  1. Dec 24, 2018 at 12:49 PM
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    Hit the gym and curse at that filter like it just did nasty things to your mother :muscleflexing:
    Prayn4surf and 03_taco_IN like this.
  2. Dec 24, 2018 at 12:53 PM
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    You guys must be over-tightening your filters if they're that hard to remove.
    Prayn4surf, jubei and Reh5108 like this.
  3. Dec 24, 2018 at 12:54 PM
    Yetimetchkangmi
    Yetimetchkangmi Well-Known Member
    Benjamin
    Newcastle, WA
    03 Tacoma 4x4 The Yeti
    ARB front locker, Custom high clearance rear bumper, Custom plate front bumper, mile marker winch PE8, safari snorkel, Deck Plate Mod Fox 2.5 rr DSC, Camburg UCA, squeaky Dakar leafs, 5125 10" and custom 7.5" shackles, thee finest PNW pinstripes, MT-R, Nissan crew cab roof rack??? wtf is that about??? Allpro skids, Rigid duallys President McKinley CB with PA Recaro SRD with Wedge Engineering Morimoto retrofits Champion Rad - Failed Tundra brakes
    I did the same thing, over tightening...
    What I failed to do was to not put oil on the rubber gasket, made is super tough to remove.
    I had to phone a friend.
  4. Dec 24, 2018 at 1:07 PM
    Dan8906
    Dan8906 Well-Known Member
    Daniel
    Concord, California
    2004 Tacoma ext cab TRD 4x4
    CBI sliders, ADS extend travel with compression adjuster coil overs, 9” Bilstein 5125 rear shocks, Icon Tubular UCA, Alcan custom leafs, All Pro Apex bumper and skids, NWTI rear diy bumper, 295/70/17 Cooper St Maxxs and nitro 4.88s.
    I always add oil to the gasket. Lol this has only happened this time.
  5. Dec 24, 2018 at 1:08 PM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    They’re all hand tight on cars I own. I work on a lot of other cars and they’re damn hard to remove, almost like they somehow used and impact to screw it on. Those oil filter sockets are a godsend.
  6. Dec 24, 2018 at 1:09 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    I always like to pre-fill the filter too. Don’t want to run the engine dry for that second or two.
  7. Dec 24, 2018 at 2:17 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Musically *it makes absolutely no difference*
    Prayn4surf, koditten, Blue92 and 2 others like this.
  8. Dec 24, 2018 at 2:20 PM
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    I have a shop down the street that charges $7 if you bring your own oil. Went to it a few times after surgery. I specifically would tell them not to tighten to much...nope...always hella tight. Or ill swing by of its a rainy day. Im super anal about my oil changes. Every 5k
  9. Dec 24, 2018 at 2:26 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    His dads mechanic says
    Wait wrong person
    Blue92 and Speedytech7[QUOTED] like this.
  10. Dec 24, 2018 at 2:45 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    Oh well, that’s what I was taught by an ASE Master Tech at my local trade school. So it makes no difference, okay. At least it lubricates the rubber gasket.
  11. Dec 24, 2018 at 2:45 PM
    Phessor
    Phessor Well-Known Member
    I added a new basket to my bed rack. Added an old lightbar to the rear that I didn't like up front. The plan is to store my spare tires on top.
  12. Dec 24, 2018 at 2:48 PM
    Speedytech7
    It's an old "feel good" technique, usually just ends up making a huge fucking mess on non vertical mounted filters. Your oil pump pushes oil through the oil filter, it doesn't draw through it and they push enough volume that it fills fast. The oil film from the last run of the engine is more than enough to safely let the engine run while everything primes itself.
    drr and BartMaster1234[QUOTED] like this.
  13. Dec 24, 2018 at 2:56 PM
    eon_blue
    Azusa, CA
    I've wondered about this...whenever I do my oil when I go to start the truck, the low oil pressure light illuminates for a second or two before going off. Back when I used to get my oil done at the drive thru shops that never happened. I figured it was probably because I spend more time letting all the old oil drain out than they do.
    I haven't concerned myself too much with it but I wonder if putting oil in the filter would make a difference there
  14. Dec 24, 2018 at 3:00 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    I guess it’s one of those debatable things that people like to argue about. For me, it’s what I was taught in school so I will continue to do it. It doesn’t really matter for me since I have to lubricate the gasket anyhow.
  15. Dec 24, 2018 at 3:01 PM
    eon_blue
    Azusa, CA
    I'll try it next time and see if it keeps the light from coming on right away. The oil change write ups I referenced before doing it myself the first time never mentioned pre-filling the oil filter so I didn't think to, only saw it mentioned here a few times afterward.
  16. Dec 24, 2018 at 3:02 PM
    JKO1998
    Utah
    I just dip my finger in my old oil and run it around the gasket.
    That not enough?
    m3bassman and Speedytech7 like this.
  17. Dec 24, 2018 at 3:04 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    This is one of those cases where people like to play “let’s disagree with everything Tyler says”
    Like I said, I don’t really care doing it. It’s what I was taught and it doesn’t take much effort.
    TacoYankee likes this.
  18. Dec 24, 2018 at 3:04 PM
    Speedytech7
    Same, sometimes if I'm feeling fancy I dip it in the new oil
    ireymon, Adude, malburg114 and 3 others like this.
  19. Dec 24, 2018 at 3:04 PM
    Speedytech7
    Mostly letting you know you can save your time and a mess
    jubei and BartMaster1234[QUOTED] like this.
  20. Dec 24, 2018 at 3:05 PM
    JKO1998
    Utah
    I was just stating what I was taught :rofl:
    Idgaf honestly
