  1. Dec 20, 2018 at 6:11 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Lighter coils and lighter truck haha
  2. Dec 20, 2018 at 6:14 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    50# less and we have similar fronts, right down to the bumper. I call user error. He lifted his off the ground and couldn't do it, maybe he needs a bigger I beam or something I dunno. Wasn't even worth a second thought with how easy mine were, I shot them with a toot of PB and was good to go.
    Reh5108 likes this.
  3. Dec 20, 2018 at 6:31 PM
    Reh5108
    Reh5108 Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    Heat the ring with a heat gun. It's probably corroded a bit. I bent his spanner before the heat. Buddy said he was quoted $160 a shock to adjust them by 4wp.
    m3bassman[QUOTED] likes this.
  4. Dec 20, 2018 at 6:33 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    Couldn’t any ol auto shop just compress the spring in their fancy gizmos they have and spin the collar in like 5 seconds?
    If you want to take them off the truck anyway.
    burntkat likes this.
  5. Dec 20, 2018 at 6:45 PM
    JKO1998
    Utah
    Even if they charged you a half hour in labor, or if youre Erm, known around the shop, they’d probably just do it for nothing.
  6. Dec 20, 2018 at 7:44 PM
    kuntry09
    kuntry09 Well-Known Member
    Cam
    Douglas, Georgia
    '99 extended cab Tacoma 4x4 converted Prerunner
    After having a burnt valved replaced, I’m wondering if I don’t have an air pocket in the cooling system, or timing is slightly off. It’s running the best it’s ever ran, but the engine temperature (according to my UG) is going between 195-199 going down the highway. It will peak at 199, eventually work it way back down to 195, and then go back to 199. Before having the valve replaced it was pretty consistent at 195.
    Am I over thinking it? Tried making sure the system had been burped correctly. Radiator should be fine, less than a year old. Thermostat was replaced with a 170 shortly before valve was replaced.
  7. Dec 20, 2018 at 8:22 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    You're ok. You wont hurt it at that temp. Mine runs at 202-205 normally. Always has.
    kuntry09[QUOTED] and Speedytech7 like this.
  8. Dec 20, 2018 at 8:25 PM
    Digiratus
    Roaming the PNW
    The RedHead
    That's right. Had forgotten that. You bent the shit outa that pin. :muscleflexing:
    m3bassman and Blackdawg[QUOTED] like this.
  9. Dec 20, 2018 at 8:27 PM
    Dan8906
    Dan8906 Well-Known Member
    Daniel
    Concord, California
    2004 Tacoma ext cab TRD 4x4
    CBI sliders, ADS extend travel with compression adjuster coil overs, 9” Bilstein 5125 rear shocks, Icon Tubular UCA, Alcan custom leafs, All Pro Apex bumper and skids, NWTI rear diy bumper, 295/70/17 Cooper St Maxxs and nitro 4.88s.
    Well the guy from the gear shop called and said the gear install went good, he drove it and it all sounds perfect. But he’s having issues bleeding my brakes properly? Says it feels to soft at the petal and that the rear brakes weren’t showing good pressure when he was bleeding them. He’s having another guy from a different shop come look at it in the morning apparently. Hopefully he gets it figured out. Any ideas on what would cause that?
  10. Dec 20, 2018 at 8:28 PM
    Speedytech7
    Why did he have the brakes apart anyway? But maybe he doesn't know to bleed the LSPV or they allowed the master to run dry and it has air trapped in it, or if you have ABS maybe air is trapped there.
  11. Dec 20, 2018 at 8:33 PM
    El Taco Diablo
    El Taco Diablo Professional Pinstriper
    Matt - KN6DZP
    Hughson, CA
    Impulse Red DC, 5vz-fe, 4wd swap, LT, dual case, F/R locked
    Just 3 tons of fun!!!
    I hear you brother... I hate this State! We just got back from spending 5 days in Texas and Oklahoma... People are so much nicer there, it's cleaner, the traffic is better, gas is under $2.00 a gallon.
    I didn't get 50 feet from the gate at SFO and I wanted to start punching people in the face for being assholes.
    Damn it... Why did we come back to this place? :notsure:
    We went back there for my youngest son Graduating from basic (shameless plug from a proud dad)
  12. Dec 20, 2018 at 8:36 PM
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    Ya... Well their entire reasoning for it is horseshit... Along with Sacramento's reasoning for essentially everything.
  13. Dec 20, 2018 at 8:41 PM
    Yetimetchkangmi
    Yetimetchkangmi Well-Known Member
    Benjamin
    Newcastle, WA
    03 Tacoma 4x4 The Yeti
    ARB front locker, Custom high clearance rear bumper, Custom plate front bumper, mile marker winch PE8, safari snorkel, Deck Plate Mod Fox 2.5 rr DSC, Camburg UCA, squeaky Dakar leafs, 5125 10" and custom 7.5" shackles, thee finest PNW pinstripes, MT-R, Nissan crew cab roof rack??? wtf is that about??? Allpro skids, Rigid duallys President McKinley CB with PA Recaro SRD with Wedge Engineering Morimoto retrofits Champion Rad - Failed Tundra brakes
    Wait, what?!?!?
    I have ABS and that LSPV and brakes are squishy after Tundra upgrade.
    I bled Driver Rear, LSPV, Pass Rear, Pass Front, Driver Front in that order.
    I learned AFTER that I should have bled LSPV first, then DR, PR, PF, DF.
    Any other guidance?
    m3bassman likes this.
  14. Dec 20, 2018 at 8:50 PM
    Dan8906
    Daniel
    Concord, California
    After the tundra upgrade mine are pretty squishy too, maybe that’s what he is feeling?
  15. Dec 20, 2018 at 8:51 PM
    Dan8906
    Daniel
    Concord, California
    Is that not normal when doing gears? He also did axle seals and wheel bearings.
  16. Dec 20, 2018 at 8:52 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    Not for gears. But yes for axles seals as you have to disconnect the rear drums
  17. Dec 20, 2018 at 8:53 PM
    Speedytech7
    You can leave the wheel cylinders on, but if he was doing the bearings and seals he would pull everything completely, makes sense
  18. Dec 20, 2018 at 8:59 PM
    eon_blue
    Azusa, CA
    yeah I'm from the Midwest (Missouri), lived in Texas for several years as a kid...definitely a different overall vibe out there. People in general are a less rushed to get about which makes for a lot less stress and lot happier people overall imo.
    That said, if I lived in the Midwest again I think I'd get way too depressed from the lack of mountains...I need mountains. Not just for the scenery but also for the better offroading trails and camping trips. The midwest has mud, that's about it for offroading lol. Unless you're out in the Ozarks maybe, which is a beautiful area.
    I lived up in Oregon for a brief time as a kid and that was by far my favorite place I've lived...if it were as easy as saying 'let's move' I'd be up there tomorrow. That's the goal eventually, maybe not Oregon depending on where the opportunities are, but somewhere further north. Hell, I'd be happier living in California even if we were up in Northern (way northern) CA. A small town like Grass Valley or maybe Folsom. Close to the N. Sierras. At least it's even prettier up there than it is down here lol.
    2002Tacoma4x4 and jubei like this.
  19. Dec 20, 2018 at 8:59 PM
    Dan8906
    Daniel
    Concord, California
    Ok I was worried for a second lol axle seals and bearings were included in the quote. The guy was recommended to me from a friend that has 6 sets of jeep Dana 60s built by him. And has a good yelp rating as well. So I know he knows what he is doing. Maybe I fucked something up when I installed the tundra brakes?? Not sure. They definitely felt softer after the install, to the point were I tried to bleed them again twice.
  20. Dec 20, 2018 at 9:04 PM
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    I totally get what you're saying. We are definitely getting out of this shit hole in the next couple years. Wife wants to move to Texas... I'm kind of on the fence with the Texas idea. It would be good for me with work especially (Home Building Superintendent) but lack of trails and mountains is not my favorite.
    Wish I could win the lottery and not have to worry about income... I'd be in Wyoming by the end of the week.
    But I may have to try and talk the wife in to moving to Reno.
    jubei and eon_blue[QUOTED] like this.
