  1. Dec 16, 2018 at 8:12 PM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    It vibrates at Idle in Drive. For example, I was at the drive though today and I would have to put it in Neutral because the Vibration was so bad. In Neutral and Park the vibration goes completely away.
    TC is known to be good. It’s my original torque converter from the A340E.
    The stall speed is 300-400 RPM different between the A340E and A340F.
  2. Dec 16, 2018 at 8:12 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    That's normal, it's a four cyl and it's being stressed cause it still has to fight the TC in drive with your foot on the brake. New mounts might lessen it a bit maybe, but it's normal
  3. Dec 16, 2018 at 8:13 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    I’d rather stock but don’t wanna pay the $$
  4. Dec 16, 2018 at 8:14 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    I added in an edit:
    Maybe it could be the torque converter. I’m running the A340E torque converter in my A340F. The transmission shop told me the stall speed was 300-400 RPM different. They advised against using it during the original flexplate dillemna.
  5. Dec 16, 2018 at 8:15 PM
    Blue92
    Blue92 Well-Known Member
    Daniel
    North Carolina
    2018 Sport
    Now that you mention that, my moms highlander does the same thing. In drive, at idle, it sounds and feels all vibratey. Put in park, smooth as can be.
    Speedytech7[QUOTED] likes this.
  6. Dec 16, 2018 at 8:15 PM
    Speedytech7
    Should make zero difference at a stop
  7. Dec 16, 2018 at 8:15 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    I’m probably gonna go to a dry filter. The oiled filter is f’ing up my MAF with Carbon.
  8. Dec 16, 2018 at 8:16 PM
    JKO1998
    Utah
    Just do what I did, bypass the filter for organic air.
  9. Dec 16, 2018 at 8:16 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    I guess it is normal then. That coupled with the old mounts.
    Another thing that adds to it is the lock rods rattling against the sheet metal. I should Dynamat the cab.
  10. Dec 16, 2018 at 8:17 PM
    Speedytech7
    Dynamat is nice, makes everything feel like quality, don't over do it though in the doors or you'll ruin your sound systems mid and bass response haha
  11. Dec 16, 2018 at 8:20 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    People always use it wrong. They cover the whole cab in it when you only need to use a few squares placed strategically around.
  12. Dec 16, 2018 at 8:20 PM
    Speedytech7
    Yup, just need to cut resonance
  13. Dec 16, 2018 at 8:21 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    Someone explained it to me like ringing a bell and putting your finger on it to stop the resonance. There is zero difference between the sound if you used your finger versus covering the bell with your hand.
  14. Dec 16, 2018 at 8:22 PM
    Blue92
    Daniel
    North Carolina
    2018 Sport
    I just shoved duct wrap wherever I could without ripping out the entire carpet. Made no difference at all. Need to finish the back wall sometime too.
  15. Dec 16, 2018 at 8:23 PM
    Speedytech7
    The floor is pretty sturdy, the roof makes a bigger difference noise level wise, back wall too. Also that duct wrap isn't mass loaded vinyl so it doesn't work all that well anyway
    Blue92[QUOTED] likes this.
  16. Dec 16, 2018 at 8:24 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    Excuse me I only use Organic, Free Range, Conflict Free, Grass-Fed air.
    Silver02Taco and JKO1998[QUOTED] like this.
  17. Dec 16, 2018 at 8:25 PM
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
    Donahoe CO, Donahoe Rear Resi, Deaver J59, 16" Pro Comp, 33" BFG AT, Hayden Trans Oil Cooler, Oil Filter Relocator, FM 40, ES Bushings, Beefed CB Drop, Deckplate, K&N Drop-In, DO Bed Bar, Cobra 75 WXST, Firestik Firefly, Philips D1R, Clarion Remote Start, Husky Liners
    You're probably oiling it too much. IMO they also come over oiled from the factory. I don't have a problem with my MAF getting covered in oil. After washing, I oil the filter, then blow out any excess oil caught in the mesh then let it sit overnight so the oil soaks in tbe element. Then I'll add more oil the next day if I feel it's needed and repeat.
    Yeah sounds like a long process but I always have a stock air filter on hand cause I'll only use stock filter elements whenever my truck sees dirt.
    I only use the K&N drop in cause it came in the stock airbox I bought for $40. Saves me money on filter replacements daily driving on the street which is all tbey're good for on a Tacoma. If I didn't have it I would never even buy one. My truck came with a full K&N FIPK. I sold that rice sounding crap & got good money from some sucker on ebay.
  18. Dec 16, 2018 at 8:27 PM
    Speedytech7
    You really losing your ass over air filter replacements? $12 for a real paper filter beats buying a new engine or MAF from a filter that can barely keep out sand let alone finer particles.
    Blue92 likes this.
  19. Dec 16, 2018 at 8:27 PM
    Blue92
    Daniel
    North Carolina
    2018 Sport
    Always wondered why you have to oil those things. Makes absolutely no sense to me.
    Then again, owning a "cold" air intake that gets its air from the hot engine makes no sense to me either.
    Adude and Speedytech7 like this.
  20. Dec 16, 2018 at 8:27 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    Doesn’t that tar paper on the floor help? Figured that combined with the mass backing in the carpet help against sound isolation. I’d be worried about the doors and ceiling and the cab walls.
