I think I paid close to 600 or 400 for both sides.
    2002Tacoma4x4 likes this.
  8. Nov 22, 2018 at 9:56 AM
    drr
    Dan
    Seattle-ish
    02 4WD Tacoma
    Yeah for both sides with brakes and all, 400 is about right.
    Speaking of which, I still need to replace that drivers side shaft and do the seal and bearing. I'm sure that'll be cheap. Are there any good aftermarket axle shafts short of 300m shafts?
  9. Nov 22, 2018 at 10:01 AM
    2002Tacoma4x4
    2002Tacoma4x4 TRD 4x4 double cab
    C K
    Limited Edition Double Cab TRD off road 4WD
    You’re all right ... installation can be where the mess up occurred
    On the 580 job 2yrs ago i bet was not OEM parts, invoice was 190 on parts you mentioned the rest just labor. 2week ago breather got changed $47 and they said they did the seal again somehow I doubt it.
    Fact is that toyota dealer diagnostic axle shaft to be replaced (upgraded part) 2yrs ago for over $3K changing drums and shoes at both sides.
    Now 11-17-18 i took it leaking for diagnostic and didnt mentioned the seal was already changed, then they quote the parts and oil seal all of you mentioned with labor for $990, was late then I told the advisor that another shop already did that , so if we continue to do the same , we will get same results, i leave truck there and returned early morning Monday to pick up as is ( leaking) then they changed the quote to $2K now including the replecement of the 1 side axle shaft .....to be continue...:annoyed:
  10. Nov 22, 2018 at 10:02 AM
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    There's a few options, all with some nuances.
    Do you have ABS and/or and elocker axle? If so, it doesn't leave you with many options. I put in some Yukon chromoly shafts this spring to replace a bent one, and have no complaints.
    jubei and drr[QUOTED] like this.
  11. Nov 22, 2018 at 10:05 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    As Brett said the chromoly axles from Yukon or nitro and kind of the only options.
    Or go guy a junk yard Ford 9 haha
    drr[QUOTED] likes this.
  12. Nov 22, 2018 at 10:15 AM
    drr
    Dan
    Seattle-ish
    02 4WD Tacoma
    Thanks gents. I have neither ABS nor an elocker, thank god for that lol
    Still working on getting an FZJ80 or LX460 9.5" housing for a reasonable price, that would be my first choice. Not sure I could live with myself if I started putting Ferd parts on my truck.
  13. Nov 22, 2018 at 10:19 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    I could. Plan to actually. Can't beat a 9in for under 300 haha
    An fzj80 would be my choice for Igor though. But people are way to proud of those for some reason
  14. Nov 22, 2018 at 10:34 AM
    drr
    Dan
    Seattle-ish
    02 4WD Tacoma
    Yeah for straight beating on that's a good choice. I'd like to keep it toyota if at all possible, I found a 9.5" for 400 but it's a ways down the coast, not sure how to get it up here haha
  15. Nov 22, 2018 at 10:53 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    That a decent price. Really good if it's the elocker.
    Someone must be close by that could meet you half way?
  16. Nov 22, 2018 at 10:57 AM
    drr
    Dan
    Seattle-ish
    02 4WD Tacoma
    SoCal, so halfway is still a long ways haha. Might be able to make something work, we'll see.
    Not an e-locker, definitely prefer an airlocker in there since I'll be doing gears anyway.
  17. Nov 22, 2018 at 11:01 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    True true. That's not bad then. Little high for an open but I'm with you.
    You could make it happen!
  18. Nov 22, 2018 at 11:07 AM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    I did the dog box mod, the best mod.
    will e, Taco Addiction and m3bassman like this.
  19. Nov 22, 2018 at 11:18 AM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Happy Thanksgiving Tacoma folks!
  20. Nov 22, 2018 at 11:59 AM
    Dan8906
    Dan8906 Well-Known Member
    Daniel
    Concord, California
    2004 Tacoma ext cab TRD 4x4
    CBI sliders, ADS extend travel with compression adjuster coil overs, 9” Bilstein 5125 rear shocks, Icon Tubular UCA, Alcan custom leafs, All Pro Apex bumper and skids, NWTI rear diy bumper, 295/70/17 Cooper St Maxxs and nitro 4.88s.
    Anyone know why it would be wet at the floor boards on the driver side. It rained yesterday. I have weatherguaed floor mats and as I am vacuuming it today it has a ton of moisture under the mat
    Crodell6 likes this.
