  1. Dec 1, 2018 at 12:24 PM
    El Taco Diablo
    El Taco Diablo Professional Pinstriper
    Matt - KN6DZP
    Hughson, CA
    Impulse Red DC, 5vz-fe, 4wd swap, LT, dual case, F/R locked
    Just 3 tons of fun!!!
    I'm interested in doing this. How's the install? Does it mount to factory location, or is there modifications that are necessary?
    burntkat likes this.
  2. Dec 1, 2018 at 12:25 PM
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    That looks like what I'll be doing soon.
    jtb1798[QUOTED] likes this.
  3. Dec 1, 2018 at 12:43 PM
    xcmtb83
    xcmtb83 Well-Known Member
    Iowa
    I almost ordered the +130 until I learned the +120 are brighter and less filtered.
  4. Dec 1, 2018 at 1:05 PM
    xtremewlr
    xtremewlr Well-Known Member
    Todd
    Tucson, AZ
    2003 4Runner V8 - 2012 b00sted XRunner
    I have mods
    Install isn't too bad, hardest part was fishing the wires through the roof, down the pillar and out the firewall, figuring out where I wanted them to go. The mirror needs a glue on windshield mount. I went to Safelite and had them do it since I had a rock chip I wanted repaired while I was there. Otherwise, drop the front of the headliner to run the wires and that's about it. Easy.
    From what I saw, the +130 are a little brighter on low beam and only high bean is filtered. They are both better than stock either way.
  5. Dec 1, 2018 at 1:37 PM
    xcmtb83
    Iowa
    burntkat, SwampYota and lucky13don like this.
  6. Dec 1, 2018 at 1:52 PM
    lucky13don
    lucky13don Well-Known Member
    Don
    Milton, fl
    R.I.P.04 tacoma prerunner, 04 sequoia 4x4
    Too many to list
  7. Dec 1, 2018 at 1:52 PM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    Upgrading to this cool shifter console with the cup holders today. The heat gun trick works wonders when restoring scratched up plastic. I had to steal that bracket on the bottom from the 5-Lug so it would mount properly to my 4Runner shifter console.
    Also putting in new 3D printed shifter bushings to stop my truck from shifting into Neutral randomly. Pretty sure the 300k mile 4Runner I took the shift console from had long disintegrated shifter bushings. (Thanks @Brice!)
  8. Dec 1, 2018 at 1:55 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    I have one too. Mine is the Gentex 313 with HomeLink from a 2012 Nissan Titan.
  9. Dec 1, 2018 at 2:02 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    Ol Gray helped find another today
    58D7A139-934E-4E05-924F-FBCA13C3D944.jpg 12B39D9B-0B43-4973-8BFB-04613DE6F791.jpg
    Dalandser and xtremewlr like this.
  10. Dec 1, 2018 at 2:05 PM
    Brice
    Brice Turbo Member
    Brice
    Texas
    1999 Tacoma PreRunner V6 SR5
    Wastegate assisted turbo delete
    No worries! Let me know how they turn out!
  11. Dec 1, 2018 at 2:08 PM
    Dan8906
    Dan8906 Well-Known Member
    Daniel
    Concord, California
    2004 Tacoma ext cab TRD 4x4
    CBI sliders, ADS extend travel with compression adjuster coil overs, 9” Bilstein 5125 rear shocks, Icon Tubular UCA, Alcan custom leafs, All Pro Apex bumper and skids, NWTI rear diy bumper, 295/70/17 Cooper St Maxxs and nitro 4.88s.
    What year is that from?
  12. Dec 1, 2018 at 2:09 PM
    Dan8906
    Daniel
    Concord, California
    My truck must have heard talking about getting spare CVs. Passenger side has some grease on the shaft. Not a ton but some. I’ll have to take a better look at it tomorrow
  13. Dec 1, 2018 at 2:11 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    Think it was a 2001. Toyota made em for the whole generation, only difference is the interior color change between 2000 and 2001. My 5-Lug has it too, albeit in 5-Speed form.
    This is perfect since it’ll match my 2004 center console. I have a 1999 shifter trim and it’s mismatched.
    Dan8906[QUOTED] likes this.
  14. Dec 1, 2018 at 2:19 PM
    Dan8906
    Daniel
    Concord, California
    I’ve been considering the marlin Taco box at some point, so I’ll lose a cup holder to the shifter. So adding another one would be cool
  15. Dec 1, 2018 at 2:44 PM
    Reh5108
    Reh5108 Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    Check your valve lash while you're in there, unless that's what you were doing in the first place. It's common that they get tight over time.
  16. Dec 1, 2018 at 3:41 PM
    xtremewlr
    Todd
    Tucson, AZ
    I have mods
    Yup, yours is one of the guys I was referring to. I didn't want or need homelink so I went with the 177.
  17. Dec 1, 2018 at 3:54 PM
    xtremewlr
    Todd
    Tucson, AZ
    I have mods
    OK, I just lubed all the zerks that I could find on the truck because I just got a new tool. I don't know if you guys have seen or heard of LockNLube stuff but you have to go check them out. Lubing all grease fittings is so simple now with this thing. It really does work as advertised. And I'm not getting paid or asked to post this. This thing just fucking rocks.
    I got the $30 one and it's worth the cost.
    https://locknlube.com/collections/locknlube-grease-coupler
    And I just ordered the 90 degree coupler since I had one fitting that I couldn't get anything on, the driver side lower ball joint fitting.
    https://locknlube.com/collections/greasing-accessories/products/push-on-90-grease-coupler
    burntkat, 2002Tacoma4x4 and Reh5108 like this.
  18. Dec 1, 2018 at 4:09 PM
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    Hopefully someone here has done this mod.
    I want to change the lighting in my instrument cluster, heater controls, shifter etc (essentially the whole dash).
    I'm hoping someone can tell me what bulbs they used. I don't want to tear the whole dash apart to figure it out.
  19. Dec 1, 2018 at 5:28 PM
    lucky13don
    Don
    Milton, fl
    Too many to list
    Check with @BartMaster1234 , hes the guy that's done it..on a couple trucks.
    BartMaster1234 likes this.
  20. Dec 1, 2018 at 5:37 PM
    jp59inh
    jp59inh Well-Known Member
    02 Tacoma Extra cab 4x4
    None yet
    I love when UPS shows up , but I hate waiting for the rest of my parts ! 41C4B0A7-FDDF-434D-AA70-191B82EDFFB4.jpg
    SwampYota and 2002Tacoma4x4 like this.
