  1. Dec 11, 2018 at 1:33 PM
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
    Donahoe CO, Donahoe Rear Resi, Deaver J59, 16" Pro Comp, 33" BFG AT, Hayden Trans Oil Cooler, Oil Filter Relocator, FM 40, ES Bushings, Beefed CB Drop, Deckplate, K&N Drop-In, DO Bed Bar, Cobra 75 WXST, Firestik Firefly, Philips D1R, Clarion Remote Start, Husky Liners
    I'm a big fan of the UG. I think the display & interface is so much better than the SG. UG looks way better & has better mounting options. The SG is bulky & ugly IMO.
    I got my first UG in a GB here in 2010 for $55 shipped. The UG Classic didn't support programmable gauges like the SG so no trans temp but that wasn't a deal breaker for me. Had it for 8 yrs with no problems. Then there's the reports of SGs melting the OBD port which is scary but could have just been isolated incidents.
    Rather than send my UG Classic in for a software update, this year I purchased the UG MX in another GB for $70. Even though UG themselves did not recommend the MX for ISO-9141/1st gens, I purchased the MX hoping that I might be able to get trans temp readout working. UG themselves even said it wouldn't work but I had hope & took a chance anyway. I was a little bummed that I couldn't get trans temp to work like everyone else couldn't, that is until today.... working trans temp!
    The updated MX has more preset gauges & more pages than my old Classic as well as more customizable user settings & features. It supports up to 6 pages now with 8 gauges per page which is more than I need/use. I only use 4 pages with 6 gauges per page. 8 gauges per page looks too cluttered for my preference but it has the ability if I ever want.
    20181211_130445.jpg 20181211_130453.jpg 20181211_130502.jpg 20181211_130511.jpg
    jubei likes this.
  2. Dec 11, 2018 at 1:33 PM
    04TRDV6
    04TRDV6 Well-Known Member
    Lynn
    Houston, TX
    2004 TRD V6 XtraCab
    I cut off the rubber seal/boot on the old gear that is under the rag joint so I could get to the base of the rag joint right up next to the shaft. Few taps with a cold chisel and I could see it start moving. Few more taps and it was off. Couple new shiny places on the rag joint but no burs. Flushed it with a good solid stream of Blaster to remove any grit and it slid right on the new gear. Got everything connected back up. Should be good.
    New dilemma though. I'm also putting in some new front shocks and LBJs while I already have the TREs and stabilizer Bar disconnected. Removed the old LBJ and thought I'd do the shock before installing the new LBJ. Well, as most of you already know, the lca "sprung up" soon as I pulled the shock out. Wasn't expecting that. So should I install the new LBJ and then the shock? Or shock first? Right now the old shock (with spring compressed) is getting a PB Blaster soak at the top nut because it still won't spin off and I have no more nub of the top of the shock to hold on to.
  3. Dec 11, 2018 at 4:47 PM
    jubei
    jubei would rather be doing something else
    NoCo
    White 2002 XC TRD and Yellow 1971 JEEP CJ5
    Stuff. Also things.
    Absolutely fucking LOVE my UG.
    The Distance to Empty gauge is super handy, and I use the intake temp as a ghetto outside temperature gauge. I also love the alarms that you can use and that I don’t need a code reader anymore.
  4. Dec 11, 2018 at 5:35 PM
    Jonyd182
    Jonyd182 What do you mean I can't go up there...Watch this!
    Jonathan
    Columbia, SC
    '99 SR5 TRD 3.4
    Armored to the teeth, 35's, Crawlbox, Boxed Frame
    Picked up a trailer last week but because of the endless rain in the south east I wasn't able to test it out until today.
    Pulled the Taco around town for about an hour to get a feel for it. Everything felt very smooth and the hemi had no trouble with the weight.
    I've read the TW towing bible but this is the first time I've hauled another vehicle so if any of you have real world advice for a novice; I'm all ears...
  5. Dec 11, 2018 at 5:49 PM
    xtremewlr
    xtremewlr Well-Known Member
    Todd
    Tucson, AZ
    2003 4Runner V8 - 2012 b00sted XRunner
    I have mods
    Only advice I have it to make sure the Taco is tied down next time you tow it. :rofl:
    Really tho, nothing too special about towing. Just remember to turn to opposite direction when backing up. :burnrubber:
  6. Dec 11, 2018 at 5:54 PM
    Jonyd182
    Jonathan
    Columbia, SC
    '99 SR5 TRD 3.4
    lol...I knew I was going to get :crapstorm: for posting the pre tie down pic. :thumbsup:
    I ended up strapping to the axles but I've seen some people go straight to the bumper. Is this just a preference thing or is one truly better than the other?
    xtremewlr[QUOTED] and Blackdawg like this.
  7. Dec 11, 2018 at 5:55 PM
    eon_blue
    Azusa, CA
    Eh, parking brake is fine
    :p
  8. Dec 11, 2018 at 5:57 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Don't be scared to drive it closer to the tongue. You want the tongue heavy which it looks like its balanced good right now. Either way, that is the most important part besides brakes.
    Getting an antisway ball hitch can help a LOT too because then you can really load up the tongue and it'll drive nice after you torque the bars down.
    Jonyd182[QUOTED] and xtremewlr like this.
  9. Dec 11, 2018 at 6:02 PM
    xtremewlr
    Todd
    Tucson, AZ
    I have mods
    Tie down via the rear axle and use the factory tie down points on the frame in the front if you still have them.
  10. Dec 11, 2018 at 6:14 PM
    Jonyd182
    Jonathan
    Columbia, SC
    '99 SR5 TRD 3.4
    Thanks.. My factory tie down points are gone but if they're above the suspension I suspect that using the recovery points on the bumper will essentially accomplish the same thing?
    I wasn't real happy with the axle straps pinching the lca's so finding a better attachment point would be nice.
    Maybe that's the reason I can give myself to S.A.S. (sorry wifey.... I had to do this for safety reasons)
    xtremewlr[QUOTED] likes this.
  11. Dec 11, 2018 at 6:15 PM
    Jonyd182
    Jonathan
    Columbia, SC
    '99 SR5 TRD 3.4
    Thanks Monte. We can always count on you for sound advice. I'm going to look into this.
  12. Dec 11, 2018 at 6:29 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    yeah when you load it wrong you'll know between 45-60mph in a hurry haha
    Seagull233 likes this.
  13. Dec 11, 2018 at 6:32 PM
    what road
    Dallas
    Indiana
    2001 tacoma sr5 trd
    alot still need done
    Have you started on Frankenstein resteration yet? Or just staring at him and the parts you need?
  14. Dec 11, 2018 at 6:43 PM
    xtremewlr
    Todd
    Tucson, AZ
    I have mods
    Did this today actually.
    chrslefty and Ace115 like this.
  15. Dec 11, 2018 at 6:52 PM
    xtremewlr
    Todd
    Tucson, AZ
    I have mods
    Paid. I'd have fucked it up royally and wasted a ton of time and money trying to do that.
  16. Dec 11, 2018 at 6:56 PM
    xtremewlr
    Todd
    Tucson, AZ
    I have mods
    Some things I will actually pay to have done by a professional, this is one of them.
  17. Dec 11, 2018 at 7:45 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Not yet. Still planning and waiting for a space to do it all. Which should happen in the next year finally.
    "it turns out, extremely" - also Jeremy Clarkson
  18. Dec 11, 2018 at 7:49 PM
    drr
    drr Primary Prognosticator
    Dan
    Seattle-ish
    02 4WD Tacoma
    Ideally you want to let the truck's suspension do it's thing while on the trailer, so strapping to axles, tire straps, etc. are preferred. If you rachet down the recovery points, any time you go over a big dip or bump it'll unload the suspension, creating a little slack (or a lack of tension) in the straps, then when you come up it'll load the suspension again and create a dynamic load in the tie-downs. Just adds more stress to the system.
    jubei, Reh5108 and xtremewlr like this.
  19. Dec 11, 2018 at 7:53 PM
    what road
    Dallas
    Indiana
    2001 tacoma sr5 trd
    Speed has never killed anyone. Suddenly becoming stationary is what gets you.
  20. Dec 11, 2018 at 8:42 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Is that a 16' or and 18' trailer?
