  1. Dec 31, 2018 at 12:41 PM
    Empty_Lord
    Empty_Lord Toyotaholic
    Dan
    Northwest Indiana/Chicagoland
    My truck use to just die after going full throttle and then coming to a Stop.. after I did the cat back. never did it again after I did the headers though
  2. Dec 31, 2018 at 12:42 PM
    turbodb
    turbodb AdventureTaco
    Dan
    PNW
    2000 Tacoma Xcab 4x4 SR5 V6 TRD
    AdventureTaco
    I wish the Pro's came in 255/85R16, I'd run those instead of the Maxx's (which I also generally like @Dan8906).
    eon_blue[QUOTED] and Dan8906 like this.
  3. Dec 31, 2018 at 12:45 PM
    eon_blue
    Azusa, CA
    Mine have taken a beating and have chunked up a bit on the outer edges, but my KO2s were much worse as far as chunking goes. I was also rubbing pretty bad after I first put them on which didn't help matters. But as far as traction goes, I've been really happy with them overall.
    and yeah, unfortunately we're pretty limited in the skinny tire department with 16s...KM2s I think are the only big brand MT available. I saw some lesser known tire options on eBay and such but the Coopers seemed to be the best bet.
    I have a regular Cooper Discoverer (not STMaxx) as a spare in the same size. I had to run it once and man that thing howls on the street lol.
    Dan8906 likes this.
  4. Dec 31, 2018 at 12:45 PM
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
    Donahoe CO, Donahoe Rear Resi, Deaver J59, 16" Pro Comp, 33" BFG AT, Hayden Trans Oil Cooler, Oil Filter Relocator, FM 40, ES Bushings, Beefed CB Drop, Deckplate, K&N Drop-In, DO Bed Bar, Cobra 75 WXST, Firestik Firefly, Philips D1R, Clarion Remote Start, Husky Liners
    FTFY....
    Oh nm, fixed that for me, I started drinking already. :rofl:
  5. Dec 31, 2018 at 12:45 PM
    Dan8906
    Dan8906 Well-Known Member
    Daniel
    Concord, California
    2004 Tacoma ext cab TRD 4x4
    CBI sliders, ADS extend travel with compression adjuster coil overs, 9” Bilstein 5125 rear shocks, Icon Tubular UCA, Alcan custom leafs, All Pro Apex bumper and skids, NWTI rear diy bumper, 295/70/17 Cooper St Maxxs and nitro 4.88s.
    Pros don’t come in 285/75/17 either
  6. Dec 31, 2018 at 12:47 PM
    El Taco Diablo
    El Taco Diablo Professional Pinstriper
    Matt - KN6DZP
    Hughson, CA
    Impulse Red DC, 5vz-fe, 4wd swap, LT, dual case, F/R locked
    Just 3 tons of fun!!!
    God damn phone! I've had nothing but problems with this S9... Even downloaded a Google keyboard for it.
    Dinking with stuff... Dinking
    zero4[QUOTED] likes this.
  7. Dec 31, 2018 at 12:51 PM
    zero4
    zero4 Metal Cutter
    Will
    SFV, CA
    01' DCab 3.4L TRD
    Naw it was me, you did put dinking but I thought drinking was better! Lol
    Happy New Year everyone! I know, not yet but I'll probably be passed.out by then. :)
  8. Dec 31, 2018 at 1:14 PM
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    I wanna run an aggressive AT. I commute 30 min each way to work. MTs are wearing stupid fast
  9. Dec 31, 2018 at 1:21 PM
    Gyrkin
    Gyrkin Well-Known Member
    Wyoming
    2000 Tacoma TRD v6 5-speed
    OK, I stand corrected. Mine are indeed fiberglass. I always thought they were plastic. I went out to my garage to check it out. There was a piece on the bottom of one that has worn through, I pulled a little chunk off and sure enough it's fiberglass. Owned the truck for 18 years and you would think I would know it, guess not.
    Digiratus likes this.
  10. Dec 31, 2018 at 1:26 PM
    JasonLee
    JasonLee Hello? I'm a truck.
    Q322+3C Denver, Colorado
    15 TRD OffRoad
    TRD Supercharger and more.
    Anti-theft mod! Prevent easy viewing of your belongings inside the shell!
    For as much as you get out wheeling, you would probably be better off getting a second set of wheels with commuter tires and a decent rapid-rise jack and just swap in 30 minutes before you head to the trails. Also, with some lighter tires you'll be happy with those 4.88's for once!
  11. Dec 31, 2018 at 2:01 PM
    Dan8906
    Daniel
    Concord, California
    Fuck. Need some help. Front diff fluid leaking out. Not sure what to do? Can I still drive it? I’m currently 10 miles or so to an auto part store. Any suggestions? Did I blow my new front gears? I did hear a pop yesterday thought something hit my skid plate. Not sure tho.
  12. Dec 31, 2018 at 2:22 PM
    drr
    drr Primary Prognosticator
    Dan
    Seattle-ish
    02 4WD Tacoma
    Where is it leaking from? If it's around the axle seal, the CV probably just popped out and you need to re-seat it.
    Dan8906[QUOTED] likes this.
  13. Dec 31, 2018 at 2:26 PM
    Dan8906
    Daniel
    Concord, California
    Don’t look like it’s around the seal. Stopped at a shop to pull the skid plate off and take a better look
  14. Dec 31, 2018 at 2:28 PM
    eon_blue
    Azusa, CA
    Wonder if they didn't put one of the CVs back in correctly when they put the diff back in after doing your gears
  15. Dec 31, 2018 at 2:30 PM
    eon_blue
    Azusa, CA
    Or if it's leaking from the drain plug then they probably didn't tighten it
  16. Dec 31, 2018 at 2:37 PM
    drr
    Dan
    Seattle-ish
    02 4WD Tacoma
    Well, there's only a few possibilities. It's either leaking from the axle seals (easy fix), from the drain or fill plug (easy fix, unless they're cross threaded), from the pinion seal, or from the joint where the extension tube bolts to the clamshell. If the extension tube wasn't sealed properly and/or torqued to spec, that could be the source.
    I guess I should add, could be from the clamshell joint itself. Not an easy fix.
  17. Dec 31, 2018 at 2:38 PM
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
  18. Dec 31, 2018 at 2:39 PM
    foxrcing07
    foxrcing07 KO7FOX
    Morgan
    Modesto, CA
    2019 Raptard 2001 TJ
    Dirt
    @CalTacoma09 this looks like fun :rofl:
  19. Dec 31, 2018 at 2:44 PM
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    You guys are more than welcome to come participate in the festivities... I'll save you some grease. :thumbsup:
  20. Dec 31, 2018 at 2:49 PM
    Dan8906
    Daniel
    Concord, California
    So it was coming out the diff vent. I’m not sure why. But all the seals looked fine. Cv was seated. Diff was still full of fluid.
    eon_blue[QUOTED] likes this.
