  1. Nov 29, 2018 at 7:11 AM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    :der:
    super easy. However,
    Not to do the whole OEM thing again but my aftermarket gaskets from Rockauto leaked badly when I put it back together. So spring for the OEM ones. Im going to have to re do it. You need FIPG too to do the half moons.
  2. Nov 29, 2018 at 7:16 AM
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    There’s a engine stiffener that is also technically the oil pan. The. The oil pan were use to is bolted to it
  3. Nov 29, 2018 at 7:18 AM
    Empty_Lord
    Dan
    Trucks in general are easy. Much more room. As for fwd vehicles. Toyota and Honda are the two easiest to work on.
  4. Nov 29, 2018 at 7:21 AM
    burntkat
    burntkat Well-Known Member
    Phillip
    Charleston, SC
    97 Extracab Tacoma
    What is "FIPG"?
  5. Nov 29, 2018 at 7:26 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Form In Place Gasket
  6. Nov 29, 2018 at 7:31 AM
    burntkat
    Phillip
    Charleston, SC
    97 Extracab Tacoma
    So, RTV??
  7. Nov 29, 2018 at 7:34 AM
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    Might need an extension with a wobble end or a u-joint. Don't think you do, but don't recall for sure.
    If you do use a ujoint, wrap it in electrical tape first so it doesn't flop all over the place.
    I used the blue felpro gaskets from the parts store. They've been fine for a few years.
    m3bassman[QUOTED] likes this.
  8. Nov 29, 2018 at 7:41 AM
    Squeaky Penguin
    Brett
    :thumbsup:
    I still don't recall which bolt that is, but like I mentioned, I pulled the AC compressor when I did my TB. Not sure which way is more work. :notsure:
    Surely Monte owns a torque wrench. :cookiemonster:
    jubei likes this.
  9. Nov 29, 2018 at 7:50 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    torque is only 53in/lbs btw. Mine practically spewed oil at that.
  10. Nov 29, 2018 at 7:50 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    2 :luvya:
  11. Nov 29, 2018 at 7:51 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Not if you don't undo any lines. If you crank a line, discharged.
  12. Nov 29, 2018 at 7:52 AM
    Squeaky Penguin
    Brett
    That looks like a pain in the dick.
    Takes a few minutes to pull the ac compressor and bracket, and does not discharge the system. You just move it out of the way with the lines connected.
    Sometimes the time saving method doesn't save you any time...
    burntkat likes this.
  13. Nov 29, 2018 at 7:53 AM
    Blue92
    Blue92 Well-Known Member
    Daniel
    North Carolina
    2018 Sport
    Add Kia/Hyundai to that. Pretty simple stuff.
  14. Nov 29, 2018 at 8:00 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Okay by that way of counting, 3. 1/4'', 3/8'' and Massive German one.
  15. Nov 29, 2018 at 8:34 AM
    Blackdawg
    Monte
    Wyoming/St. Louis
    :facepalm:
    Super missremember that!
    its really low no matter what. Didn't work for me, i had to way past that.
  16. Nov 29, 2018 at 9:18 AM
    Phessor
    Phessor Well-Known Member
    Got my Stubbs Welding HD-SKO sliders installed!
  17. Nov 29, 2018 at 11:30 AM
    Empty_Lord
    Dan
    I’ve had luck with my covers staying dry after factory spec and blue loctite
  18. Nov 29, 2018 at 12:11 PM
    burntkat
    Phillip
    Charleston, SC
    97 Extracab Tacoma
    Where did you get those dash light brackets from?
  19. Nov 29, 2018 at 12:48 PM
    Phessor
    burntkat[QUOTED] and xtremewlr like this.
  20. Nov 29, 2018 at 2:03 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Yall are using torque specs for a big squishy rubber gasketed cover? Just snug it up and let the FIPG set before you give it one more round of snugging. Don't over think it
    Seagull233, cruiserguy and burntkat like this.
