  1. Dec 17, 2018 at 7:06 PM
    nzbrock
    nzbrock Well-Known Member
    Noah
    San Marcos, TX
    99 TRD Prerunner 3RZ
    I chased a vibration on my truck for years, and ultimately it ended up being my muffler. Get your truck to start shaking, put the ebrake on, and look underneath at your muffler.
    I started a thread about it here where I wen't through all other options. I did replace the motor mounts and trans mount since they weren't in the best shape.
    https://www.tacomaworld.com/threads/2-7l-rough-idle-diagnosing-solved.466233/
  2. Dec 17, 2018 at 7:07 PM
    Thaitoy
    Thaitoy 2003 3.0 turbo diesel. 6in lift w 33's
    2003 taco 3.0 turbo diesel
    6 inch lift. 33in tires 10000lb winch and shocks
    Yes
  3. Dec 17, 2018 at 7:11 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    How many amps is that unit rated for?
  4. Dec 17, 2018 at 7:12 PM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    Would’ve never suspected the exhaust. I’ll take a look.
  5. Dec 17, 2018 at 7:12 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    That’s interesting. I’ve never seen it used outside of computer monitors.
  6. Dec 17, 2018 at 7:17 PM
    Thaitoy
    It is nice since longer or shorter cables are easy to get.
  7. Dec 17, 2018 at 7:18 PM
    Thaitoy
    Speedytech7 likes this.
  8. Dec 17, 2018 at 7:20 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    What’s it for, just goes to the switch panel?
    Speedytech7 and RonJon31 like this.
  9. Dec 17, 2018 at 7:20 PM
    Thaitoy
    I did the same but since my truck doesnt have a dimmer switch i went with red.
  10. Dec 17, 2018 at 7:23 PM
    Thaitoy
    Yes between the switch panel and power box.
    I wanted the spod but i didnt want to pay the import tax. Up to 300%
  11. Dec 17, 2018 at 7:40 PM
    yotatoy02
    yotatoy02 Well-Known Member
    Will
    1999 Gold Tacoma v6 4wd
    OME 3" Suspension lift, tailgate removal, 2016 wheels
    I hear ya I kinda wanted to do red but just decided to go with some white ones
  12. Dec 17, 2018 at 8:04 PM
    Thaitoy
    Yes
  13. Dec 17, 2018 at 8:06 PM
    Thaitoy
  14. Dec 17, 2018 at 9:01 PM
    xtremewlr
    xtremewlr Well-Known Member
    Todd
    Tucson, AZ
    2003 4Runner V8 - 2012 b00sted XRunner
    I have mods
    Oh the joys of changing coolant! I'm about 1/2 of the way done with a complete coolant flush and change from the green stuff that was in the truck when I bought it. Putting Zerex Asian car red stuff in.
    1. Green stuff drained from radiator and block - Done
    2. Refill with distilled water for initial flush to get as much of the green crap out as possible - Done
    3. Run engine for 20 minutes, burping the system and then let cool - Done
    4. Drain radiator and block again - Done
    5. Refill with distilled water and Prestone engine flush and degreaser - Done
    6. Burp system and drive around town for an hour or 2 with the flush/degreaser/distilled water mix
    7. Drain flush/degreaser/water mix from radiator and block
    8. Fill one last time with distilled water to make sure the system is as clean as possible
    9. Run engine for 20 minutes, burping the system and then let cool
    10. Drain radiator and block one final time
    11. Final refill with Zerex Asian vehicle red premixed coolant and monitor for the next couple days
    There was definitely sediment starting to build up in the system. Lots of what looks like sand in the bottom of the drain bucket. And I can see some build up in the pipes that you can see via the fill cap on the radiator. Hopefully the Prestone flush is able to dissolve and clean most of that crap out. The radiator internals do look pretty good otherwise. It's a Denso unit so I assume aftermarket but I have no idea how old it is. Timing belt, water pump and thermostat were replaced by the PO about 6k miles ago.
  15. Dec 17, 2018 at 9:19 PM
    Dan8906
    Dan8906 Well-Known Member
    Daniel
    Concord, California
    2004 Tacoma ext cab TRD 4x4
    CBI sliders, ADS extend travel with compression adjuster coil overs, 9” Bilstein 5125 rear shocks, Icon Tubular UCA, Alcan custom leafs, All Pro Apex bumper and skids, NWTI rear diy bumper, 295/70/17 Cooper St Maxxs and nitro 4.88s.
    Picked up my pops 2001 tundra to drive while my gear are getting done. I think I’m going to have to take this truck from him when he gets a new one. Rides so nice. 108k on it, 4x4 trd
    Fuergrissa, BYJOSHCOOK and lucky13don like this.
  16. Dec 17, 2018 at 9:21 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    They’re arguably better all around work trucks. It’s amazing how much of a price difference there is on the used market.
  17. Dec 17, 2018 at 9:33 PM
    Dan8906
    Daniel
    Concord, California
    They are much cheaper! They are bigger tho. Not ideal for wheeling. But his is completely stock. Just did the timing belt and replaced the suspension. The 4.7 V8 is nice too. I’m thinking if I can grab it up that will be my around town truck and hauler.
  18. Dec 18, 2018 at 5:44 AM
    burntkat
    burntkat Well-Known Member
    Phillip
    Charleston, SC
    97 Extracab Tacoma
    Got a link to the source?
    I was QUITE impressed with the Hella H4 conversion housings and included bulbs. $90 on Amazon. Built my own harness upgrade. I liked the housings so much I bought another set and put them in my son's XJ last night so he can see and be safe. I haven't even upgraded the harness in it, and already it's a huge difference in light output, and I replaced the h6054 sealed beams recently.
  19. Dec 18, 2018 at 5:44 AM
    burntkat
    Phillip
    Charleston, SC
    97 Extracab Tacoma
    Wait til you have to replace the starter! :)
    koditten likes this.
  20. Dec 18, 2018 at 6:01 AM
    lucky13don
    lucky13don Well-Known Member
    Don
    Milton, fl
    R.I.P.04 tacoma prerunner, 04 sequoia 4x4
    Too many to list
    Grabbed them off Ebay. All the way from Bulgaria. Took 10 days to get here. 22 bucks with shipping. I'll dig up the seller for you.boloromo is the seller.
    burntkat[QUOTED] likes this.
