  1. Dec 15, 2018 at 9:32 PM
    Sebz13
    Sebz13 appy polly loggies
    Shane
    Maui Hawaii
    03 Reg Cab, 99 3 Link SC ext cab.
    a dropped one and a high one
  2. Dec 15, 2018 at 9:32 PM
    xcmtb83
    xcmtb83 Well-Known Member
    Iowa
    55W on low beam, 60W on high beam. Same as the GE.
    crashnburn80 and lucky13don like this.
  3. Dec 15, 2018 at 9:58 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Reh5108 and crashnburn80 like this.
  4. Dec 16, 2018 at 1:42 AM
    BlackPearl
    BlackPearl Well-Known Member
    Alex
    Toyota Tacoma TRD
    3” lift. Sway a ways 2.5 on 285 75 16 and much more
    New gears are in. 4.88, so much better then the stock 4.10 on 33’s :bananadance:
    Got to brake them in and test out the front arb locker.
  5. Dec 16, 2018 at 5:34 AM
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    Beef!
  6. Dec 16, 2018 at 6:28 AM
    Blue92
    Blue92 Well-Known Member
    Daniel
    North Carolina
    2018 Sport
    Hmmm same as the Philips X-Treme Vision I have. Theyre good bulbs, and brighter than stock, but they didnt blow my socks off.
    crashnburn80 likes this.
  7. Dec 16, 2018 at 6:43 AM
    xcmtb83
    Iowa
  8. Dec 16, 2018 at 6:46 AM
    xcmtb83
    Iowa
    I'm not sure what you mean by "same as". Are you referring to just the wattage specs? That is the legal limit for road use so almost every bulb you see will be 60/55W.
  9. Dec 16, 2018 at 6:52 AM
    Blue92
    Daniel
    North Carolina
    2018 Sport
    Same wattage yes. Its a higher performance bulb, I wouldnt expect those GE bulbs to be much better.
  10. Dec 16, 2018 at 9:12 AM
    MichaelsTacoma
    MichaelsTacoma Well-Known Member
    Michael
    Sacramento
    00 TRD 4wd e-locker
    donahoe racing coilovers, Camburg upper control arms, rear bilstein 5100, wheelers leaf pack, wheelers super bumps, 33 inch Cooper discovere stt pros
    So last night I went to drive my truck, as I’m moving forward out the driveway the truck does like a stutter like somethings blocking the tires. I figured out for some reason it’s kind of being caught between 2hi and 4hi. I could move the shifter to 4hi but for some reason it would not fully engage back into 2hi. A few times when I’d come to a stop it would have a violent shake and hop and slam into 4hi anybody have any suggestions on why or how to fix it?
  11. Dec 16, 2018 at 9:40 AM
    Digiratus
    Roaming the PNW
    The RedHead
    Maybe I missed it but it wasn't clear if you had also done the wiring harness upgrade. That is what makes for the most improvement in headlight performance. I am sure upgrading the harness would have also been part of @crashnburn80 recommendation.
  12. Dec 16, 2018 at 10:02 AM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    The GE +120 Megalight H4s are the highest efficiency (plus rating) bulb on the market without negatively affecting high beam performance by putting a blue coating over it.
    Upgrading the harness is always a good idea to boost output with higher voltage. Running a stock wattage bulb it is not required, but will further boost performance and is definitely recommended for best output.
    xcmtb83 and lucky13don like this.
  13. Dec 16, 2018 at 10:25 AM
    se7enine
    se7enine MCMLXXIX
    Reno, NV
    Hella has an 80w bulb that might be worth a try. Easily available and cheap at $7 each. Quality wise I'm not sure it will compare to the Osram Bilux that's no longer available.
    chrslefty likes this.
  14. Dec 16, 2018 at 12:50 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Not comparable to the discontinued Osram Bilux Hypers, which are high efficiency and high wattage.
    Compared to the available Osram 100/90w Superbrights, the Hellas are rated at 100 hours vs 200 hours for the Osram, and the Osram are higher output on low beam, they are equivalent on high beam.
  15. Dec 16, 2018 at 12:56 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    Driving this fugly hoe home today. It’s gonna make Logan it’s bitch.
    ToxicTwin, chrslefty and FLBAdrian like this.
  16. Dec 16, 2018 at 1:02 PM
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    are those nozzles the fan style?
  17. Dec 16, 2018 at 2:00 PM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    Yeah there was a whole thread on people testing various nozzles from various makes and models. It was concluded that this was the best set.
    xtremewlr likes this.
  18. Dec 16, 2018 at 2:00 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    Has anyone done engine mounts and the transmission mount for the 2.7l A340F?
    I’m tired of this Hitachi Magic Wand idle.
  19. Dec 16, 2018 at 3:08 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Yeah it's easy
  20. Dec 16, 2018 at 3:08 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    I'm guessing there's two for the engine, right?
    My guess on how to do this is lift up the engine from the factory points with a cherry picker.
