  1. Dec 16, 2018 at 3:08 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Yeah it's easy
  2. Dec 16, 2018 at 3:08 PM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    I'm guessing there's two for the engine, right?
    My guess on how to do this is lift up the engine from the factory points with a cherry picker.
  3. Dec 16, 2018 at 3:19 PM
    xtremewlr
    xtremewlr Well-Known Member
    Todd
    Tucson, AZ
    2003 4Runner V8 - 2012 b00sted XRunner
    I have mods
    What @BartMaster1234 said.
  4. Dec 16, 2018 at 3:31 PM
    xtremewlr
    Todd
    Tucson, AZ
    I have mods
    So I think I have a location picked out for the air compressor under the hood. The problem is, I will lose the cruise control and I really don't want to if at all possible. Relocation is therefore the only option. My question however, is the cable replaceable on the CC unit? If it is, then I might be able to have a longer one made which would give me better options for retaining the CC in a new location.
  5. Dec 16, 2018 at 3:59 PM
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    I believe it is. Just pull the cover off and it should be removable
    xtremewlr[QUOTED] likes this.
  6. Dec 16, 2018 at 4:11 PM
    Speedytech7
    Yeah, just use the picker on the front hook to pull it up after loosening the mounts and swap em out and set it back down. Takes like 10mins per side if you are using stock style rubber mounts
  7. Dec 16, 2018 at 4:28 PM
    Gamaliel
    Gamaliel Active Member
    Gamaliel
    Tacoma Double Cab 2001 Automatic to Manual tranny and 4x4 conversion
    3" Lift Prerunner Automatic to Manual tranny and 4x4 conversion
  8. Dec 16, 2018 at 6:23 PM
    Dan8906
    Dan8906 Well-Known Member
    Daniel
    Concord, California
    2004 Tacoma ext cab TRD 4x4
    CBI sliders, ADS extend travel with compression adjuster coil overs, 9” Bilstein 5125 rear shocks, Icon Tubular UCA, Alcan custom leafs, All Pro Apex bumper and skids, NWTI rear diy bumper, 295/70/17 Cooper St Maxxs and nitro 4.88s.
    So I thought I fixed my water leak, but I didn’t. I think it’s better now but still leaking. I had wires running on the out of the rubber boot in the fire wall on the driver side. I cut the wires and ran them through the boot and sealed them with silicone so the boot would sit tight in the hole like normal. But water is still seeping around the boot. Any ideas on how to seal it better? Silicone around the boot too?
  9. Dec 16, 2018 at 6:52 PM
    xtremewlr
    Todd
    Tucson, AZ
    I have mods
    That's what I would do, short of replacing the boot. If you can even get one.
  10. Dec 16, 2018 at 7:02 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    Would you recommend stock OEM Replacement, aftermarket stock replacement, or like a Polyurethane (if one exists)?
  11. Dec 16, 2018 at 7:03 PM
    xtremewlr
    Todd
    Tucson, AZ
    I have mods
  12. Dec 16, 2018 at 7:05 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    Website says:
    “Caution: These motor mounts will cause more vibration than OEM motor mounts.”
    I’m trying to get rid of the excessive vibration haha.
    Dan8906 and JKO1998 like this.
  13. Dec 16, 2018 at 7:05 PM
    xtremewlr
    Todd
    Tucson, AZ
    I have mods
    And? If you don't want that then go with OEM replacements.
  14. Dec 16, 2018 at 7:06 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    The whole reason I’m replacing the motor mounts is because of excessive vibration...
  15. Dec 16, 2018 at 7:06 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    That’s what he was asking.
  16. Dec 16, 2018 at 7:08 PM
    eon_blue
    Azusa, CA
    also cancer and reproductive harm.
    I can take one or the other but not both vibes and cancer/reproductive harm
  17. Dec 16, 2018 at 7:08 PM
    xtremewlr
    Todd
    Tucson, AZ
    I have mods
    You added that part after I responded.
    OEM/aftermarket OEM is your only choice then. Poly motor mounts of any kind are going to have more vibration than stock.
  18. Dec 16, 2018 at 7:09 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    If you read back the conversation was about my shaky idle.
  19. Dec 16, 2018 at 7:11 PM
    xtremewlr
    Todd
    Tucson, AZ
    I have mods
    Missed that part. Have you visually inspected your existing motor mounts to see if they are broken or cracked. Mine, even with 317k miles and a completely broken trans mount when I got it are still fine from what I can see.
  20. Dec 16, 2018 at 7:12 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    I have not. I assumed they’d need to be replaced by 100,000 miles.
    My transmission mount I literally found on the ground of the junkyard, so who knows the history behind it.
