  1. Dec 30, 2018 at 9:14 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    It's not easy to see but if you get you hand up there you can make sure it's secure.
  2. Dec 30, 2018 at 9:20 PM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    Nothing seems awry with the connector. I could barely touch it, but they seemed secure.
  3. Dec 30, 2018 at 10:12 PM
    eon_blue
    Azusa, CA
    How low is 'low' when you say you were low on gas when this happened?
    Too many 'lows' in that sentence...the word sounds funny to me now
    If you were really low (like several miles into the gas light coming on)...maybe what little gas was left sloshed around and the pump couldn't pick up enough at that moment and it stalled out?
  4. Dec 30, 2018 at 10:15 PM
    aknickyota22
    aknickyota22 Well-Known Member
    Adam
    Durango, CO
    2000 Tacoma 4x4 TRD
    Bilstein Suspension, All Pro Baja Bumper, and more
    What a coincidence this actually just happened to me for the first time this morning. It's been single digits here, so went to start and warm the truck up this morning and it started fine and then just petered out and died. Started it right back up, gave it some gas, and all was good.
    Guess I need to clean my IAC valve then haha.
    zero4[QUOTED] likes this.
  5. Dec 30, 2018 at 10:55 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    I forget how big the 4x4 tank is, but when I filled up it was 14.8 Gallons.
  6. Dec 30, 2018 at 10:57 PM
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
    Donahoe CO, Donahoe Rear Resi, Deaver J59, 16" Pro Comp, 33" BFG AT, Hayden Trans Oil Cooler, Oil Filter Relocator, FM 40, ES Bushings, Beefed CB Drop, Deckplate, K&N Drop-In, DO Bed Bar, Cobra 75 WXST, Firestik Firefly, Philips D1R, Clarion Remote Start, Husky Liners
    So you don't have the 4x4 tank? Or is it smaller on the 98?
  7. Dec 30, 2018 at 10:59 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    No I have the 4x4 tank, pretty sure all 6-Lugs came with a standard sized tank. I believe the difference is the 5-Lug tank.
  8. Dec 30, 2018 at 11:00 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    My running theory is that it could be it was gas sloshing away from the fuel pump. I do remember the road being fairly level, however the truck did roll after it stalled.
  9. Dec 30, 2018 at 11:01 PM
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
    Yeah that's what I thought too. But you were only able to put 15 gal in your tank on fill up? Or was your tank not empty?
  10. Dec 30, 2018 at 11:03 PM
    Speedytech7
    Would have to be really low for it to happen that fast, the tank has a surge box so that gas can't slosh too much away from the pump and on mine it took a good 10 seconds of chuggging to die when i ran it out stopping at a stop one time.
    cruiserguy likes this.
  11. Dec 30, 2018 at 11:08 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    It was pretty damn empty. That’s when the gas pump clicked off.
  12. Dec 30, 2018 at 11:08 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    I do wonder what it was. That stalling issue and the inaccurate gas gauge when I came home could be part of a bigger issue.
    Speedytech7[QUOTED] likes this.
  13. Dec 30, 2018 at 11:09 PM
    Speedytech7
    So you still had three gallons or so. When mine clicked off after I died in the middle of the road for a sec. I put in 17.7gal
  14. Dec 30, 2018 at 11:11 PM
    eon_blue
    Azusa, CA
    My v6 4x4 has an 18 gallon tank...if yours is 18 too then I doubt that the gas sloshing around caused this. I've filled up with the light on several times and never had the truck stall out on me. I guess it's a possibility but it just seems unlikely unless you were running on fumes or close to it.
    You sure you maybe don't have a smaller tank? If yours is 15 gallons then the sloshing gas + stalling would seem much more likely
  15. Dec 30, 2018 at 11:13 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    That’s comforting, that means I had a little over 2.5 gallons. Wonder what’s going on with my fuel system.
  16. Dec 30, 2018 at 11:14 PM
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
    Oh weird. My tank is 18.5 gal. I pretty much know when my truck will start sputtering looking at how far down the needle goes. Usually if I get my needle below the last line, it'll take just over 17 gal of gas. My last fill up was 17.3.
    IIRC my truck will start to sputter on level ground with only 3/4 of a gallon left. I forget, it's been many years since I've done that & I try not to.
  17. Dec 30, 2018 at 11:14 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    Very sure it’s the 18 gallon. My 5-lug has the 15 gallon tank and it’s very different.
    When I added my 4WD position lights, I noticed my gas light wasn’t pinned from the factory. You know how many times I relied on that damn light? Haha
  18. Dec 30, 2018 at 11:15 PM
    eon_blue
    Azusa, CA
    Fuel filter got a clog maybe? I know they're more of a pain to do on the 4cyl but could be a good place to start and rule it out, they're pretty cheap. Think I paid $20 for my Wix one
    Running Board Man likes this.
  19. Dec 30, 2018 at 11:16 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    Engine just cut out. I know how a low fuel stall is, I experienced it several times in the 5-lug. Low fuel is accompanied by abnormal engine performance as I’ve noticed.
  20. Dec 30, 2018 at 11:17 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    I’m pretty sure it’s original, so maybe it’s time to change it.
    Doesn’t explain why my gas gauge was reporting inaccurately when I got home. It read 1/4 tank when I parked, and when I restarted it read full tank.
