  1. Dec 29, 2018 at 9:35 PM
    96degreesindashayd
    96degreesindashayd IG: @96degreesindashayd
    Shaydon
    Kaua’i, Hawai’i
    95.5 Tacoma SX 2.7L TRD Supercharged Single Cab
    17” Trail Edition wheels Toytec Boss 3” TC UCAs TRD Supercharger SplitSecond FTC1 AFE Dry Pro CAI LCE Short Throw
    Finally put my tires on today. Pretty pumped. KM3 265/70R17.C6D7798F-048B-43B9-835B-04A00FC3936D.jpg
  2. Dec 29, 2018 at 9:36 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    When yours get out of adjustment they get quieter because wear causes them to tighten up and ride the cam harder
  3. Dec 29, 2018 at 9:40 PM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    That pile looks familiar.
    About one year ago today, I made my truck 4WD.
    (That’s the differential I gave you sitting in the bed, haha.)
    And then the flexplate exploded a week later.
    Works great now though. Haha.
  4. Dec 29, 2018 at 9:40 PM
    Speedytech7
    you have shim over bucket non hydraulic lifters, Usually wears out your nice little valve seats too as they tighten up, but that's fine how about you tell me how they work since you knew enough to ask the question in the first place. I seriously have no idea why I bother sometimes, I'll just go back to eating glue
  5. Dec 29, 2018 at 9:46 PM
    eon_blue
    Azusa, CA
    At least explain why you think differently if you're going to disagree with someone trying to help you. Otherwise it just sounds like you want to argue
    ireymon, Fernando, cali04intx and 2 others like this.
  6. Dec 29, 2018 at 9:49 PM
    Speedytech7
    I'm working on a new line of mechanical explanations through the use of cave paintings and grunts right now.
  7. Dec 29, 2018 at 9:57 PM
    Speedytech7
    I'm gonna just give two bits of advice you can google yourself to find the answer.
    They're called Shim over Bucket Valve Adjuster (you'll get the most info looking this up, it's not like an old pushrod engine or even a newer hydraulic adjuster rocker arm engine, it is it's own thing)
    And the one major piece of advice associated with them "tappy valves are happy valves)
    cruiserguy and xtremewlr like this.
  8. Dec 29, 2018 at 10:08 PM
    SwampYota
    SwampYota Strange things are afoot at the Circle K
    Jon
    Concord, North Carolina
    '03 Tacoma SR5 TRD 5VZ-FE, 5 Speed
    Floor mats
    Haha, same here. Looked like a second gen grill.
  9. Dec 29, 2018 at 10:13 PM
    El Taco Diablo
    El Taco Diablo Professional Pinstriper
    Matt - KN6DZP
    Hughson, CA
    Impulse Red DC, 5vz-fe, 4wd swap, LT, dual case, F/R locked
    Just 3 tons of fun!!!
    Ok... Now at least I know I wasn't stupid when I pm'd @HomerTaco to make sure. :thumbsup:
  10. Dec 29, 2018 at 10:49 PM
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    Did you buy a new grill to do this? Or are you using the one off your truck?
    I'm thinking about buying a grill because my truck is my daily and I'm not sure how long that process is going to take.
  11. Dec 30, 2018 at 12:52 AM
    Reh5108
    Reh5108 Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    There's a solid thread somewhere on here with everything you'd need to know about the auto trans that came in the toyota truck. I was reading it the other day and some transmissions won't shift past second if the coolant temp isn't warm enough.
    I anyways get shit for this but imo oem junkyard axles are the best. $50 a piece in Denver. My wallet doesn't want to cry when I break one.
    I run 85-140 because it's what ECGS recommends and I like my warranty. I do experience temps around -30F. Truck is definitely sluggish to move but I feel like it's similar to my T100 when it's cold. I just pulled my front diff apart and there's no sign of improper lubrication even with a diff drop (OMG ARE YOU THERIOUS!?! :luvya: to all the diff drop haters). Some other things happening in it but nothing is heat scorched.
    Anyone doing valve cover gasket, I'd recommend checking the valve lash while you're in there. On the 3rz they are known to get tight over time. I haven't heard of the 5vz doing this but if you're in there it's easy enough to check.
    In my experience the tighter the shaft the quieter things are. If it's sloppy you'll hear it :spy::rimshot:
  12. Dec 30, 2018 at 1:43 AM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    “asks question”
    *knowledgable person responds
    “Tells knowledgeable person they’re wrong”
    Your profile picture is fitting
    ireymon, Gen1FTMFW, m3bassman and 4 others like this.
  13. Dec 30, 2018 at 5:26 AM
    SwampYota
    Jon
    Floor mats
    Bought a new one, they’re cheap on eBay. I figured if I donk this one up or decide I don’t like it I still have the original chrome one.
  14. Dec 30, 2018 at 6:00 AM
    Trim taco
    Trim taco Just one more stupid question
    Bourbon capital of the world
    Was: 96 SR5 5MT Is: 19 OR 6MT
    Bunch 'o random stuff
    Redskins fan? My condolences, I've been trying to get my membership revoked since the mid 90's.
  15. Dec 30, 2018 at 8:55 AM
    xtremewlr
    xtremewlr Well-Known Member
    Todd
    Tucson, AZ
    2003 4Runner V8 - 2012 b00sted XRunner
    I have mods
    This is absolutely correct. They are the same style as a lot of motorcycle (Japanese and European) valves are done. Pain in the ass to adjust. The valves will get tighter as the shims under the bucket wear which will cause the valve train to get quieter. Hydraulic valves get noisier, shim under bucket do not.
  16. Dec 30, 2018 at 9:07 AM
    Blue92
    Blue92 Well-Known Member
    Daniel
    North Carolina
    2018 Sport
    This is why taco tick is a thing. Sign of a healthy engine
  17. Dec 30, 2018 at 10:31 AM
    kuntry09
    kuntry09 Well-Known Member
    Cam
    Douglas, Georgia
    '99 extended cab Tacoma 4x4 converted Prerunner
    This is actually very helpful. After having a burnt valved replaced on one head I’ve gotten more of a tick ever since. I’ve been worried that the valves were out of adjustment. Good info! :thumbsup:
  18. Dec 30, 2018 at 10:47 AM
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    Ya, I've been a fan since the time I knew enough about football, to be able to root for a team. The 80's and 90's were great.
    I've actually tried to become a fan of other teams but I just can't do it.
    Now I just don't watch the NFL... I can stand the stupid shit the players do, the rule changes are stupid, the announcers are too political... And my favorite team is a dumpster fire. What's the point in watching?
    Trim taco[QUOTED] and TacoYankee like this.
  19. Dec 30, 2018 at 10:53 AM
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    I was thinking the same thing. How is the one off eBay? Everything seem solid on it?
  20. Dec 30, 2018 at 11:00 AM
    SwampYota
    Jon
    Floor mats
    Seemed about as solid as the OEM plastic one. It came with connectors but they looked cheap so I bought a pack of OEM ones. I haven’t test fit it so I can’t speak to how it lines up...
