  1. Nov 28, 2018 at 8:51 PM
    drr
    drr Primary Prognosticator
    Dan
    Seattle-ish
    02 4WD Tacoma
    PCV valve? Just presses into a grommet in the valve cover. The valve could be bad, never heard one make a whistling noise though. They're cheap and should be replaced periodically, get a new grommet for it while you're at it. Just be careful pulling it out, if the grommet is old enough it will crack and fall into the valve cover.
  2. Nov 28, 2018 at 8:54 PM
    Adude
    Adude Well-Known Member
    Pnw
    04 Double cab
    I pulled all the shims in between all the leafs. It eliminated the squeaky noises. There is no more lead on dirt on leaf rubbing.
  3. Nov 28, 2018 at 8:58 PM
    eon_blue
    Azusa, CA
    Tacomas supposedly have 'lifetime' fuel filters too but it's not uncommon for them to get clogged up and start effecting performance...on our 3.4s it's really easy to change out and they're like $20
  4. Nov 28, 2018 at 9:27 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    They say it is, but it must have had some bad buildup because a new one fixed her right up. I keep meaning to take the time and pull the injectors to have them cleaned and flow tested, but I need to get the Z running before I pull it apart again
  5. Nov 28, 2018 at 9:53 PM
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    i would get a new PCV gasket.. its likely going to fall apart being as old as it is.
    Crodell6 likes this.
  6. Nov 28, 2018 at 10:29 PM
    drr
    Dan
    Seattle-ish
    02 4WD Tacoma
    Does either one leak out of the valve cover gaskets at all? If the valve plugs up, it'll start pushing oil past the gaskets.
  7. Nov 28, 2018 at 10:41 PM
    Speedytech7
    How are valve covers not in your wheelhouse, you changed a timing belt, thats much more work
  8. Nov 28, 2018 at 10:44 PM
    Empty_Lord
    Dan
    V/C gaskets arent bad, just time consuming. Honestly ive never had a PCV go bad on a toyota. but theyre cheap so might as well replace it
    xtremewlr likes this.
  9. Nov 28, 2018 at 10:45 PM
    Speedytech7
    much bigger opportunity to fuckup timing an engine than changing VC, just the valve train is exposed anyway, not much you can do there to mess it up, just dont leave a socket in there or something
  10. Nov 28, 2018 at 10:47 PM
    Empty_Lord
    Dan
    ive seen more issues from people leaving towels in the intake ports when doing v/c gaskets instead of anything actually in the engine being a problem lol
  11. Nov 28, 2018 at 10:48 PM
    Speedytech7
    This is why i just stretch a glove over instead of use rags.
    jubei likes this.
  12. Nov 28, 2018 at 10:49 PM
    Speedytech7
    You wanna come set the timing on my Z, no pressure, it's just interference and completely untimed right now haha
  13. Nov 28, 2018 at 10:50 PM
    Empty_Lord
    Dan
    painters tape is my weapon of choice
  14. Nov 28, 2018 at 10:50 PM
    Empty_Lord
    Dan
    toyota 4.7l engines are fun... we had a tech get the mark on the crank 1 tooth off. needless to say he had to replace and engine for free
    Speedytech7[QUOTED] likes this.
  15. Nov 28, 2018 at 10:52 PM
    Empty_Lord
    Dan
    mitsubishi is fun. theres 2 timing belts. and oil pumps have to be in the right spot because theyre also balance shafts.. theres no easy way to know if theyre right.
    Speedytech7 likes this.
  16. Nov 28, 2018 at 10:53 PM
    Speedytech7
    I guess I actually have around four if you count the distributor, I have to do it from the beginning because I disassembled the whole engine. But they basically give you zero excuse to do it wrong, line up all the marks, they tell you how many teeth to count off on the belt in between everything, and they even tell you how to find TDC without any of the tools haha
  17. Nov 28, 2018 at 10:54 PM
    Speedytech7
    4G63 life haha, done that job before, done VG30DETT once too.... that's fun
  18. Nov 28, 2018 at 10:56 PM
    Empty_Lord
    Dan
    mitsu and some ford timing belts are literal hell. i forget which engine but ford has an engine that you HAVE to lock the crank and cams before removing the belt or you WILL bend valves
  19. Nov 28, 2018 at 10:58 PM
    Speedytech7
    I know you have to lock them on the Duratec V6 when you remove a chain to do the waterpump or it'll snap em
    Running Board Man likes this.
  20. Nov 28, 2018 at 10:58 PM
    Empty_Lord
    Dan
    just be grateful toyota makes some of the easiest to work on cars out of all the major car brands
