  1. Jan 3, 2019 at 7:31 PM
    Reh5108
    Reh5108 Well-Known Member
    Idaho
    2004 SR5 4X4 2.7L Extra Cab
    OME lift, 4x sliders, Demello rear bumper, custom front bumper, Engo 9000lb winch
    When my pulleys seize my belts melt
    Darth_Yota likes this.
  2. Jan 3, 2019 at 7:33 PM
    Blue92
    Blue92 Well-Known Member
    Daniel
    North Carolina
    2018 Sport
    Thankfully it wasnt that bad when we caught it, still kinda intermittent. Basically we heard it, then took it in to get it fixed. Cant recall if they replaced the belt or not.
    Reh5108[QUOTED] likes this.
  3. Jan 3, 2019 at 7:59 PM
    old4x4yota
    old4x4yota Member
    1996 Tacoma extra cab v6 4x4
    Finished building my bumper
  4. Jan 3, 2019 at 8:07 PM
    buckmaster243
    buckmaster243 I don’t know what to do with my hands
    Buck
    Washington
    2013 DCLB, 2023 4runner
    Yeah it is for dirtbikes for sure. I just take the dog up there when no one is around.
  5. Jan 3, 2019 at 9:07 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    Nice effort man. Looks good!
  6. Jan 3, 2019 at 9:42 PM
    Dan8906
    Dan8906 Well-Known Member
    Daniel
    Concord, California
    2004 Tacoma ext cab TRD 4x4
    CBI sliders, ADS extend travel with compression adjuster coil overs, 9” Bilstein 5125 rear shocks, Icon Tubular UCA, Alcan custom leafs, All Pro Apex bumper and skids, NWTI rear diy bumper, 295/70/17 Cooper St Maxxs and nitro 4.88s.
    How are you breaking dowels?
    1st4x4 likes this.
  7. Jan 3, 2019 at 9:53 PM
    eon_blue
    Azusa, CA
    Fuel pump should be pretty easy to determine, if it's louder when you're near your gas tank then it's the pump. I have the typical Walboro fuel pump whine so I'm very familiar with what whining fuel pump sounds like lol. I can hear it in the cab sometimes but if I put my ear near the gas tank it's much louder.
  8. Jan 3, 2019 at 10:04 PM
    chrslefty
    chrslefty Well-Known Member
    chris
    Mesa az
    01 trd
    Stockish
    Spent the last two days ,i work slow. Replaces the lower control arms with a set of stock arms with whiteline bushings. I thought id be clever and make the job easier by replacing the inner and outer tie rods while i was at it. Still ended up having to move the steering rack. Mainly on the drivers side. Off to get it aligned in the morning.
    I thought the passengers side was the only bad side but im pretty sure that the drivers side bushings were further gone.
    2002Tacoma4x4 and SwampYota like this.
  9. Jan 3, 2019 at 10:41 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    The latter by far. Should have used a bigger one as in thicker handle.
    Willbeck likes this.
  10. Jan 3, 2019 at 11:30 PM
    Blackdawg
    Monte
    Wyoming/St. Louis
    The one I used was 14" long and the handle was like 1" at least. Tapered to 3/8 slowly.
    m3bassman[QUOTED] likes this.
  11. Jan 4, 2019 at 5:19 AM
    Reh5108
    Idaho
    Only does it when I'm driving, at idle everything sounds normal.
    Shittsburg punches are terrible.
  12. Jan 4, 2019 at 6:55 AM
    turbodb
    turbodb AdventureTaco
    Dan
    PNW
    2000 Tacoma Xcab 4x4 SR5 V6 TRD
    AdventureTaco
  13. Jan 4, 2019 at 7:00 AM
    StAndrew
    StAndrew Wait for it...
    Hampton Roads, Va
    SR5 4x4TRD
    Intake, exhaust, lift. Typical stuff.
    Dang. Did you loosen the allen nuts on the collar hat and lubricate the threads? I've never had to put that much effort in cranking my CO's.
  14. Jan 4, 2019 at 7:30 AM
    Reh5108
    Idaho
    Are the oem radiators Denso?
  15. Jan 4, 2019 at 9:19 AM
    Robert61899
    Robert61899 Well-Known Member
    Robert
    Blacked out 2004 Toyota Tacoma Double Cab
    Dang how much you charge to make them?
  16. Jan 4, 2019 at 9:20 AM
    loosnut
    loosnut Well-Known Member
    jerry
    feasterville pa
    06 dbl cab long bed
    ome 2.5lift leer cap
    Sup RYAN?
  17. Jan 4, 2019 at 9:39 AM
    Shiki Shabazz
    Shiki Shabazz Well-Known Member
    Tulsa, OK
    2003 Tacoma Dbl Cab TRD
    Curious, what radiator are you runnin?
  18. Jan 4, 2019 at 9:48 AM
    eon_blue
    Azusa, CA
    Kpatt9 and Shiki Shabazz[QUOTED] like this.
  19. Jan 4, 2019 at 9:52 AM
    Squeaky Penguin
    Squeaky Penguin Nothing Ventured, Nothing Gained
    Brett
    Steamboat Springs, Colorado
    '01 4WD, SR5, TRD & '13 TRDOR AC
    Lots of dust and custom dents, Check Build
    No. Harrison made them.
    Speedytech7 and Reh5108[QUOTED] like this.
  20. Jan 4, 2019 at 10:20 AM
    El Taco Diablo
    El Taco Diablo Professional Pinstriper
    Matt - KN6DZP
    Hughson, CA
    Impulse Red DC, 5vz-fe, 4wd swap, LT, dual case, F/R locked
    Just 3 tons of fun!!!
    Champion.
    Shiki Shabazz[QUOTED] likes this.
