  1. Jul 10, 2012 at 1:39 PM
    45acp
    45acp Paint me back in Wyoming again...
    Jonathan
    Boring, Wisconsin
    1981 Long bed 4x4
    Nevermind, gonna ziptie the drive shaft to the crossmember and drive it to the hardware store. :anonymous:
  2. Jul 10, 2012 at 1:53 PM
    RMAN808
    RMAN808 S)(AKALO)(AWAII
    Reid
    Pearl City, Hawaii
    '17 TRD OR 4X4 Quicksand
    No, it definitely is not a Rosie blow up doll :puke:
    And I just called a bunch of hardware stores and had no luck with that rubber gasket material. Ace has em but only 4x4" for about $3-4 and I'm not sure how thick. I also don't have a drill for the holes :eek: and is it thick enough to cut with a regular razor blade?
  3. Jul 10, 2012 at 2:11 PM
    Madjik_Man
    Colorado Front Range
    I used a utility razor to cut one, then moved on to scissors. Seemed to be easier.
    A drill definitely helps for the holes (Capt Obvious) but you might be able to get away with a punch. If you don't have a punch you might be able to get away with a phillips head screwdriver.
  4. Jul 10, 2012 at 2:17 PM
    RMAN808
    Reid
    Pearl City, Hawaii
    Don't have either :pout:
    Hmm... how much would it cost to have you do it for me? Material, cutting, drilling, shipping? :D Serious question, but ONLY if you find time and wouldn't mind.
  5. Jul 10, 2012 at 2:17 PM
    scocar
    scocar Patron of the Farts
    Aren't all the shaft bolts 12mm?
  6. Jul 10, 2012 at 2:23 PM
    scocar
    Ah hell, you just need to poke a hole through with scissors tips and hog it out. It is just so the screw goes through easily. No need for exact tolerances.
  7. Jul 10, 2012 at 2:29 PM
    45acp
    Jonathan
    Boring, Wisconsin
    1981 Long bed 4x4
    This is the nut that holds the flange to the t-case. Its probably like somewhere around 26-30mm. :notsure:
  8. Jul 10, 2012 at 2:29 PM
    RMAN808
    Reid
    Pearl City, Hawaii
    Whoops, I was just imagining it being really thick and tough to poke a big enough hole :eek: 1/8" should be thin enough with a screwdriver and hammer huh?
  9. Jul 10, 2012 at 2:41 PM
    Madjik_Man
    And here I was going to suggest to RMAN to get a microgauge...
  10. Jul 10, 2012 at 2:41 PM
    Madjik_Man
    No need for a hammer...
  11. Jul 10, 2012 at 2:42 PM
    scocar
    Ohhh, gotcha. No clue. But it does need 87 ft lbs when you put it back on (attached). Sorry bud.
    Ben might know off the top of his head.
  12. Jul 10, 2012 at 2:42 PM
    Madjik_Man
    If you want me to do it, I'll do it for free. Took me 2 mins.
    One 6x6" sheet makes two complete sets, so I made one for my friend who has an '02. I would have just sent you those.
  13. Jul 10, 2012 at 2:43 PM
    scocar
    You can probabaly burn a whole in it with normal human vision.
  14. Jul 10, 2012 at 2:44 PM
    RMAN808
    Reid
    Pearl City, Hawaii
    Burn hole... with human vision. Got it.
  15. Jul 10, 2012 at 2:45 PM
    buzzard1992
    buzzard1992 Yep
    Alex
    Summerville, SC
    01 4wd trd, 255/85/16 km2s
    5100's with eibachs. And 255/85/16 km2s
    Plasti derped the rest of the Chrome on the front. I'll take pics when it stops rainin
  16. Jul 10, 2012 at 2:57 PM
    Sidewinder10
    Sidewinder10 Active Member
    Hunter
    Alabama
    '98 Tacoma 4x4 Reg. Cab
    3in spacer up front Rear AAL
    I call it the "sticker under tool box lid" mod. PM me for write up ;)
  17. Jul 10, 2012 at 3:13 PM
    TIPICOTACO
    TIPICOTACO Well-Known Member
    Tyler
    nw nj
    '01 DC 4X4 TRD "RAD BARON"
    Some lift, some armor, some scratches..
    did a 3 stage Seafoam treatment, washed and vacuumed her out (TONS of dog hair!!) and made a stubby antenna :)
  18. Jul 10, 2012 at 3:27 PM
    45acp
    Jonathan
    Boring, Wisconsin
    1981 Long bed 4x4
    Thanks for the help. Went to the hardware store, looks like it's 30mm. I'd give you rep anyway, but I got a message saying "You must spread some reputation around before giving it to scocar again." :D
  19. Jul 10, 2012 at 3:32 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    :woot: :cool:
    Wtf did you do..
  20. Jul 10, 2012 at 3:36 PM
    45acp
    Jonathan
    Boring, Wisconsin
    1981 Long bed 4x4
    Just wanted to replace (for the 2nd time :mad:) a leaking seal between the flange and transfer case before I put the belly armor back on.:cool:
