  1. Dec 21, 2018 at 7:14 PM
    xtremewlr
    xtremewlr Well-Known Member
    Todd
    Tucson, AZ
    2003 4Runner V8 - 2012 b00sted XRunner
    I have mods
    Picked up my RTT in San Diego this afternoon. Now spending the weekend and Christmas at my daughter's place in Oceanside.
    JPinFL, Phessor, jubei and 5 others like this.
  2. Dec 21, 2018 at 7:35 PM
    beikokupilot
    beikokupilot Well-Known Member
    Utah
    1997 Red Tacoma 4WD
    Power steering pump, Steering rack, Tie rods, Radiator cap, Thermostat, New radiator, magnets to hold the fuel door closed, new starter drum/cylinder, dash lights changed to red, replaced all carpet in the cab. Not real “mods”, but all work
    Haha thanks :). Yeah, went from cheapest to most expensive fix. Come to find out the left 1/4 of the radiator was rusted out... ‍♂️. I gotta change the modifications to show the replacement of all the carpet!
  3. Dec 21, 2018 at 7:43 PM
    kuntry09
    kuntry09 Well-Known Member
    Cam
    Douglas, Georgia
    '99 extended cab Tacoma 4x4 converted Prerunner
    Just wanted to give a shout out to SPC Lightracing and their customer service.
    There seems to be mixed reviews on their UCAs, but I’ve been running them for 5 or 6 years with no major issues.
    I found last weekend that the shop that did my alignment after I installed my ADS coilovers messed up the ‘key’ (not sure what it’s technically called) that adjust for caster/camber. They didn’t listen when I tried to explain the adjustment procedure and distorted the star shape holds the BJ for the camber. Needless to say that shop has lost my business. The camber was close after I reinstalled everything but not where it should have been. I couldn’t find the part listed online anywhere, so I called SPC and explained what happened. They were gracious enough that they mailed me two new ‘keys’ to replace the damaged one. Not a huge deal, but great service in my book :thumbsup:
    Prayn4surf, jubei, Reh5108 and 7 others like this.
  4. Dec 21, 2018 at 7:51 PM
    TacoJohn4x4
    TacoJohn4x4 Captain Save-A-Ho
    Central Valley
    2002 Tacoma DC 4x4
    Good to know since I’m running them on my truck.
  5. Dec 21, 2018 at 7:54 PM
    El Taco Diablo
    El Taco Diablo Professional Pinstriper
    Matt - KN6DZP
    Hughson, CA
    Impulse Red DC, 5vz-fe, 4wd swap, LT, dual case, F/R locked
    Just 3 tons of fun!!!
    You don't run dual electrode spark plugs? It says to use them on the sticker in the picture under the nose of your SC. (Actually says to use them on driver side... I use them in both sides, I think a lot of people do)
    I wouldn't go by whether there is a puddle under your truck to tell how much oil you're leaking. Have you checked your skid plates? A lot of oil can drip on to your skids and you'd never know it looking for oil on the ground.
  6. Dec 21, 2018 at 7:57 PM
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    +1 on SPC. I'm collecting parts to do my 4x conversion. I got a new set of spindles and decided I wanted to just get new races for the UBJs to install on the new spindles. They were great to deal with. Very polite, knowledgeable and helpful.
    jubei and because_wumbo-truck like this.
  7. Dec 21, 2018 at 8:02 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    What part of Utah?
    beikokupilot[QUOTED] likes this.
  8. Dec 21, 2018 at 8:08 PM
    kuntry09
    Cam
    Douglas, Georgia
    Agreed! This is the second time I’ve called and they’ve been helpful both times. I’ve been following your build thread, hope it all goes well! I just finished my conversion. If you decided to replace the bushings in your UCAs during the conversion like I did, I found a much easier way than what LR outlines.
  9. Dec 21, 2018 at 8:13 PM
    1st4x4
    1st4x4 Well-Known Member
    sam
    Torrance
    98 tacoma 5 speed 4x4
    tundra front clip, tundra brakes, cab cage, camburg long travel, archive garage rear shock relocate
    Fuck ya picking up his old flatbed soon @wheeleveryweekend
    xtremewlr[QUOTED] likes this.
  10. Dec 21, 2018 at 8:15 PM
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    Right on :thumbsup:
    I'm hoping not to have to do anything to my UCAs. They haven't been on the truck very long.
    The 4x convert should be happening pretty soon. The garage looks like Santa vomited in it right now cause all the Xmas totes are pulled out of the attic. The plan is to organize the garage this weekend, then do the valve cover gaskets next weekend, then do 4x swap mid/late January.
    Still need to buy the front locker (probably Spartan) and twin sticks, but other than that, I have the vast majority of the parts collected.
    jubei likes this.
  11. Dec 21, 2018 at 8:25 PM
    kuntry09
    Cam
    Douglas, Georgia
    Mine had been on a while. So UBJ and bushings were due while I had everything apart. With a front locker and twin sticks you’re going beyond me..I’m just happy with 4wd hahaha I did mine in two stages. I did everything under the front end back in March, and the transmission/transfer case a little over two weeks ago. The task of removing and installing the transmission seemed daunting, but it actually wasn’t bad. Especially with videos from @Timmah! A harbor freight transmission jack is worth it’s weight gold!
  12. Dec 21, 2018 at 8:33 PM
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    I'm totally doing the 2 stage plan. I still have to re-boot my CVs, press the wheel bearings in the spindles, replace seals in the front diff etc. I'll be working on those things in the evenings after work leading up (another reason I need to unbury my garage).
    But I'll be doing the diff etc first and then doing the trans and Tcase... Probably over 2 weekends. Trying to limit down time, the truck is my daily driver.
    kuntry09[QUOTED] likes this.
  13. Dec 21, 2018 at 10:22 PM
    beikokupilot
    Utah
    1997 Red Tacoma 4WD
    Down in Draper. I’ve got family up in Logan!
  14. Dec 21, 2018 at 10:24 PM
    JKO1998
    Utah
    I’m just up there for school, originally for Vernal
  15. Dec 21, 2018 at 10:27 PM
    beikokupilot
    Utah
    1997 Red Tacoma 4WD
    Small world!
    JKO1998[QUOTED] likes this.
  16. Dec 21, 2018 at 10:30 PM
    JKO1998
    Utah
    There’s a few Utahns running around, not tooo many in the 1st gen section, at least that claim to be.
    jubei and beikokupilot[QUOTED] like this.
  17. Dec 21, 2018 at 11:26 PM
    kigmob
    kigmob Well-Known Member
    James
    New Orleans
    97 TRD S/C 4x4 V6 5spd
    ICON/TC TRD Supercharger URD 2.2 and 7th
    Denso IK22’s which have one electrode have long been the recommended plugs to run with the SC. They are two steps colder than stock plugs which help prevent pinging/knock.
    I never go by a puddle on the ground to determine how much oil I’m leaking/consuming. I check the dipstick periodically. I see my skid every time I change the oil since I remove it, and it’s always clean.
  18. Dec 22, 2018 at 4:48 AM
    03_taco_IN
    03_taco_IN Well-Known Member
    Indiana
    2003 xtracab sr5 v6 trd
    Blue wire/ grey wire/rear diff breather mod/881s w/bilistein
    Smelled burning oil today popped the hood to see smoke off the driver side exhaust. Thought my valve covers were shot but it turns out all my Vc bolts were lose I tightened them all two turns no in/lb torque wrench. It quit leaking but should I take one bolt out at a time and put loctite on them.
  19. Dec 22, 2018 at 5:37 AM
    Reh5108
    Reh5108 Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    Learning to do your own alignment is super easy with the SPC. Once you know what your doing you can align your truck yourself in less than 30 minutes.
    jubei and kuntry09[QUOTED] like this.
  20. Dec 22, 2018 at 7:28 AM
    jubei
    jubei would rather be doing something else
    NoCo
    White 2002 XC TRD and Yellow 1971 JEEP CJ5
    Stuff. Also things.
    Good to know SPC is great to work with. I didn’t know until I started researching their UCAs that their facility is only about 15 minutes from me. Guess if I have issues I can just drop by!
    I’d love to learn how to do this one day. One of the big reasons I’m stoked for the SPC arms is that Brian told me that I can get better numbers AND get the tire away from the firewall a bit more. I’m hoping that proves to be true.
