  1. Dec 9, 2018 at 8:52 PM
    El Taco Diablo
    El Taco Diablo Professional Pinstriper
    Matt - KN6DZP
    Hughson, CA
    Impulse Red DC, 5vz-fe, 4wd swap, LT, dual case, F/R locked
    Just 3 tons of fun!!!
    You gotta remember... Tundras came with the same 16 inch wheels the 1st gen TRDs came with.
    This is my Tundra brakes behind my stock 16 inch wheels.
  2. Dec 9, 2018 at 9:08 PM
    Adude
    Adude Well-Known Member
    Pnw
    04 Double cab
    And they should fit behind your spare as well, have you checked
  3. Dec 9, 2018 at 9:19 PM
    drr
    drr Primary Prognosticator
    Dan
    Seattle-ish
    02 4WD Tacoma
    All 16" Toyota spares fit over Tundra calipers as well, I've tried 1st gen and 2nd gen 16" spares.
    Edit: although I did have 1" spacers on, not sure if that would change fitment. Might be a good thing to doublecheck.
  4. Dec 9, 2018 at 9:23 PM
    Adude
    Pnw
    04 Double cab
    Thats what I thought and my measurements concurred. Then a band wagon of -no steelies fit with tundra calipers - started. I have had no issues. :deadhorse:
  5. Dec 9, 2018 at 11:44 PM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    Only certain Steelies won’t fit. @turbodb has an excellent article on it on his website.
    turbodb likes this.
  6. Dec 10, 2018 at 12:03 AM
    will e
    will e Well-Known Member
    World Wide
    04 pre-runner
    Dominic Toretto Tuned with Extra Blinker Fluid
    I have the Tundra Brake upgrade on my 2wd 2004 and so far 16" american Racing "Outlaw 11's" & my 16" Method "double standard"
    would not fit with out using a spacer & im running the 1.5 All Pro spacers
  7. Dec 10, 2018 at 12:25 AM
    pittim
    pittim mittip backwards
    Pennsyltucky
    Boujee Prius
    It’sa Lexus, boogie woogie woogie
    There's 2 tundra brakes. One is smaller (193mm iirc) and is what was recalled. The bigger ones are 231mm (iirc) and came standard behind the 17" wheels.
  8. Dec 10, 2018 at 6:14 AM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    My little cats are a handful. Can't imagine being blindsided by that monster on a hike. Damn!
  9. Dec 10, 2018 at 6:41 AM
    FirstTimeFirstGen
    FirstTimeFirstGen Less active than most
    David
    Pacifica
    2004 4WD 3.4L Tacoma (Manual)
    Not enough to have a build thread.
    You trying to say something about my phone? :p
    Fernando[QUOTED] likes this.
  10. Dec 10, 2018 at 7:12 AM
    turbodb
    turbodb AdventureTaco
    Dan
    PNW
    2000 Tacoma Xcab 4x4 SR5 V6 TRD
    AdventureTaco
    ...Our stomachs satisfied for the moment, we continued down the mountain - only a single planned overlook between us and the bottom, our road spitting us out near the confluence of the Bighorn and Devil's Canyons which we could already see in the distance... it was at this overlook that tragedy struck. (Tragedy is perhaps a bit strong a word to use in this case, but what unfolded was definitely a bummer...)
    Fnd out what happened, and photos from this amazing day: The Re-Tour Day 6: Into the Abyss
    --- catch up on the whole story so far ---
    [day 1] [day 2] [day 3] [day 4] [day 5] [day 6] ​
    xtremewlr likes this.
  11. Dec 10, 2018 at 7:29 AM
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
    All SCS 16" rims will fit the Tundra Brake, but most 16" rims fit either way. There's a thread on one of the 4Runner sites that has a list of compatible rims (it's a bit dated now tho)
  12. Dec 10, 2018 at 8:02 AM
    turbodb
    Dan
    PNW
    AdventureTaco
    Another 10% ebay coupon today...looks like for automotive categories:
    How to redeem your Coupon:
    1. Shop for eligible items. (See below for exclusions).
    2. Enter the Coupon code in the redemption code field: PEDAL2METAL
    3. Pay for your item by 11:59 PM Pacific Time on December 10, 2018
    Terms & Conditions:
    The Coupon is a 10% discount, valid from 4:00 AM PT on December 10, 2018 until 11:59 PM PT on December 10, 2018. No minimum purchase required. The Coupon discount is capped at a maximum value of $100. Discount applies to the purchase price (excluding shipping, handling, and taxes) of an eligible item on ebay.com, ebay.ca, and cafr.ebay.ca. Eligible items include items purchased from the following categories: Parts & Accessories, Tools & Workshop Equipment, Vehicle Electronics & GPS, Transportation, and Light Equipment & Tools. Coupon must be used within a single transaction (and can include multiple eligible items), while supplies last. Max one redemption per user.
  13. Dec 10, 2018 at 8:22 AM
    xtremewlr
    xtremewlr Well-Known Member
    Todd
    Tucson, AZ
    2003 4Runner V8 - 2012 b00sted XRunner
    I have mods
    Got my brake lines installed and the new clutch line done yesterday. I also ended up with a new brake master cylinder since I managed to order the wrong replacement reservoir. I didn't want to spend all the time draining the reservoir to change the front brake lines and not have a nice, clean one that I could see the fluid level in. I also rationalized that it was the original master with over 315k miles on it so it wouldn't hurt to replace the whole thing at one go. Turned into more of a pain in the ass then expected and I manager to get brake fluid EVERYWHERE. But the job is done now and brakes and clutch are bled and everything is working great. And I removed the sway bar while I was at it.
    New Crown lines, I'm sure everyone has seen similar before. Only the front lines since the rear got a new line when I did the leafs. The original lines were definitely showing their age.
    The original brake master cylinder. This is why I wanted to at least replace the reservoir. Even shining a flash light thru the opposite side, it was hard to verify the fluid level. But since I screwed up on the replacement reservoir, I ended up running down to the parts store and they fortunately had a new, non-ABS master with reservoir in stock.
    This was the replacement reservoir. Looks like it fits but it was leaking fluid out of the rubber grommets in the laster, which I also replaced. My bad for thinking that a newer, 2003, non-ABS reservoir would be the same as my 1999 non-ABS reservoir. They aren't and have different mounts to the master.
    So that came out spilling brake fluid all over the place, and then in with the new and correct master cylinder. Which also spilled brake fluid all over the engine bay after bench bleeding it in the truck and then me failing to get the brake lines attached before the reservoir emptied out. I just could not get the tube nuts started into the master for the life of me and ended up having to unbolt the master again, get the flare nuts started and then reattach the master. Such a mess!
    Then I was able to get to the clutch line. The OEM one had seen much better days.
  14. Dec 10, 2018 at 8:26 AM
    loosnut
    loosnut Well-Known Member
    jerry
    feasterville pa
    06 dbl cab long bed
    ome 2.5lift leer cap
    I like it.
  15. Dec 10, 2018 at 8:33 AM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    Erm, no?
    I think he might be in the this forum though
  16. Dec 10, 2018 at 8:35 AM
    jubei
    jubei would rather be doing something else
    NoCo
    White 2002 XC TRD and Yellow 1971 JEEP CJ5
    Stuff. Also things.
    How much total backspace are you running again, Dan?
  17. Dec 10, 2018 at 9:49 AM
    Dan8906
    Dan8906 Well-Known Member
    Daniel
    Concord, California
    2004 Tacoma ext cab TRD 4x4
    CBI sliders, ADS extend travel with compression adjuster coil overs, 9” Bilstein 5125 rear shocks, Icon Tubular UCA, Alcan custom leafs, All Pro Apex bumper and skids, NWTI rear diy bumper, 295/70/17 Cooper St Maxxs and nitro 4.88s.
    Maybe I missed it but what was the tragedy lol
  18. Dec 10, 2018 at 9:49 AM
    Reh5108
    Reh5108 Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    I think most steelies need a 1/4" spacer to clear tundra calipers FWIW
  19. Dec 10, 2018 at 9:53 AM
    turbodb
    Dan
    PNW
    AdventureTaco
    Monte dropped his prized (b/c he uses it so much) wide angle lens (10-18mm) off the cliff.
    This was a look of ":annoyed: :censored: :facepalm:"
    ...it's since been replaced, since he could never really be without that lens.
  20. Dec 10, 2018 at 9:58 AM
    turbodb
    Dan
    PNW
    AdventureTaco
    Here's my post where (at the very end) I cover the spare steelies that fit/don't fit (bare - I wasn't using any spacers).
    New-to-me tires and Tundra Brake Upgrade
