  1. Jan 10, 2019 at 12:02 PM
    eon_blue
    Azusa, CA
    Nice I should do that...you're right, it sucks bad when you have wet shoes and you go to shift and accidentally pop the clutch hard because your shoe slips off it
    xtremewlr[QUOTED] likes this.
  2. Jan 10, 2019 at 12:02 PM
    xtremewlr
    xtremewlr Well-Known Member
    Todd
    Tucson, AZ
    2003 4Runner V8 - 2012 b00sted XRunner
    I have mods
    Exactly!
  3. Jan 10, 2019 at 12:03 PM
    eon_blue
    Azusa, CA
    My stock ones are still in good shape so I was planning on just putting some skateboard grip tape on them but this is probably a better long term solution
  4. Jan 10, 2019 at 12:05 PM
    xtremewlr
    Todd
    Tucson, AZ
    I have mods
    The stock ones are actually pretty tough. Mine weren't all that bad, even after 316k miles. The clutch one had popped off at some point and started to wear thru the edge.
    eon_blue[QUOTED] likes this.
  5. Jan 10, 2019 at 12:08 PM
    Yetimetchkangmi
    Yetimetchkangmi Well-Known Member
    Benjamin
    Newcastle, WA
    03 Tacoma 4x4 The Yeti
    ARB front locker, Custom high clearance rear bumper, Custom plate front bumper, mile marker winch PE8, safari snorkel, Deck Plate Mod Fox 2.5 rr DSC, Camburg UCA, squeaky Dakar leafs, 5125 10" and custom 7.5" shackles, thee finest PNW pinstripes, MT-R, Nissan crew cab roof rack??? wtf is that about??? Allpro skids, Rigid duallys President McKinley CB with PA Recaro SRD with Wedge Engineering Morimoto retrofits Champion Rad - Failed Tundra brakes
    Rotopax users:
    Using the white 2gl rotopax in Moab, the water from PNW tasted metallic. :puke:
    I am sure that I rinsed it out as it was new from @turbodb
    Do I need to rinse with bleach or baking soda or what?
    Headed to Death Valley at the end of April '19 and want to make sure my water is tasty.
  6. Jan 10, 2019 at 12:12 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    I had the same issue with my fresh water jugs. Some dawn and a half a day soak then vigorous rinsing helps. Also don't fill from tap water where you live, the chlorine taste seems to multiply haha.
  7. Jan 10, 2019 at 12:28 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    DTE?
    Thanks for the explanations.
    The SG also considers distance traveled in its calculations. It gets this info from the ECU so changing tire size has to be accounted for.
    turbodb[QUOTED] likes this.
  8. Jan 10, 2019 at 12:30 PM
    Kpatt9
    Kpatt9 Well-Known Member
    Kade
    SLC, UT
    2013 DCSB
    Sorry distance to empty
  9. Jan 10, 2019 at 12:34 PM
    Digiratus
    Roaming the PNW
    The RedHead
    Yes, both in miles and in fuel
    Kpatt9[QUOTED] likes this.
  10. Jan 10, 2019 at 1:14 PM
    Lucky941
    Lucky941 New Member
    Matthew
    2000 Single Cab 4x4
    C1718B7E-A7F8-4F5E-B67B-800F1E3C1A1C.jpg I did a tight donut today with the new locker!
  11. Jan 10, 2019 at 3:22 PM
    lucky13don
    lucky13don Well-Known Member
    Don
    Milton, fl
    R.I.P.04 tacoma prerunner, 04 sequoia 4x4
    Too many to list
    20190110_151912.jpg these visor vents work pretty good..
    jjsul, 2002Tacoma4x4, Ace115 and 2 others like this.
  12. Jan 10, 2019 at 3:44 PM
    lucky13don
    Don
    Milton, fl
    Too many to list
    20190110_152645.jpg need to run power to the bumper turn signals so these switchbacks will light white with the marker lights..
  13. Jan 10, 2019 at 4:21 PM
    MatthewMay1
    MatthewMay1 I'm an amateur professional.
    Matthew
    Lone Star Republic
    Supercharged '01 TRD
    Is there somewhere on this site that lists all the service intervals for the truck?
  14. Jan 10, 2019 at 4:31 PM
    Jiveydude
    Jiveydude Well-Known Member
    Micah
    OH
    04Taco
    Stuff and things that make it better.
    DW85 likes this.
  15. Jan 10, 2019 at 4:46 PM
    MatthewMay1
    Matthew
    Lone Star Republic
  16. Jan 10, 2019 at 5:11 PM
    lucky13don
    Don
    Milton, fl
    Too many to list
    Let me go check the mail...hold on
  17. Jan 10, 2019 at 5:14 PM
    lucky13don
    Don
    Milton, fl
    Too many to list
    I got it. Thanks brother..now to buy the alternator.
  18. Jan 10, 2019 at 5:17 PM
    lucky13don
    Don
    Milton, fl
    Too many to list
    Yup..on the list. Debating on driving to SoCal and picking up a sleeping platform for my truck..
  19. Jan 10, 2019 at 6:02 PM
    1st4x4
    1st4x4 Well-Known Member
    sam
    Torrance
    98 tacoma 5 speed 4x4
    tundra front clip, tundra brakes, cab cage, camburg long travel, archive garage rear shock relocate
    Dyou doing rtt if so I saw one for 400 I can see if j could find the link its here in cali
    lucky13don[QUOTED] likes this.
  20. Jan 10, 2019 at 6:03 PM
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    Those clicks mean battery is too low to crank, assuming no voltage loss at your batt cable connectors (clean)
