  1. Jan 9, 2019 at 10:55 AM
    xtremewlr
    xtremewlr Well-Known Member
    Todd
    Tucson, AZ
    2003 4Runner V8 - 2012 b00sted XRunner
    I have mods
    The replacement windshield from Safelite for my 2004 Ram was $250 so I'm sure the Tacoma would be cheaper since it's a smaller piece of glass.
    m3bassman[QUOTED] likes this.
  2. Jan 9, 2019 at 11:03 AM
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
    So got bored at work and decided to do the grunt work in anycase of my alternator being gone. From what I've read and picked up on the only things I need are:
    Wiring harness - https://www.ebay.com/itm/Alternator...-to-Denso-Geo-Toyota-Oval-Style-/163085136423
    CS144 - https://www.autozone.com/batteries-...ternator/duralast-alternator/540693_940059_0#
    And a spacer, then it becomes a plug and play upgrade correct? I've seen some write-ups where they cut up the stock harness and I don't wanna do that because I'm going to rebuild my old alternator just in case.
  3. Jan 9, 2019 at 11:03 AM
    Dan8906
    Dan8906 Well-Known Member
    Daniel
    Concord, California
    2004 Tacoma ext cab TRD 4x4
    CBI sliders, ADS extend travel with compression adjuster coil overs, 9” Bilstein 5125 rear shocks, Icon Tubular UCA, Alcan custom leafs, All Pro Apex bumper and skids, NWTI rear diy bumper, 295/70/17 Cooper St Maxxs and nitro 4.88s.
    My was $100 through insurance
  4. Jan 9, 2019 at 11:05 AM
    xtremewlr
    Todd
    Tucson, AZ
    I have mods
    Should be correct. I plan on doing this swap as well and already have the harness for it. You can stack washers for the spacer, unless you find a good source for one the right size or make one yourself.
    BYJOSHCOOK[QUOTED] likes this.
  5. Jan 9, 2019 at 11:05 AM
    Dan8906
    Daniel
    Concord, California
    Shit I’m suppose to go this weekend
  6. Jan 9, 2019 at 11:07 AM
    xtremewlr
    Todd
    Tucson, AZ
    I have mods
    If the new windshield was installed today, it will be fine by this weekend.
    Dan8906[QUOTED] likes this.
  7. Jan 9, 2019 at 11:09 AM
    BYJOSHCOOK
    Josh
    Check Out My Builds
    Good deal! I'll be ordering the parts tomorrow unless I find the alternator is fine (but doubtful)
  8. Jan 9, 2019 at 11:11 AM
    xtremewlr
    Todd
    Tucson, AZ
    I have mods
    You can use the stock belt from what I recall reading. Just bear in mind that the Caddy alt has a 6 rib pulley so the stock belt will not cover it all but will still work fine.
    Edit: Here's the write up on the caddy alt - https://www.tacomaworld.com/threads/3-4-cadillac-alternator-write-up.563992/
  9. Jan 9, 2019 at 11:14 AM
    BYJOSHCOOK
    Josh
    Check Out My Builds
    I remember reading up on that. I found one saying that the stock belt wouldn't work so they used a power steering one, but I never found another write-up saying that. So I'm sticking with stock belt
    xtremewlr[QUOTED] likes this.
  10. Jan 9, 2019 at 11:14 AM
    Dan8906
    Daniel
    Concord, California
    What is the Amp upgrade?
  11. Jan 9, 2019 at 11:17 AM
    xtremewlr
    Todd
    Tucson, AZ
    I have mods
    The caddy alt is 140amp.
  12. Jan 9, 2019 at 11:22 AM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Stock belt works, but make sure you get the caddy alt with the windshield defroster option, it has the proper 1/4" pulley spacer needed for the belt alignment to be halfway decent
    xtremewlr and BYJOSHCOOK[QUOTED] like this.
  13. Jan 9, 2019 at 11:28 AM
    BYJOSHCOOK
    Josh
    Check Out My Builds
  14. Jan 9, 2019 at 12:59 PM
    Dan8906
    Daniel
    Concord, California
    Running Board Man likes this.
  15. Jan 9, 2019 at 1:04 PM
    BYJOSHCOOK
    Josh
    Check Out My Builds
    That I don't know, I've only heard good things about the CS144's
  16. Jan 9, 2019 at 1:11 PM
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    Nah, I like my Damage Multiplier.
    vorabora99 likes this.
  17. Jan 9, 2019 at 1:12 PM
    eon_blue
    Azusa, CA
    sell me your predator bumper already arghh
  18. Jan 9, 2019 at 1:13 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    Please, that’s my 401k investment right there sitting on the shelf.
  19. Jan 9, 2019 at 1:17 PM
    JKO1998
    JKO1998 Well-Known Member
    Utah
    Things gonna rust away before you can put it to use.
    But I bet the rust layers will be thick enough by then it’ll be as good as steel. Maybe you’ll luck out and the layers will put enough pressure on each other and become one solid dust bunny bumper.
  20. Jan 9, 2019 at 1:20 PM
    BartMaster1234
    Tyler
    Flux Capacitor
    One benefit of living in California: Rust doesn’t exist.
    Probably the only benefit, according to most people.
    I’m not welding that thing together till I get better at welding. I have to look at it everyday.
